After you drive about 10 to 15 miles the very low refriderent light comes on.WEhave put a new compresser and dyer andorfice valvein it and arebuilt dash cluster in it and a low tempsure senserin it. We have cleared the codes but after you drive it away ways it comes back on.
    President:
  • 1,922 Answers
Go back to whomever did the work, have them put the manifold gauges on you must have another leak
Posted on Sep 26, 2009
What are the probable causes of recurrent DTC P0302?
Check the compression on the cylinder. Compare it to specs and to the other cylinders. If the compression is too low, it can cause misfiring. Low compression could be due to piston ring wear, cylinder wall wear, or improper valve seating.
Feb 14, 2016 | 1998 Volvo V90
How do I adjust the carbs on a 1995 yamaha 750 virago. I just rebuilt the front cylinder and I am getting only 70 to 90 lbs of compression and it is blowing oil. where could it be coming from.
Bad news, I think its a cracked cylinder. Contact local Yamaha dealer for more information. Incidentally, 20,000 miles on a motorcycle engine, if rode hard, can be worn out.
Jun 29, 2014 | 1995 Yamaha Xv 250 Virago S
Transmission temp and over drive off light coming on
check the oil level first
too low and it will be low on pressure and overheat
too much and it will froth up and give the same indications
run the fault codes to check for sensor , servo or solenoid faults
Jul 15, 2017 | Cars & Trucks
My 2000 jeep grand cherokee is over heating, i had a new radiator put in, and a new thermostat and i can drive it about 2-3 miles and it still over heats and the check gauge light pops on , what is causing...
Did you bleed all air from the system? Is it actually overheating or is the light just coming on? If so, replace the temperature sending unit. If you are loosing coolant with no apparent leak then suspect a blown head gasket which will cause the engine to overheat. A compression test will verify this.
Aug 05, 2011 | 2000 Jeep Grand Cherokee
97 plymouth breeze 2.4 never no problems until driving oil light came on idle was rough went to turn it died,we put few quarts oil in it it started up drove a couple miles it died again.down for a month...
take compression test
if it has fuel and spark and timming is good
compression could be low do to low oil level at one time
if commpression low need to rebuild or replace engine
Apr 08, 2011 | Plymouth Breeze Cars & Trucks
2003 CHEVEY BLAZER POOR GAS MILAGE Just tuned up , new wires,plugs, pvc vavle,rotor ,cap.air filter ,fuel filter, seems to run great, no check engine light, 74000 miles, new tires, only getting approx 8...
What grade of fuel are you using? There are many conditions that effect gas mileage. The way a vehicle is driven, is it shifting correctly, flooring it to get up to speed from dead stop also known as Jack Rabbit starts, driving with the defroster on when it isn't needed or the setting just above that can be used. Back in the 90's most car manufacturers made a change to their heating.cooling system that caused the AC compressor to kick in when the selector was set to defrost. This puts drag on teh motor and decreases gas mileage. Build up on valves and low compression in the firing cylinders will cause you to lose gas mileage as well. Do a compression check on the motor to make sure you don't have abnormally high compression or low compression on cylinders and use a bottle of gas treatment in your fuel to clean some of the carbon build up from injectors and valves. Also start using the Mid grade fuel. Not the High Octane in your area. In Texas we typically have 3 choices 87, 89 and 93 to choose from. Low grade is enough to run the vehicle but performance is low as well as mileage. I use the 89 octane for better performance and better mileage. The High Octane or 93 isn't really good as it leads to higher carbon build up on the valves. Also check your oil often and make sure your changing it every 4000 miles at the longest. All of this along with making sure you change the Air Filter every 5000 miles will increase your mileage.
Jan 25, 2011 | 2003 Chevrolet Blazer
Blue thermostat light comes on after driving for 5 miles or so and stays on; after driving for 20 miles or so on occasion the oil pressure light comes on when car slows down and is idling.
when the thermostat in a beetle goes, it stays in the open position, so it could be you blue light is indicating a "cold system",change the thermostat.
the oil light will come on if low on oil or you have a low pressure,try using 10/40 semi synthetic oil.and mloyslip.if no improvement you will need to renew the oil pump.
Jun 18, 2010 | 2002 Volkswagen Beetle Turbo S
I'm getting the engine light coming every so often. It seems that after I fill the tank and get down around 3/4 tank, The message I'm getting is "EVAP Emission Control System Purge Flow Fault". PO441 and...
I have a 2004 dodge stratus 2.4 dual overhead cam. When driving down the road, bell goes off, check engine light comes on, and it's like I'm driving on limp mode, when going over 2000 rpm's, there's a severe stutter. After getting code for light it points to cam shaft sensor, which i changed. I also changed crank shaft sensor. After all of this was done, drove great for about 30 miles and the same thing happened all over again. If anyone can point me in the right direction it would be greatly appreciated.
Jul 05, 2009 | 2004 Dodge Stratus
New car 180 miles from home check engine light has come on - can I drive back on regular roads with this light on
I would pull into the closest auto store and have them put OBD scanner on it to know codes before answering that question.
Apr 18, 2009 | 2009 Subaru Forester
Hi, I have primera., i check the engine oil, and it's too low so i bought 4 ltrs of castrol engine oil and put all of them in the engine., and after driving the car for abt 3 miles smoke came from the tail...
If you low oil light is not illuminated it is ok to drive to the dealer. Putting 4 quarts in might have overfilled it leaving it to leak overboard on engine. You did not say that the smoke was coming from the tail pipe.
Dec 24, 2008 | 1996 Pontiac Firebird
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
