Question about Lexmark X1290 All-in-one Inkjet Print Printer
MY PRINTER ONLY PRINTS BLANK PAGES - Lexmark X1290 All-in-one Inkjet Print Printer
mediatecar
  • 60 Answers
SOURCE: My printing displays wrong ink levels and prints blank pages
If your cartridge is new (or full) and you know that not just from ink levels display, then you did not used the printer for a while (at least a month) and the nozzles of the cartridge are clogged. If u used the cartridghe 4 or 5 moths ago, then the whole cartridge is dryed out, so get out and get yourself a new cartridge.
If it's just a month, then you should put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the cartridge with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridge in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the cartridge on some sheets of tissue.
Install the cartridges it in the printer and run a few cleaning processes from the printers maintenance software.
If the cartridge is new and just installed in the printer, and you have the inklevels but it does not print, then get it out of the printer and back to the store, they should replace it for you. I hope you removed the protective plastic stripe that covers the nozzles before installing the cartridge?...
OK, let ne know please how things evolve.
Hope it helped you, rate the solution.
Almoust forgot: ink levels are displayed by Lexmark inkprinters by estimating the ink consumed trough you printing process, it has no sensors in the cartridge. It's just kind of a counter, you can evan set an empty cartridge to be seen as a full one.
Posted on Feb 15, 2008
  • 7 Answers
SOURCE: Lexmark X 5150 prints blank pages
Hi !!
Try this ---
take out the ink cartridges from printer
Take a tissue paper and make it damp with water
Then CLean the bottom part of cartridge where you see some golden contacts , just wipe it off with damp tissue .
Check if there is any ink coming on the tissue or not .
If No ink coming out , may be u forgot to pull out the protective tape or there is no ink inside the cartridge
Let me know what happens
Priya
Posted on Dec 04, 2008
  • 55 Answers
SOURCE: printing blank pages
fist of all uninstall your printer driver and affter then install printer driver again if problem not get fix
then change cartridge.
Posted on Apr 24, 2009
  • 232 Answers
SOURCE: My Lexmark x1150 printer prints blank pages.
Usually, when the printer prints, but the page comes out blank, the print head on your cartridges is clogged. Since you pointed out that you computer was repaired, I guess you weren't printing during that period, so it is quite normal that the cartridges won't print. Here is a link to Lexmark's site.
http://support.lexmark.com/index?page=content&id=HO1562&actp=search&viewlocale=en_US&userlocale=EN_CA&segment=SUPPORT&productCode=LEXMARK_X1150&searchid=1270554483928.
Read carefully and follow the instructions. If necessary, do several nozzles cleaning, but do bear in mind that it uses a lot of your ink.
If you found my answer useful, please vote and leave a comment, that's what makes it all worth while!
Posted on Apr 06, 2010
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    For 34 Short Paper error, reseat the tray guides and make sure it is set properly. Also, set the correct settings in the computer. For blank pages, always double-check the paper settings and again the settings in the computer. For not printing black, print the Print Quality page and see what color is not printed or not showing. If Print Quality shows black, try printing any document from any application in the computer. Check if you still have the problem. If problem is not resolved, leave a comment so I can get back to this.
    Posted on Apr 09, 2010
    Printer prints blank pages
    This is almost certainly an issue with the toner cartridge. I would recommend running off 30 or so prints and contacting whoever the cartridge was purchased from if the toner doesn't pull through.
    Nov 18, 2012 | Brother HL 2140 Laser Printer
    Prints out blank pages
    if it doesn't print anything, there is a problem with the ink cartridges, if it just prints extra blank pages, you need to verify the printer settings have the correct page settings, and that your word processor doesn't add extra pages to your documents.
    Aug 16, 2010 | HP Officejet 7130 All-In-One InkJet...
    Photosmart 7960 prints blank documents; prints from internet ok
    If it can print from the internet, it is working properly. I would disconnect the printer from the computer, uninstall the drivers and reboot twice. Reinstall the drivers and hook up the printer when instructed. Make sure that you select this as the default printer. (unless, of course, you have another as default)
    Jul 24, 2009 | HP PhotoSmart 7960 InkJet Printer
    I have a 1320 printer that just prints blank pages
    If ink is ok , then you may need to reinstall printer drivers.
    Unplug printer USB.
    Go to control panel>>Installed printers and delete existing printer installation.
    Reinstall printer driver software using printer CD.
    Mar 02, 2009 | HP Laser Jet 1320 Printer
    Hp 1320 prints blank pages
    My HP 1320 printer is printing blank pages and it will not even print test pages etc
    Nov 03, 2008 | HP LaserJet 1320 Printer
    My cx 6400 prints blank pages why
    WON'T PRINT CX400 SAYS IT HAS AN ERROR WHEN ASKED TO PRINT
    Sep 24, 2008 | Epson Stylus CX6400 All-In-One InkJet...
    Kodak printer prints blank pages
    When you print from an internet site page and the Kodak box come up on your screen showing that it's printing, do not close this box until you've finished printing or it will print a blank page.
    Sep 06, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
    Printer only prints blank pages epson sylus cx5400
    Sorry to say, but you may want to read this thread......
    http://www.fixyourownprinter.com/forums/inkjet/29681
    Jul 12, 2008 | Epson Stylus CX5400 All-In-One InkJet...
    Blank pages
    Even though I changed my black and colored ink cartridges twice, the printer still prints blank pages. What should I do?
    Dec 21, 2007 | Epson Stylus CX3200 All-In-One InkJet...
    Lexmark X1290 All-in-one Inkjet Print Printer Logo
    23 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
