Question about GE Microwave Ovens
What is the proper wattage for the replacement over range bulbs? model #MA9698175 thanks
  • GE Master
  • 9,047 Answers
That's not a correct GE model number, but you can find handy exploded views and order parts by model number here.
You can also download GE owner's manuals and installation instructions here.
Posted on Sep 28, 2009
I need to replace the cooktop light bulb-mmv5208ww
You should try to at least find the same wattage. The light bulbs are not dangerous safety hazards if they are made to fit microwaves.
Nov 07, 2013 | Maytag Appliances Over-the-Range Microwave...
On stove bulbs what is the wattage I need to replace the two bulb's. Everytime I purchase bulbs they don't last long. LG microwave, model # lmvm2055st Thanks, Dave
There should be a sticker in the back that quotes this. 40 Watt is the highest you may go but....buy the 130volt brands as this is a higher rating for 120volt and it will not burn out as quick. Make sure it is an appliance bulb. Most hardware stores like ACE have them. Big Walmarts do too but check the package.
Jan 03, 2011 | LG LMVM2055 Convection/Microwave Oven
We have a Jenn Air Microwave Over our built in oven. The light is burned out. How do we replace it? it is a jmc 7010ADB. Thank you Jan G
Mine is JMV8166BAS over-the-range model, and yours may be similar. Disconnect electric source (pull plug, or turn off circuit breaker).
1. Locate and remove 2 Phillips head screws on top projecting from cabinet/wall,etc,
2. Carefully & slowly, slide entire front vent 1/4" towards your left simultaneously pulling toward you.
3. Remove vent filter, if any.
4. In very center maybe beneath filter space, locate approx.4" width aluminum colored metal cover, possibly held in place with Phillips head screw.
5. Remove screw, exposing small light bulb.
6. Gently pull back on bulb, replace with identical wattage, 120V bulb from big box or appliance store.
7. Human touch may shorten life of bulb, so carefully push wire prongs into plastic bulb inlet socket using whatever allows you to grip bulb in the limited space.
8. Reverse 5 - 1 for reassembly. Before replacing vent assembly, notice the small notched angle clips on the bottom before aligning to microwave unit, as these were slightly tricky on my unit when inserting & sliding assembly 1/4" toright.
Jun 30, 2010 | Microwave Ovens
Need cooktop replacement bulb for Kenmore
Search the web site www.searspartsdirect.com Once you find the information, you can purchase it where ever you choose. If you found this information to be helpfull, please rate my solution. Thanks D. Lange
Apr 23, 2009 | Microwave Ovens
F3 Message given from my GE jvm1650wb008 Microwave!
WATTAGE AND CU.FT IS UP TO YOU. JUST MAKE SURE WHAT YOU GET FITS LIKE THE OLD ONE DID DIMENSIONS WISE. THE HIGHER THE WATTAGE THE FASTER THEY COOK AND HEAT FOOD UP.
Apr 08, 2009 | GE JVM1650 1000 Watts Microwave Oven
Cleaning ge profile convection microwave
HI HERE THE STEPS TO DISASSEMBLEA gas range cabinet comes apart very easily. Here's how:
Step 1: Take out the screws that hold the panels, and pull off the control knobs. On the control panel the knobs are friction-fit; pull them straight off. Some knobs may have setscrews in the base of the knobs; back out these screws using a screwdriver or Allen wrench and pull off the knobs.
Step 2: Remove the back service panel on the control panel by backing out a series of screws around the edge of the panel. To remove the front panel, take off the control knobs and remove a series of mounting screws that hold the decorative panel to the frame. These screws may be hidden by molding or trim; pry off the molding or trim with a screwdriver, or take out several screws.
Step 3: To gain access to the burner assemblies, remove the burner grates and then the top of the range. The entire range top should either lift up and off the range or open up and back on hinges. The oven door can usually be removed by pulling it straight up off the hinges on both sides of the door. Some hinges have a latch that must be unlocked before the door can be removed.
Step 4: If the surface light of the range burns out, remove retaining screws and panels as necessary to gain access to the bulb. Replace the burned-out bulb with a new one of the same type and wattage; check the ends of the old bulb for this information. Then replace any retaining panels.
Step 5: If the oven light burns out, unscrew it and remove it from the oven. Replace the burned-out bulb with a new one of the same wattage, made for oven use.
PLEASE RATE IT.........................
Nov 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-1500 range lights
Are any other bulbs in the home going out prematurely? If so, I would check the actual voltage of your power outlets. If not, the bulbs may be getting grease or debris on them from stovetop cooking. This can cause hot psots and premature failure. I recommend wiping them clean with alcohol on a cloth before installing them. I recommend that folks always have their hood fan on when cooking on the stovetop. Also, you might check with a local home center (Lowe's, Home Depot, etc.) to see if they have some high-quality (non-Chinese) substitutes.
Aug 08, 2007 | Sharp R-1500 Microwave Oven
Microwave Ovens Logo
41 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
