Question about Panasonic TH-42PX600U 42 in. Plasma HDTV
This set is only 3 years old. last night it
This set is only 3 years old. last night it started showing ghost images and the color contrast on close-ups is grainy and a lot of red shows through. any thoughts on this? what about cost to repair? is it worth it?
  • d_deporter Sep 26, 2009
    Thanks for the quick reply. I was going to buy a new set...I appreciate the feedback.
  • 11,896 Answers
This would well be worth fixing. At most your looking at $250 to replace some IC's on the circuit board. Possibly convergance board.
Posted on Sep 26, 2009
Why does it show only a gray, ghostly image?
could be a setting in image settings there are a number of picture affects to choose from i.e sepia,negative,color tints etc, should be in picture editor
Aug 08, 2015 | Samsung Galaxy Note 3
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
The TV picture shows a double image like "ghosting"?
Ghosting or blurring vision happens due to a faulty video processing board. It may be due to faulty T-con board (BN81-01308A) or a main board ( BN94-01199B ). However, you'll need to check the wiring on both of these boards. Before this I'll suggest you to callibrate the TV by following these settings--
Contrast: 85
Brightness: 46
Color: 56
Tint: G50 / R50
Sharpness: 15
Backlight: 5
Black Adjust: low
Dynamic Contrast: low
Gamma: 1
If this doesn't resolve the issue then turn off and unplug the TV for 4-5 hours and check.
Jun 10, 2011 | Televison & Video
I have a Sony Grand Vega 60'' XBR800 and it has been working perfectly with HDTV hookup and DVD direct input. Lately, I have noticed some ''green halo'' on the images on the left side of the screen. I...
Hi, It sounds like your lcd chip has gone bad this is how your technology works ;http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 lcd chips that create the image and colors by blending together.When they start to go bad you will get color distortion, color halo,spots even lines.You will need to replace the light engine.I suggested to contact you manufacturer to see if they can fix it at no charge since this is a common problem and even where in a law suit because of that problem.
Mar 03, 2010 | Televison & Video
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
Mar 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Epson C1900 "ghost " images
Sounds like the transfer roller or the fuser unit may be faulty. Look at the fuser to see if the roller surfaces are dirty. If so, replace the fuser.
Jul 20, 2008 | Epson AcuLaser C1900 Printer
Red ghosting on images that are not closeup
1. Power off -- let bulb cool.
2. Display - 5 - VOL+ - Power (in quick sequence) to display service menu.
3. Go into the user menu and set auto revision back to auto.
4. Put an image on the screen that shows the problem. I always found the edges of a 4:3 aspect ratio signal displayed the ghosting very well on my set.
5. Use 2 to scroll through the categories to find D GM TG
6. Use 1 to scroll through items in D GM TG to find V POS D
7. Write down current value.
9. Use 3 and 6 to change the value to minimize the ghosting. You should only need to move it up or down a value or two.
10. Press Mute - Enter to save the changes.
11. Power off and let the bulb cool.
Jun 25, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Ghost images on the screen
sounds like the two stk392-560 ic's need to be changed, usually about $400 for the parts and labor
Mar 14, 2008 | Sony KP-51WS510 51" Rear Projection...
Ghosting problem with Christie LX 45
reset the settings to factory default and make sure the resolution matches. you can adjust the clock and phase in the menu.
Nov 16, 2007 | Christie LX45 Multimedia Projector
Temporary Image Retention, Ghosting?
Quick question, is this the same image? or image from prior frame?
Jul 12, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Open Questions:
See all Panasonic TH-42PX600U 42 in. Plasma HDTV Questions
Panasonic TH-42PX600U 42 in. Plasma HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
