Question about Craftsman Air Tools & Compressors
My 7 gallon 1 HP compressor biuld air pressure very slowly then seems to peak at 30 PSI it is less than 2 years old and seems to operate properly have bleed the tank of condensation? What next?
  • 5,603 Answers
Check the check valve. They are usually where the air line goes into the air tank. On some they are a teflon washer that starts to leak. There is a spring that closes the valve after each pulse of air is pushed into the tank.
Posted on Sep 27, 2009
My Black bull 4 gallon 5.0 CFM 2 HP air compressor will not start. Regardless of whether the on or off position is selected, all I get is a humming sound for about 2 seconds, then it goes silent. After a...
I need the diaphram in the On/Off pressure switch on a Black Bull- 4 Gal., 2 HP, 5.0 cfm @ 90 PSI 120 v /13.8 amp . Batch # 0911. These are the only # I can find
Jan 19, 2013 | Black Bull Air Tools & Compressors
Looking for SCFM rating for a Mastercraft Model # 820218 air compressor
I have a Mastercraft 820218.
Specs are: 2 peak HP 5 Gallon tank 5.0 cfl @ 40 psi 4.0 cfm @90 psi max pressure 125 psi
Jan 23, 2011 | Garden
Compressor will only build pressure to 75 psi and stop and compressor keeps running what could be wrong
If you can hear air bleeding off through the air filter when you turn it off then the check valve has failed on the compressor discharge to tank line and cannot overcome the tank pressure. If there is no air coming out through the air filter than the intake and dischare valves have become weak or are broken/not seating. Post your findings, I wil see if i can help I worked on compressors for 5+ years
Jan 19, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Pressure only biulds to 50 PSI
Two things I'd look at first, the belt to see if it slips and check the water level in your tank, may need to drain it.
Oct 19, 2010 | Ingersoll Rand - Rand Type - 30...
1 HP 3 Gallon Air Compressor does not build up pressure.
it sounds like the regulator is out of whack turning down increases air pressure. make sure there is no leaks
Jun 28, 2009 | Air Tools & Compressors
I have a Husky model Y6010 air compressor.
First remove the valve using probably about a 1/2" wrench but make sure there is no pressure in the tank before you do so. check the cone and seal by loosening the valve by hand and check for debris. If there is no debris then the problem is either the pressure relief valve or weak pressure regulator but may also be a bad piston seal if it is a direct drive unit.
Apr 28, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
Here are the specs on your compressor:
Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
Mar 21, 2009 | Air Tools & Compressors
Will a 1/3 hp compressor fire an 18 guage 5/8'-2" Finish nailer?
You compessor is ideal for a small spray gun however a pin nailer requires 80 to 100 psi and a small air storage thank to operate properly. The nailer may very well shoot a short nail into very soft wood at 30 psi, however there may not be enough pressure to push the piston back to top positon to load another nail and fire again. Good Luck
Jan 31, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
113 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
