Question about Kenmore 44042 Front Load Washer
The machine is not spinning or tumbling, i went through the diagnostic test and that was the only thing it did not do. my understanding is that it is a belt that should be the problem how do i get at it?
I have the same washer and problem. I've had mine for just over five years with no problems, but I've had other top loading washers for as many as 12 years. I solved the problem with the Kenmore 44042 as follows:
1. Remove the washer from the laundry room and move it to the garage.
2. Go to Lowe's and purchase a Roper top loading washer for $300.
3. Install the new Roper in place of the Kenmore 44042.
4. Create and sign an agreement with yourself to never purchase another Kenmore product.
Posted on Oct 02, 2009
To get to the belt you start as above , if you can get to the rear of the machine there are 6 srcews , they are #2 square head srcews, remove them and you will see the belt
remove and replace
Posted on May 21, 2010
MW3677HW Spin Function is Intermittant.
99.9 % it's a cold weld on the pcb...
as you say.
its not a stator , but it can be grafit rods are ending.
rewelding the card (pcb) by a poftional elctronics man will be a good place to start...
Dec 17, 2013 | Washing Machines
I have a Kennmore super capacity 3.5 quiet tumble,action wash,easy access washer. The problem is, it won't do the spin cycle and clothes are coming out wet. I looked at the tech sheet and it says to check...
You might want to check the plumbing in the bottom of the machine for clogs. On most modern washers, the spin cycle will not start if the water is not completely drained or doesn't drain fast enough. I had a similar problem and found a there was a rubber fitting with a plastic cup inside that serves as a trap to prevent debris from entering the pump. It had a piece of scotchbrite, forty cents worth of change and a hairpin stuck in it.
Jan 20, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
LTF2940ES3--Washer drains, but will not do a final spin.
Hi. You have done a great job diagnosing your unit. This unit is designed to not allow a full scaled spin out, if there are issues with the on-board door lock mechanism. This is standard safety equipment for most units. Once this damaged door lock mechanism is replaced, the washer will operate properly. The full scaled spin out will return.
Nov 29, 2009 | Frigidaire Washing Machines
Front Load Frigidaire Won't Spin Out
I had the same problem listed above on my LTF2140ES3...the machine did everything but do a final spin. In diagnostics I could do the final spin and the machine kicked out an E43 which is the control board error.
Following the advice here I changed the door latch first and the problem went away and the unit runs as it should.
You'll get "experts" who say that the unit would not spin at all if the door latch was bad. I can tell you first hand that they are wrong. Again the unit did all the normal tumbling but didn't do the high speed final spin. Again, replacing the door latch fixed the problem. The door latch is part number 131763245 (AP3886713)
Jun 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Front load pumps out water, DOESN'T SPIN, but DOES "tumble"
The pressure switch or pressure switch tube could be blocked tricking the machine that it still has water in it therefore not advancing into 'spin mode'.
Or the electronic card could be faulty and require replacing.
Jun 17, 2009 | Frigidaire GLTR1670A Front Load Washer
Drum won't Tumble or spin
check motor winding resistance. new motor comes with motor control unit. main controls are not common on ge
Mar 08, 2009 | GE WBVH6240F Front Load Washer
GE front load washer can't handle more than a single shirt at a time or won't tumble or spin
Front load washers have an auto water level determined by the weight of the clothes placed in the washer.
If that sensor is malfunctioning the washer may not run !
Unfortunately I think that its time to spend $75. and have a trained GE laundry tech with hands on diagnostic experience remedy the problem. Rather than you spending tons of your hard earned money swapping parts!
I agree with you on that point!
I understand this is not as complicated as a jet engine.
And you tried your best,but some times it is more
cost efficient to let a surgeon fix my hernia while I'm relaxed and under anesthesia, than try to fix it myself!
If My jet was broken, I would not risk flying it after I fixed the problem because I am an appliance man!
I would prefer my life in your hands with your expertise !
Please cut your self a break and call service. You may find it interesting, and fascinating yourself to see what the problem was!
Bless you, and let me know what was the end result!
I believe if I was there with hands on, I would solve your problem!
Please give me a good rating before you sign off, for my rational and calming advice
ngafm
Aug 26, 2008 | GE Energy Star WCVH6260F Front Load Washer
Kenmore 44092500 Won't complete spin cycle
AllExperts.com gave me the answer I needed at no cost.
Jul 29, 2008 | Kenmore Energy Star 44092 Front Load...
Service Mode
System Diagnostics
SERVICE MODE
The service mode provides service personnel the
ability to verify the operation of the washing machine.
The service mode can be entered in the middle of
any wash cycle. While in the service mode, the
servicer can start a variety of special service tests.
Accessing Service Mode:
Pressing down the delicates and heavy soil keys for
3 seconds places the machine in the service mode.
Motor speed will be displayed when started. To exit
Service Mode, press delicates and heavy soil keys
for 3 seconds again.
Troubleshooting
December 2004 4 16025861
©2004 Maytag Services
Stage of
Wash Cycle
Advances To
Presoak End of Presoak
Wash Every 5 Minutes of
Wash Time
Spin/Drain Every Step of The
Spin Profile
Rinse End of Rinse
Speed Range Displayed
a) 0-99 rpm 0-99 (actual)
b) 100-999 rpm Speed / 10
Quick Service Cycle
While in service mode, pressing the delicates key
will start a quick service cycle. This will be a quick
check of all systems.
The following steps will be followed.
1. Energize the cold and bleach water valves. Fill to
Low level, then turn bleach and cold off.
2. Energize the hot and fabric softener water valves. Fill
to high level, then turn all valves off.
3. Lock the door.
4. Tumble using 7/3 tumble pattern for 12 sec.
5. Turn the drain on.
6. Spin to 800 RPM using default rates.
7. End spin and coast down.
8. Unlock the door when the RPM is zero.
9. Display a ‘PA’ (Passed) on continuously for 10 seconds
if no diagnostic codes were logged during this
test.
The up arrow if pressed will advance to the next step.
The right most dot will be turned on as an indication
of failure and stay on until quick service cycle test
has reached the end. Any diagnostic code logged
during this test will result in failure of the test, but will
not necessarily stop the test. While in quick service
cycle, the pressing of the hand wash will suspend
the machine at this step for 30 minutes until the
Hand Wash key is pressed again. All LED’s will
flash on and off while the cycle is suspended, or on
hold.
Motor Drive System
To check the system, check the board for proper
output to the motor control. Performing a board
output test does this. Then perform the Motor
Control Board Output Test.
Motor Control Board Output Test
1. Disconnect power to the washer.
2. Remove the front panel and pull the JP4 Connector
from the motor control board.
The following Quick Spin test steps are as follows:
1) Lock the door.
2) Spin to 350 rpm and hold for 6 seconds.
3) Spin to 550 rpm and hold for 6 seconds.
4) Spin to 600 rpm and hold for 6 seconds.
5) Spin to 650 rpm and hold for 6 seconds.
6) Spin to 800 rpm and hold for 6 seconds.
If the Spin key is pressed again during the Quick Spin
test, the current speed will be held indefinitely. Pressing
the Spin key again will allow the quick test to
proceed as listed above.
When the washer is in the Service Mode, the speed
will be displayed as a two digit number or a letter/
number.
Quick Spin Test
While in service mode, the pressing of spin key shall
start the washer in the quick spin mode.
3. Reconnect the washer power cord to supply
voltage. Make sure the door is closed.
4. Press delicates and heavy soil keys for 3 seconds
to activate Service Mode.
Jan 23, 2008 | Maytag Neptune MAH5500B Front Load Washer
I ran the test program and found faults
No you will need to check the motor controller board
Nov 21, 2007 | GE WBVH6240F Front Load Washer
Kenmore 44042 Front Load Washer Logo
338 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
