Question about Crosley Dryers
How to replace the belt on a crosley electric dryer
  • Crosley Master
  • 7,482 Answers
If it is a front load machine, you need to remove the front of the machine.
When you do this it will expose the drum and belt
Posted on Sep 26, 2009
My Crosley electric dryer will not turn on at all.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 18, 2011 | Crosley CDE6000 Electric Dryer
Crosley dryer model # cde22b6v. Timer switch works but dryer will not turn or heat. I checked connections. Belt is good. Motor turns free. What do you think I need to check?
door switch, bypass by taping the wires together. here are some other things to check:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Mar 30, 2011 | Crosley CDE6000 Electric Dryer
As I was cleaning my crosley dryer modle cde600w I let the drive belt idler arm relax and the spring came off.Now how do you put it back in place?Can you HELP!!! Thank you.
The idler arm attaches to the base, and the spring attaches to the arm, and then the frame. You'll pull the arm past the belt, and then relax your tension, and transferring the tension to the belt.
--W/D--
Feb 06, 2011 | Crosley CDE6000 Electric Dryer
My Crosley dryer not drying
You will have to ensure the tub belt is not broken or off the motor pulley. Also, you may have a bad push to start switch or door closed switch. Open door and manual hold in door switch and have someone to push the start button if there is any sound or attempt to start these switchs are most likely good and your problem is with the belt. Hope this helps God Bless
Sep 18, 2009 | Crosley CDE6000 Electric Dryer
My belt came off my dryer, Help!
You should have a "tension pulley" that the belt goes around somewhere in the belt track. Usually a "wheel or pulley mounted on a spring" which looks like a flat piece if metal. Check to see if it has come out of its positon or the flat spring has broken. You can buy replacements if it has. Simply reposition the belt and push the tension pulley in such a way as to engage the belt correctly. That should fix it.
Jul 16, 2007 | Crosley CDE6000 Electric Dryer
Dryers Logo
218 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
