Question about Garden
Starts and runs for 2 or 3 seconds and quits.Will start again and same thing happens
SOURCE: 99 suburban wont stay on runs for 1 or 2 seconds then dies
have you checked the electrical portion of the egnition yet?
Posted on Jan 30, 2009
  • 41 Answers
SOURCE: Blower runs for 2 min and quits
Check fuel lines for cracks or holes. check fuel filter. If this don't solve it, could be in carb.
Posted on May 08, 2009
  • 15 Answers
SOURCE: engine starts then quits
does it have a fuel filter, or air? If it does make sure they are both clean and free of debris as priming will force fuel up line but will die as soon as its burned out
Posted on May 31, 2010
  • 4 Answers
SOURCE: tiller starts runs for 30 seconds then quits
Make sure the choke is off, use fresh gas and if that doesn't work it sounds like a gas problem meaning it is starving for gas or running rich. brucewo
Posted on Jul 05, 2010
  • 22 Answers
SOURCE: 2001 yamaha breeze wont stay running
i had the same issue. it's gonna be a blockage in one of the vent tubes to the carb. check the line to the left of the carb that runs next to the gas tank. if thats fine then check the gas cap line. then if thats all good then check the line that runs below the carb. these are all vent tubes and allow the carb. to refill with fuel
Posted on Aug 07, 2010
Hi 260 42cc starts good but after using for awhile and shut it off it wont start, it will fire and run a few seconds and quits, does this every time but wont start and run, if i let it sit a few hrs and...
It could be a number of things, bad fuel ( stale) engine over heating and causeing vapour lock, or a bad ignition unit, start with fresh fuel, replace the fuel filter in the tank, try just slackeing the fuel cap and try starting again, this will rule out the fuel tank breather, if still no better replace the ignition unit.
Aug 02, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Car stalls while driving. Will start after about five minutes. Is not flooded. Doesn't usually do this until after it has been driven a bit. Does it more in warm weather. Check engine light sometimes...
I'd have fuel pressure tested. I had a 95' did same thing. Cold winter day, worked fine, as soon as it got warmer, or hot out, it would quit, and re-start 20 minutes later and go for a distance then die again. If I parked in the shade on a hot day, I'd get further before it quit for the first time. I started carrying a fuel pressure gauge with me. Cool in the morning my fuel pressure was up to spec @ 49-50psi. Once it got warm/hot out and it died, Hooked up gauge and it was at 2-5psi. Let it sit and cool off 20-30 minutes, pressure would jump back up and run good until fuel pump got hot again and then pressure dropped off and car quit. It sure sounds like the fuel pump, but the hard part will be getting the car to the shop at the right time, or they will need to let it run on the lot until it quits to confirm the pressure drop. One thing you can try is when car quits, have a can of WD-40 or quick start with you and a screwdriver. Loosen the clamp on the air intake hose where it connects to the front of the throttle body and pull it off. With vehicle off, turn throttle linkage so the plate opens up enough to spray WD-40 a second or 2 in the throttle body. Then try to start it. If it starts and runs momentarily, then you can be pretty sure it's fuel related and my guess is the pump needs replacement.
Apr 12, 2011 | 1996 Plymouth Neon
My 2002 Pontiac Montana has issues starting in hot weather. If it hasnt been driving for a while it starts and runs fine but the once you stop somewhere then theres a chance it wont start again. Actually...
check your temperature if it goes up quite fast you have a problem with your radiator or water pump, but if it is ok check your battery and alternator...
Aug 17, 2010 | 2002 Pontiac Montana
Tiller starts runs for 30 seconds then quits
Jul 05, 2010 | Mantis 2-Cycle Tiller
You can be driving down the road and it will shut off on you after a few minutes you can start it back up and it will go a little ways them it does the same thing again what is causeing this to...
I'd take a can of WD-40 in vehicle, as well as a screwdriver. When it quits, lift hood, remove air intake at throttle body, open throttlebody plate, spray some WD-40 in there,(a second or 2) and then see if it starts and runs for a second or 2. If it does, then you know it's fuel related. Then have filter changed, and fuel pressure checked. If you get real lucky it will be filter, otherwise probably fuel pump.
Feb 21, 2010 | 1992 Oldsmobile Cutlass Ciera
96 ram 1500 5.2 intermittent backfire,quits,like running out gas
you have a leaking intake mainifold gasket that is common on the model
Jan 21, 2010 | 1996 Dodge Ram
Starts then bogs down and quits running
Check and change the fuel pump relay...the one in the black box inside the engine compartment....hope this will help
Jul 07, 2009 | 1998 Isuzu Rodeo
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
