Question about Iomega HDD External Desktop (32660) 80 GB Hard Drive
I plugged in an external hard drive into the USB ports and it does not show up in My Computer. I plugged an ipod into both ports and it showed up. The hard drive showed up once and then vanished. Help??
  • 3 Answers
Tried different usb ports, or check the status of the USB controllers in the Device Manager, if u have any error signs next to the device, tried to unbistall and reinstall usb drivers. when checking for error signs external Hard disc should be connected to the computer
Posted on Oct 18, 2009
    Sergeant:
  • 191 Answers
If this drive has 2 usb cables you need to connect both. one is for power other is for data. it may be also drive physical damage.
Posted on Sep 26, 2009
I know there is data on my phr-250a mcally external hard drive but it's showing empty folder
Leave it connected to your computer and try a restart.
If the folder is still showing as empty, power down the computer then disconnect the external drive.
Power on the computer and connect the external hard drive to a different usb port.
I had this exact problem with a 1000 Gb external drive that was full of movies and music. I thought it had all been lost .. After 2-3 days and repeated attempts of restarts and power-downs/different usb ports it suddenly was recognised again and has worked perfectly since
Jun 07, 2013 | Macally Phr-250a - Usb 2.0 2.5-inch Ide...
My computer doesn't show the external drive
Try plugging the hard drive to a different usb port, if that doesnt work its possible that you may need to update the usb drivers.
Dec 11, 2011 | Fantom Computers & Internet
I bought a brand new fantom drive externl hard drive used it once and now it wont show up when i plug it into a usb port
Try to plug the external hard drive to a different port. if its not working try to use other usb device like ipod, or thumb drive and if the other usb device works it means the problem is the external hard drive it self. If the problem still the same the problem is the usb ports probably the motherbaord
Sep 03, 2011 | Fantom Computers & Internet
My Ovation 320GB external hard disk is not showing on the computer when I plugged in although the red light is on. There's a sound from the disk but after that while it just remain quiet and nothing...
I would try to plug it into a different USB port on the computer or try and see if it works on another computer. It could be that the computers USB port is no longer working or that the drive has failed.
Mar 29, 2011 | Western Digital Elements powered by WD 320...
I plugged my external hard drive into my usb port where it downloaded the driver perfectly and it said everything was working properly. Then i went to my computer and the hard drive does not show up for me...
above the control panel there is a computer word
click on that and it shows the external hard drive double click on the hard drive icon and that will open up all of the files and folders on the hard drive
Jan 05, 2018 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
Why wont my external hard drive registor on my computer? and why wont it show up on my computer?
does it show up on another laptop or computer?
Some of the larger hard drives need access to 2 separate USB ports to allow enough current for the drive to spin up and be accessed. Each USB port on your computer can only provide half an amp of current.
If the external drive has a lead with 2 USB plugs make sure you have both plugged in at the host computer.
The larger drives eg 1TB in a large enclosure usually have a dedicated power supply which you need to use. The smaller pocket size drives (containing laptop hard drives usually no larger than 500Gb) typically only make use of a USB lead for data and power access (whether it be a single or double headed USB lead)
Feel free to ask more questions.
Regards,
Steve
PS please vote for my answer, or add a testimonial if I have helped out.
Oct 12, 2010 | Computers & Internet
My external hard drive is not being recognized by my computer.
Try using another USB cable or different port on your PC. It also may be that it needs external power, Check to see if its plugged in to the wall, if it is, it may be that you need a new power supply.
Jun 03, 2010 | Galaxy Metal Gear GMG 2518UAS External...
I have a 160GB signature mini external harddrive. It has been working fine for months but all of a sudden my laptop won't recognize when I plug it into the usb port. The red light comes on to show that it...
It sounds like your hard drive is dead. If you have tried it on a different computer and it did the same thing then your drive isn't booting up and is probably bad.
Aug 09, 2009 | SimpleTech Signature Mini 160GB External...
Computer will not reconize that my Ipod is plugged into the usb
Plug in the ipod,double click on my computer and see if it shows as a drive.If so and you want this turned off,you can do it by opening itunes and going into the settings and disable hard drive mode.
Feb 04, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
Wd 120gb External no longer recognised by my PC
hi there
have you tried looking at the device manager?
you can also try transfering it to different usb ports.
hope this helps
Feb 04, 2008 | Western Digital Passport WDXML800UE...
Iomega HDD External Desktop (32660) 80 GB Hard Drive Logo
365 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
