Question about Nintendo DS Lite Console
I need to put my ds lite case back on how do i do it
    Scholar:
  • 50 Answers
This really easy, it goes on the same way it came off.
Just go to www.powergamingparts.com
And just do the DS Lite forms backwards, and it should come together really easy.
If you have any other problems just talk to me again.
Posted on Sep 27, 2009
How to get my DS Lite back into english?
If you can work it into main menu without a game in tap on the ds picture at the bottom
Then the wrench picture and then the globe this will give you the languages
Nov 01, 2011 | Nintendo DS Lite Console
Tip
DS Lite not turning on? Read this tip to find out how to fix it!
Have you dropped your DS Lite and now it rattles?
Is it charging but not turning on?
Then this is the guide for you!!
A very common problem with the DS Lite is that when it is dropped a small chip called the L2 Inductor comes away from the motherboard. This will still enable the DS to charge but you will not be able to switch it on. This guide will take you through step by step how to repair your DS Lite.
Things you will need :-
If you are lucky then your L2 inductor is still rattling around inside your DS. If it is lost then they can be bought very cheaply off of ebay :- L2 Inductor Ebay (Please note - This is not my ebay username, just the person that I always get my parts from)
Ok now we have everything it is time to start. Clear a nice big area for you to work in.
First remove any game cartridges from their slots and the DS stylus, like so -
Next remove the battery cover and 2 small rubber bungs here -
Underneath the 2 rubber bungs are 2 phillips screws.
Next remove the battery and take out the circled 3 phillips screws. You do not need to remove the uncircled phillips screw in the battery compartment.
Next, remove the 4 circled tri-wing screws using the tri-wing screwdriver -
Ok, thats all the screws removed, now to lift the case off. Pulling up from the back with 2 fingers on the shoulder buttons gently pull up and towards you but only enough so that you can get the case tool in to help with leverage. See below pictures -
Work the case tool around the gap and the top cover should lift off easily. DO NOT FORCE IT! You will then be able to see the motherboard like so -
The L2 Inductor sits to the left of the motherboard, right underneath the power switch -
Make sure that when you took the case apart if the L2 inductor was rattling around, it has not been lost. Hopefully you have managed to find it. What you need to do now is resolder the L2 inductor back onto the motherboard. Hold the L2 Inductor in place and carefully apply the soldering iron to each end, like so (it does not matter which way round the L2 Inductor goes) -
If you need to hold the L2 Inductor use something like tweezers.
Once you have secured the L2 Inductor onto the motherboard apply a tiny amount of solder onto each end of the L2 Inductor just to give it a bit more strength.
Thats it! You are done! Congratulations, you have repaired your DS Lite!
Now all you have to do is put it back together and you are finished. There are a couple of important things you need to know when putting your DS Lite back together.
You must make sure both the power switch slider and the volume switch slider are in the right place. The power switch slider should spring back to where it is supposed to but these pictures will confirm where they need to be -
Volume switch all the way to the left
Power switch all the way to the right as you look at it
The case sliders also need to be in the right place too, if you do not get this right you will break the little tabs off of the switches!
Volume slider all the way to the left
Power slider all the way to the right
When you re-assemble your ds, start refitting the case from the front backwards. Get it all in line on the front and the back should drop down with ease. Again do not force anything!!
Replace all the screws in reverse order and you are 100% done!! Give yourself a pat on the back!!
on Aug 30, 2010 | Nintendo DS Lite Console
I have a ds lite that works fine but i need to change the casing on it as some parts of the original casing are broken. Can anyone give me or tell me where to get the instructions on how to remove the...
I have written a guide that should help...
DS lite dismantling guide
Hope it helps... if you need any further help oradvice feel free to message me via my profile page.
Regards,
SOD69
Mar 04, 2010 | Nintendo DS Lite
My DS cant read any of my games
seems to be quite a comman problem, check for ant broken or bent pins inside the socket if there are any youll need to replace slot 1 socket. If everything looks fine you could try this trick, open up your ds lite so that the motherboard is exposed, at the bottem of the slot press down in the 2 corners so that u make a slight dent in the metal caseing and 1 in the middle, put the ds back together and try again. good luck.
Jan 13, 2010 | Nintendo DS Lite Console
My DS lite wouldnt switch on whilst i was on it so
It sounds like a faulty on off switch, when you turn it on it is not contacting fully, i had this problem with my grandsons ds lite, what i did was unscrew the ds, then looked to see if the push up and down on off switch was fully contacting when switching on, when i took the case off i could turn it on, i just made sure everything was in place and put the case back on, its ok now, i could be the on off switch had dislodged ater time, and just needed re locating, its nothing to do with getting a new battery.
Oct 15, 2009 | Nintendo DS Lite Console
Nds lite wont turn on
if you have another nds lite try switching batterys if that dont work then its broke, sorry.
Sep 21, 2009 | Nintendo FOR NINTENDO DS LITE NDS AIRFOAM...
Please help i have pulled my ds lite apart and now i do not know how to put it back
sure I could have told you all the steps on how to put the ds back together again but that would just take a while to do so the best way is to watch a youtube vid and see how its taken apart and then just do it in the reverse order from where you are.
Aug 06, 2008 | Nintendo DS Lite Console
Ds lite
WHEN I PUT MY DS ON IT GOES OFF
Jun 14, 2008 | Nintendo DS Lite Console
Ndsl power problem
As Bob (HowlingMad) said, the Ds and Ds Lite will turn off immediately after being turned on if the connection to the top screen is broken.
Check the connections between the screen and Ds, if they look damaged then try replacing the ribbon cable for the top screen (or you may have to replace the whole screen - i'm not sure if it is built together on the Ds Lite). If the connections appear fine then it may be that due to the movement the connector has come out of it's socket/plug (also like Bob said), this is easily fixable if this is the case and would require you to take the casing off your Ds and plug it back in.
Hope this helps
Mowcius
May 07, 2008 | Nintendo DS Lite Console
I want to factory reset how
Is there a possibility to reset de DS lite?
When i put on the power nothing happenes, even when it is connected to AC/DC adapter/
Mar 02, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
59 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
