Question about Garden
Unable to restring
Can not open bottom to restring.
How to restring trimmr line of ryobi gas trimmer
What is the model of your Ryobi trimmer? If it is a bump an cut, you just turn the big plastic screw on the bottom CCW, and take the spool off.
Oct 09, 2014 | Garden
How to restring a husqvarna 224L
To remove the head to restring, push in the bumper cap/side tabs on the strimmer head, the top should then just pull off exposing the inner spool.
Jul 24, 2012 | Husqvarna Weed Trimmer 224 L 4-stroke Line...
How do I open the spool to restring a Troy Bult line trimmer
They come with a rig pin to lock the spool in place, then turn the large platic ball on the bottom of the trimmer head COUNTER CLOCKWISE. do not try to fill up the spool with line it will only get stuck and melt together. You should also sprinkle the line with baby powder as you wind it up as it reduces sticking too.
May 25, 2010 | Troy Bilt Tb70ss Gas Trimmer
How to restring
Remove the cup from the bottom of the unit. Press the 2 tabs and pull away from unit. replace spool found inside or refill with aftermarket line. Wind in direction of arrow.
Apr 18, 2010 | Black & Decker 14" Grass Hog Xp...
How to restring back and decker grass hog
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit. Replace empty spool with new full one or wind on aftermarket string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
Apr 11, 2010 | Black & Decker 14" Grass Hog Xp...
Have a grass hog that has two lines in the spool. How do I restring the spool
wind in direction of arrow on spool. Use 2 separate pieces. 1 at top and 1 at bottom. Feed 1 through each opening in hub when done.
Apr 10, 2010 | Black & Decker 14" Grass Hog Xp...
How do I change the string on a craftsman model# 358.791010?
remove bottom cap, restring spool and reinsert spool and replace cap
Aug 24, 2009 | Garden
Maytag DE 412 won't heat. Looking for a fuse.
No fuse on that old of a model . Probably element bad or thermostat . You can get a restring kit a lot less expensive , but you would have to restring it yourself (not that hard though) or , you can buy the element already strung and all you have to do is transfer the thermostat and install . complete pt # Y303404 ...Restring element pt # Y313538
Jul 19, 2009 | Dryers
How do i restring the Ariens st 622 string trimmer
Cut two pieces of 18" commercial grade line - one to mount on each side. Look at the series of holes, two on bottom of rotating head, two immediately above but on outer lip of plate. Go up through the bottom two holes, even up your piece of line (like when you are putting in a new shoe string in a pair of shoes) and cross over then out through the top two. All done. If you are using an adequate grade of commercial line you can trim for hours over the roughest of stuff without worrying about restringing.
May 03, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
