Question about Vacuums
Tristar mg2 keeps shutting off and a few minutes later comes back on. Almost like it is heating up. I noticed that intermittently I'm losing suction.
  • Anonymous Mar 16, 2014
    I am only getting 4.0 volts at the motor
  • 430 Answers
. remove the hose and check hose and wand for blockage by dropping a coin through end to end. A coin will come to rest against a clog and when you shake the hose the coin will rattle in the are of the obstruction.
Blockage should always be drawn backwards out with another vacuum. If no blockage, install a fresh bag and check your internal filter. Then test the vac for suction where the hose inserts.
Posted on Sep 27, 2009
  • Chemist1961 Sep 27, 2009
  • 64 Answers
Sorry,i just saw your problem. i am an authorized sales and service center. sounds like you have a clog. turn your hose into a blower. you can contact me @ 866-635-9254 or tsscenter@cox.net. hope i helped. John.
Posted on Oct 18, 2009
Tristar raptor pistol grip came off
If you are talking about the pistol grip handle on the end of the suction hose you can put a little bit of glue or sealant on the the pistol grip handle and insert it into the hose. Let the glue or sealant dry before using it.
Mar 30, 2014 | Tristar Vacuums
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Keeps Turning Off
A possible answer is right at the letter head above, look to see if the air filter is dirty or blocked up.
Dec 14, 2012 | Envirocare Tristar Compact Exhaust After...
My toaster oven elements heat up pretty quickly and then go out for a few minutes and them come back on and keep doing that....toast doesn't get done because of it and tonight I tried to cook some hot...
You trouble is intermittent operation. Fix it by checking the thermostat and power button switch also the cord. Check it use a analog tester set to Rx1. All of that is test through continuity, so if there no fluctuation in the meter reading, there is defective parts. An intermittent part(s) operate sometimes good and sometimes bad. Check those parts carefully.
Good luck.
Jul 17, 2011 | Vacuums
Fully charged, filters cleaned, vacuum keeps shutting down in and then starts again only to shut off again. the 6 minute time limit is not used up.
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
Oct 19, 2010 | Dyson DC16 Root 6 Bagless Handheld...
Runs for a few minutes. Loses suction the shuts
It sounds like it's draging on the motor Also heating up the thermister switch. I would recomend having this look at from a vacuum repair shop ask for free estimates if you call around. save some $$$
Nov 10, 2009 | Royal RY9200 Bagged Upright Vacuum
It runs for a couple of minutes shuts off then restarts 30 seconds later runs a couple of minutes and does this over and over
Most vacuum motors are protected from overheating by a thermal switch that resets after cooling down. Check for blockage in the hose,
power head or a full bag that would block cooling air from cooling the motor.
Tom
Oct 22, 2009 | Tristar Vacuums
I have a red c velvet. My vacuum keeps shutting
Could be you have a filter issue and it is overheating and shutting itself off. Make sure you have not put on the wrong filter type for the machine. Some of the pieces that come in the FJM boxes are not actually filters and people make the mistake of putting them on as filters. The other major problem that could be happening is that there is some problem with the hose itself. On my vacuum it will shut itself off after 2-5 minutes, but the power light remains on. I have to press the up button to get more suction, but that only lasts until it shuts itself off again. If I unplug the hose from the cannister... the power comes on fully and the vac never shuts itself off.
A tech told me that the likelihood is that there is some component or connection in the hose control that is causing faulty shutdown. He told me I would need a new hose costing $175. After a year of trying different things, I am convinced he is right and we need to bite it and just buy a new hose.
Sep 13, 2009 | Miele S558 Red Velvet Bagged Canister...
Machine turns on, has little suction, then stops working.
It would be helpful to know what model of vacuum cleaner you're talking about. Basically though, your machine has a blockage somewhere (hence very low suction), and is cutting out after just a few minutes because of overheating.  You need to explore the suction hose (or whatever your machine has), find the blockage and remove it. Blockages almost always happen where the pipe-work takes a sharp bend.  In the worst-case scenario (although in almost all modern machines this is not possible) the blockage may be in the vacuum fan enclosure itself, and then you'll probably need a professional to take care of it.
Feb 03, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Eureka the Boss bagless
Sounds like you have a clog somewhere. Check the filter inside the dust compartment, if is very dirty it won't allow ait to flow thru, Part #62132, DCF-H filter. Check the hose, take it off if you can and drop something in it to see if it comes out the other end, if it doesn't, then the hose is clogged. Check bown by the brush roll, the inlet may be plugged. Also if the belt is more then say 6 months old, you may want to replace it, I am sure it is strertched, part #61120B, extended life belt.
Jan 23, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
Vacuums Logo
198 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
