Question about Sewing Machines
Nu-Vu oven proofer M# sub 123, unevenly cooks bread. door seal is tight. Vent on top of oven sucks air in, it should blow air out
  • kagem&r Oct 03, 2009
    This is a 3 phase oven but the fan only runs on 120v. I tried reversing the rotation and it helped the problem of the vent tube sucking air in, but made the cooking bread unevenly problem worse. Is there something that directs the air flow thats missing or maybe panels installed incorrectly?
    President:
  • Sewing Machines Master
  • 1,714 Answers
This is probably a three phase machine and the 'phase rotation' is backwards, causing the blower to run backward. Reverse any two of the three phase lines in (power input lines to unit) and it will reverse the motor.
Posted on Sep 26, 2009
  • Craig Butler
    Craig Butler Oct 03, 2009
    Is this convection heating (a blower inside the oven) moving the air? Is the fan running? Have you tried an 'oven thermostat' to verify the oven temp compared to the thermostat setting?
How do I open the top of the machine to clean thread etc.?
try a can of compressed air to blow it out .
Oct 31, 2015 | Sewing Machines
I would like instructions on how to set different stitch lengths on my Juki 1541-S.
Puckering is typically NOT a tension problem. But rather a bad needle or not the right needle for the project and thread. Sometimes it's uneven feed but since your 1541 is a walking foot you might have to get the feed timed. I know little about that.
I would first look at the recommended needle thread combo for the fabric. Then the presser foot tension.
Good luck.
Sep 21, 2012 | Juki DNU-1541 Mechanical Sewing Machine
Uneven stitching on the bottom
Try sewvacdoctor.com and refer to handy problem list. Click on it for answer. Hope this helps.
Apr 03, 2012 | Singer 1120 Mechanical Sewing Machine
The top stitching is good but the bottom is to tight and have uneven stitching
try loosening the top thread tension one number at a time until the stitch becomes regular
also try changing the needle--flat side goes to the back of the machine
if this doesn't help then you should consider having the machine serviced
Feb 26, 2012 | Janome 1600P-DB Mechanical Sewing Machine
My Imagine Serger's threading ports are blowing out air when I press the lever, not sucking the thread back in.
Hello Wardmel
Make sure that the serger is set up for threading, now check that the air tubes are not plugged. You should have a long spun wire to clear the air paths.
Happy Stitching
Sewingirl/
Jun 30, 2011 | Baby Lock Imagine
Needle keeps jamming, won't thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
Cannot get the tension right and the thread keeps braking
Good day!
Good day!
Jun 05, 2011 | Singer Inspiration 4206
Sewing Machines Logo
121 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
