My picture is moving from large normal picture to small picture and the sometime flashes off completely and then the picture comes right back on. What is causing this problem?
  • 3,459 Answers
If this is a Magnavox set goto www.TvRepairKits.com for a fix
Posted on Sep 27, 2009
I have a Maytag Centennial top load washer. When washing in normal or heavy with large or super load size, the washer remains in sensing mode. Some water does start to fill, but never reaches wash cycle....
This unit does not handle a super large load as it advertised. When you put a super large load, the sensor is over-sized and will not move on the next cycle.
Sep 03, 2013 | Maytag Centennial MTW5800TW Top Load...
Mitsubishi vs-60607 60" screen is
when picture is getting smaller in size or goes away or moves towards one side then hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 22, 2011 | Mitsubishi VS-60607 TV
The left arm of the cranck don't come out,so i can't take the cranckset off the bottom bracket.Every bolt it's already untight. Thanks!! Stefano
There are 3 bolts to remove: 1 the main large cap in the center of the arm, and 2 bolts holding the arms in place. Remove all three completely. If the arm still will not come off easily, then take a large screwdriver and work in between the bearings and the crank arm and gently pry off.
The trick is too only move a little then go to another section and move another small amount. until the crank arm wants to loosen. The most likely culprit is a small black piece of plastic that is holding up the works.
Nov 23, 2010 | Shimano XTR Hollowtech II Mountain Bike...
Trying to view pictures
If you mean trying to view pictures already taken, then consider this:
there are 4 small buttons, one on each corner, and one large one in the middle, on the back of the camera. Press the top-left one to toggle between viewing and taking-picture modes. Then you can use the larger one to move from one picture to the next by pressing the left or right side of it.
Nov 16, 2009 | Canon PowerShot A560 Digital Camera
Flash busy signal
This is perfectly normal, the flash uses short burst of electricity that are stored in a large state capacitor. This has to be recharged after so many pictures. You can go as fast as the SD card will allow even if the flash is charging, simply close the flash and continue taking photos without it, no effect apart from loss of some illumination depending on the conditions.
Dec 29, 2008 | Canon EOS Digital Rebel XS / 1000D IS...
Sometimes will not start and digital dashboard stops working.
Just had this problem on one of my homies cars. We thought it was the fuel pump, but it wound up being the anti theft. Locking all the doors and unlocking it from the drivers side (As recommended in the owners manual. ) with the key didn't work. But it did work locking all the doors and unlocking it with the key from the passengers side. Started right up!
Oct 30, 2008 | 1993 Chrysler Imperial
Black squares or rectangles over picture
It's the closed captioning. The reason it doesn't go away when you press the "caption" button is because there are four option for closed captioning: Text 1, Text 2, Text 3, and Text 4. The fifth option, which has no designation, is the "off" option. Using the remote, just click on the "caption button until the option has no designation.
Mine was a large black rectangle in the middle of the picture. It's not like Nina3's problem.
Feb 01, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Tassimo
Mine sometimes does this but cleaning the barcode reader at the top of the machine (small glass panel) fixed it. Also make sure the water container is seated correctly. If these dont fix it try pushing the water container left right/back front while there is a disc in the machine-mine has started to only work if I push the fitted water container backwards when "brewing".Its out of warranty now so I will make do until it breaks completely. Regards Nicki
May 09, 2007 | Braun Tassimo Espresso Machine/Coffee...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
