Question about Hotpoint NWXR473EV Dryer
Our 473ET or GT is making a loud rubbing/shrieking noise. Sometimes stops, but is mostly doing it. Have taken the fron of the dryer off, but looks like the back has to come off to tell what is wrong. Help please.
  • Hotpoint Master
  • 7,482 Answers
Take the front of the dryer off again,remove the belt from the drum and remove the drum from the dryer, this will expose the drum rollers,motor pulley and idler arm.
Check to see that the drum rollers are good and do not have flat spots on them, if they have flat spots on them then they will need to be replaced.
Also lube the drum rollers at the shaft and bearing area with a good grade of machine oil, something like 3inOne oil.
Maybe this will solve your problem
Posted on Sep 26, 2009
Loud noise when the dryer turns on
Well, sir, it is metal on metal, and you did well to stop it. Someone will be needing to take the whole thing apart and find the problem. It may be easy because the metal should show where it was rubbing because it will be shiny bright.
Be blessed.
Jan 08, 2014 | Samsung DV448AEE Electric Dryer
2007 Cadillac escalade makes loud noise when starting the car. Sounds like the air suspension on a navigator when it adjusts, but louder. Lasts maybe 20 seconds. Happened 3-4 times within the year. Any...
Try to better describe the noise.
Is it a
scraping of metal
grinding / rubbing
high pitched shriek like a drive belt slipping
Is it
underneath the body
under the hood
in the aircon
when you pull into gear
when you pull away
etc
Do a bit of detective work and come back.
Sep 28, 2013 | Cars & Trucks
Dryer makes a loud rubbing noise as the drum spins and produces no heat to dry clothes. Im not sure exactly what the problem is.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 13, 2010 | Dryers
The barrel makes a rubbing squeeking sound as it turns. Sometimes it is really loud and other times it doesn't make the noise.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up
May 20, 2010 | Dryers
Dryer makes loud noise when operated.
Get your model number and get a set of glides or drum bearings, whichever your unit uses. Don't let this go too long or your drum could be ruined.
Dec 01, 2009 | Washing Machines
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
Dryer makes a loud squeaky noise
probably a bad pulley or drum bearing
Aug 31, 2009 | GE DSXH47EGWW Electric Dryer
Whirlpool dishwasher makes a loud notise then
The spray arms do sometimes wear and need replacenent, and are available fron spares centres.
The loud noise is probably the water pressure pushing it off at an angle, and instead of rotating, water will just escape out one side - so your dishes will not get clean untill it is replaced.
Aug 05, 2009 | Dishwashers
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
71 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
