Question about Dryers
Want to replace dryer belt - got new one, took apart front panel,took drum out and found pully on floor-don't know where to hook it up to
  • Dryers Master
  • 7,482 Answers
The pulley may have come from the motor... if it is then it is normally held on to the shaft of the motor by a set screw, if not then it came from the idler arm. The idler arm hooks up to the frame normally of the dryer with a spring , look for rub marks on the arm to show how to install it.
Hope this helps
Posted on Sep 26, 2009
    President:
  • 1,714 Answers
Look at this: put the 'belt tensioner' back and put the belt on., like one of these...
I have a creda tvr2 tumble dryer. The fan belt has snapped but i I have purchased a new one. I want to know the easiest way to replace it. Cheers
Not totally clear on the particular model, but generally the belt is the same on most dryers.
Definitely do not mess with that thing in the middle there, that is the pivot point for the drum, and the place where the delicate heating elements usually are.
The belt will go all the way around the drum (tumbler); around the motor pully there you see in the opening there, and then arround another pully that is spring loaded to keep the tention on the belt.
It will probably take a tool to pry the spring loaded pully back so you can get the belt on.
Usually too, the machine pops apart with some force if you pry between the seams on the front, either the top pops up, or the front pops forward, then screws inside lead to the rest of the way.
Over all, the front casing will have to move forward so you can get the belt arround the drum, then move back to keep everything from falling in every direction. Once the belt is around the drum, it's just a matter of weaving it around the other two pullies.
It is not an easy task.
Nov 01, 2012 | Dryers
My belt is broken on my tumble dryer.took it apart and don't know how to put the new belt on
The belt goes around the drum, through the idler pulley onto the pulley on the motor. The idler fastens into several holes on the floor of the dryer.
Sep 29, 2011 | Dryers
How to replace belt on samsung dv218ae
Hello & Welcome to FixYa
Please follow the step by step instructions for belt replacement given in this video:
Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 | Samsung DV218AEW Electric Dryer
The belt around the drum of my dryer broke. i have a new one just need some tips on puting it on. Also when i pulled the drum out there was a white/clear piece, round in size, and a metal clip laying on...
don't know what the pieces are that you found on the floor of dryer,check the front panel for the clip,might have popped off when you took the dryer apart or these things fell out of clothing that were put into dryer.now the belt,rap it around the drum with the ridges touching the drum, smooth side up.stick the drum in place and spin it a few times till the felt in the back is lined up and the rollers are lined up on the drum,stick your head inside the drum and hold the drum up with your shoulder,just pinch the belt together and pull it under the pulley and attach it onto the motor shaft,that's it.picture your pants belt floded in half,around four inches from the folded part pinch the belt together and you'll have a loop on the end,your fingers are the bottom part of the pulley and the loop end is the part of the belt that connects to the motor shaft.hope this helps,let me know how you make out
Jun 25, 2010 | Kenmore Dryers
I have a Kenmore Stacked washer/dryer that was given to me. The dryer has a pretty loud sqweek. Is this normal?
A loud squeek is normally caused by the tension pully or the rear drum rollers seizing. Remove the two screws holding the inspection panel between the washer and the dryer. Remove the panel. Slide a 1/2 inch paint scraper between the top and the cabnet front and releave the spring loaded clips that hold the top on and remove the top. Loosen the two screws at the bottom of the dryer front panel. Looking down inside the front panel remove the two screws holding the front panel to the cabnet. Mark and remove the wires going to the door switch and remove the front panel. At the rear of the dryer remove the inspection plate at the bottom of the dryer and remove the belt from the spring loaded tension pulley. Go the the front of the dryer and remove the dryer drum and belt. Now you can check to see if the rollers are worn or seized and check to see if the tension pulley is seized.
Purches a kit that includes a new belt, drum rollers and tension pulley and replace all. Reassemble the dryer in the reverse as to how you took it apart.
Jan 30, 2010 | Washing Machines
Put dryer belt on maytag dryer
generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Oct 29, 2008 | Maytag Dryers
Install dryer belt
more information needed to specifcally match the model
however dryers are all similar so
generically, UNPLUG dryer
A:top mounted lint filter (kenmore maytag(New))
  • remove lint filter
  • remove screws in lint filter housing
  • with putty knife or other flat blade depress lock tabs at front corners of top body panel
  • tilt top panel up
  • remove screws 1/3 way down each side, remove door switch wires
  • remove front panel set aside
B:dryers with screws at bottom of front panel (maytag speedqueen)
  • remove screws from bottom of front panel
All
  • pull drum forward & out
  • examine drum felts, rollers, and slides for wear replace if worn
  • wrap new belt round drum at old wear marks
  • insert drum
  • wrap belt round motor pully
  • pull tensioner pulley hard to end of travel against spring
  • wrap belt round tensioner pulley
  • release tensioner
reassemble
Oct 19, 2008 | GE Dryers
Putting dryer back together
from front with belt around drum ..gather slack and push under idler and around motor pulley right to left...recommend doing it before reinstalling front place rollers on front panel under front lip of drum and lift ..easier than trying to reach under front panel and will a little more slck in belt
Sep 13, 2008 | Kenmore 63012 Electric Dryer
DRUM WON't TURN on my Roper Dryer
you can put the back back on, remove the 2 screws under the lint filter( if ones mounted to top of machine ), then the top tips back revealing 2 5/16 screws holding the front panel on. lift off hte panel and string new belt arond drum and hook ove rht e motro pulley , first passing the belt through the idler tension pulley. belt number is a 341241
Mar 12, 2008 | Roper RES7646KQ Electric Dryer
Dryers Logo
Top Dryers Experts
