Question about Polaris Ranger 26 Men's Full-Suspension Mountain Bike
After accellorating to 15 or 20 mph then letting coast just before stopping a grawling noise from drive train
  • 921 Answers
Lube the chain...if its not lubed correctly it will tend to bind up in the derailluer.
Posted on Sep 27, 2009
What is the drive cycle for a 2003 Nissan Sentra SE?
Take extra caution while performing dirve cycles on public roadways. Drive cycles can be difficult to follow under normal driving conditions. Begin by: - Start the engine. Idle the engine in drive for two and a half minutes with the A/C and rear defroster on. - Turn the A/C and rear defrost off, and accelerate to 55 mph at half throttle. - Hold at a steady speed of 55 mph for three minutes. - Decelerate (coast down) to 20 mph without braking or depressing the clutch. - Accelerate back to 55 to 60 mph at ¾ throttle. - Hold at a steady speed of 55 to 60 mph for five minutes. - Decelerate (coast down) to a stop without braking. If all other emissions systems are functioning properly, completing the drive cycle above will set the "readiness flags" required to pass the smog check. It will not hurt to perform the drive cycle 2 or 3 times before the smog test.
Oct 06, 2016 | 2003 Nissan Sentra
I got into my 2006 trailblazer today and when I accellorate it make a loud squealing noise
It sounds like the black serpentine belt. It's about $20-$40 and easy to replace. Or it could be the pulley. First check that belt.
Jul 28, 2016 | 2006 Chevrolet Chevrolet TrailBlazer LS
S50 vibration above 40 mph. Tire pressure is ok, pulled clutch in and vibration goes away
When the clutch is in of course you're just coasting not under power. If vibration stops you could rule out tire balance but under power could be many things. Is it a shaft drive? If so you're u joint may be going.
Aug 02, 2015 | 2006 Suzuki Boulevard S50
Faint roughness in engine above 65 MPH, goes away when coasting
check emissions controls for leaks then fuel filter as you may be loosing fuel pressure..
Dec 27, 2013 | 2006 Lincoln Town Car
2006 chev 3500 duramax 4x4 noisely differential when coasting at 50 mph, stops under torque and braking
Pull the diff drain plug and check for metal on the magnetic pad. It sounds as if the tapered bearing on the diff pinion is failing. When under load the pressure is on the larger bearing next to the pinion gear bur under coaste the load shifts to the bearing next the the pinion drive nut I suspect that bearing is failing allowing the pinion to comes out of correct mesh position causing the noise.
Feb 17, 2013 | Cars & Trucks
Front end noise
could be wheel bearings
Oct 12, 2012 | 2004 Chevrolet Suburban
How do i do the drive cycle on a 1997 nissan pathfinder
The following drive cycle can be used as a guide to assist with re-setting monitors when a vehicle specific drive cycle cannot be located. This OBDII drive cycle begins with a cold start (coolant temperature below 122 degrees F and the coolant and air temperature sensors within 11 degrees of one another). This condition can be achieved by allowing the vehicle to "sit" overnight, and then by beginning the drive cycle the next day. Most drive cycles will be difficult to follow exactly under normal driving conditions, so the driver should exercise caution, road safety, and courtesy to others.
  1. . Start the engine. Idle the engine in drive for two and a half minutes with the A/C and rear defroster on.
  2. Turn the A/C and rear defrost off, and accelerate to 55 mph at half throttle.
  3. Hold at a steady speed of 55 mph for three minutes.
  4. Decelerate (coast down) to 20 mph without braking or depressing the clutch.
  5. Accelerate back to 55 to 60 mph at ¾ throttle.
  6. Hold at a steady speed of 55 to 60 mph for five minutes.
  7. Decelerate (coast down) to a stop without braking.
Sep 17, 2010 | 1997 Nissan Pathfinder
Loud Intermittent Droaning Noise
rear axle to ring gear side bearing is loose due to weak preload. might be able to locktight is its not to late. was in bmwmoa memeber mag this month december08
Nov 30, 2008 | 2004 BMW R 1150 RT (ABS)
Clicking noise, 2004 Toyota 5-speed
Check your CV joints - usually you'll hear them clicking the most when you turn a corner while pressing on the gas, but they can make noise like that while you're driving straight. Given that it's most prominent above 35mph, I'm not sure that this is going to be the issue, but it's worth checking - if it is a CV joint, and it breaks, your car will coast to a stop and you won't be going anywhere except on the back of a flatbed.
Aug 26, 2008 | 2004 Toyota Corolla
Polaris Ranger 26 Men's Full-Suspension Mountain Bike Logo
122 people viewed this question
Top Polaris Cycling Experts
WTF Chuck.....
WTF Chuck.....
colinat108
Are you a Polaris Cycling Expert? Answer questions, earn points and help others
