Question about Bushnell Golf Medalist BUU0055 Rangefinder
Need a new cap for the battery compartment. - Bushnell Golf Medalist BUU0055 Rangefinder
  • 115 Answers
Call bushnell at 800-423-3537 option one and you should be able to order this part. the model it apears that you have is 20-1354.
Posted on Oct 06, 2009
My igniton turns off while driving and sometimes it wont start at all
Inspect all your ground wires and the wires to the starter and make sure good and tight
Sep 21, 2014 | 1998 Pontiac Bonneville
How do you change the batteries of the bbq grill light
The battery compartment is the opposite end of the light from the on/off buttons. Turn it counter clock wise about 1/2 turn and the batteries should push the end cap out. Remove it all the way. If the unit is new and doesn't have batteries you might have to pull the end cap to get it free of the compartment. Once the cap is free tip the batteries out, replace with new batteries, replace the cap and tighten by turning it clock wise.
Nov 05, 2013 | Brookstone Handle-Mount Grill Light
When i press the button to snap a shot, nothing happens. when I look through the view finder I only see black. I also can not advance the film. I put in new batteries and (yes) the lens cap is off.
Set camera to M90 or B, it will free the shutter. If if fires at these settings but not others then you have an electronic problem. If it does not fire at M90 or B then you have a mechanical problem. Clean the battery cap with a hard eraser and make sure the batteries are in correctly - does the battery check work? Also check to make sure that the battery compartment is not broken. Using a thin round tool, insert it into the battery compartment and push down slightly (not Hard!) and see if the battery compartment gives or you see a crank. Also check for impact around the rewind knob. The FRE resister plate there is made of glass and impact breaks it.
Oct 08, 2011 | Nikon FE 35mm Film Camera
I need the cap cover on the battery compartment
Nikon RifleHunter 550 I have lost my battery cover. I need to order a replacement.
Feb 01, 2011 | Nikon ProStaff 550 Laser Rangefinder
Where is the battery compartment on konica z-up80camera
Under the strap at the grip there are two screws - i assume this is a Z-Up80RC ? Takes a 2CR5 Battery. The non RC model has 'standard' b attery cap at the base, so i assume yours is a RC ?
Jun 01, 2010 | Photography
F&P double dishdrawer
sounds like the rinseaid cap' may not be sealing. I'd try swapping the caps over to see if this fixes the problem if so you need a new cap if not you need a whole new dispenser cheers
May 15, 2009 | Dishwashers
Can't open battery compartment.
ashe 1977
there are two ways to fix this.
1- remove the bottom cover, take the rubber seal off from the battery compartment, remove the battery then soak the bottom cover in vinegar overnite. this will remove all corrosion. remove the battery cap and clean the threads. completely dry the cap and bottom cover, apply WD40 to battery cover threads. clean battery contact with pencil eraser ( carefully ). reinstall the rubber seal, replace bottom cover.------ best fix.
2- this may not work but it's worth a try. just apply ( carefully ) WD40 around battery cap and let it set for about an hour, re-apply and wait another half hour. If this doesn't work refer to # 1
Jan 04, 2009 | Pentax K1000 35mm SLR Camera
Battery compartment cover
They really want you to buy a new camera instead!
TAPE it shut!
Otherwise you can sometimes find equipment sold 'as-is' for parts on eBay or other internet sites.
Do a web-search for it.
Nov 01, 2007 | Fuji FinePix S602 Zoom Digital Camera
Bushnell Golf Medalist BUU0055 Rangefinder Logo
138 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
