Question about HP PSC 1210 All-In-One InkJet Printer
The roller will not pick up paper for prining.
2 Suggested Answers
  • 34170 Answers
SOURCE: hp officejet pro l7780 all in one printer, Cleaned the pick up roller still not picking up paper
The pick up roller may be worn and in need of replacement. The slight grinding noise is the pickup roller trying to work but slipping
Posted on Oct 31, 2012
HP Pro 8500 printer will not feed paper keep getting "load paper" error even though paper in tray; found small white "gear" in tray.
If the gear is broken, you most likely need to replace the pick up roller which is extremely hard or almost impossible. You may try to see if the error is really with the broken gear, or you if you just have a dusty roller that picks up paper by checking if the rollers is actually spinning when it is trying to pick up the paper.
To see what the issue is with gear or roller, try the following:
1. Remove the output paper tray and paper from the loading tray.
2. Send a copy job or print job through.
3. have a flashlight to shine light on the pick up roller and se if it spins. Try touching with your hand to be sure.
4. If the roller spins, put some alcohol on a cloth or paper towel and clean the rubber rollers.
5. Wait a few minutes, load paper and try sending copy job again.
If the roller is not spinning, then you have a problem with gears for sure.
http://www.303electroncs.com/
our eBay parts store: 303Electronics eBay Stores
Mar 30, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
How do I fix a Canon MP460 printer that feeds multiple sheets at a time, even for a one-page document, causing a paper jam?
Assumed you have cleaned out the feeding slot and sprockets that turn the feeder wheels. Often there's some piece of paper or gunk. One option that likely applies to most printers -- from another HP online source: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00190540&cc=us&dlc=en&lc=en
  1. Look for paper that might have jammed inside the product. Use a flashlight to carefully view the areas around the rollers. Remove all traces of paper found.
  2. Wipe the rubber paper-feed rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers up carefully to clean all the way around.
  1. Look for the paper pick roller farther inside the rear access area. The paper pick roller
    IMPORTANT : The paper pick roller is a bit more difficult to reach; however, it is the most important part to clean. Make sure to clean it thoroughly. If this roller is not clean, the issue will likely continue.
  2. Clean the paper pick roller with a cotton swab moistened with distilled or bottled water. Apply a moderate amount of pressure to make sure that you remove all debris. Clean the roller thoroughly all the way around. Figure 8: Clean the paper pick roller
    [img border="0" src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/855/c01996641.gif" alt="Photo of cleaning the paper pick roller." title="Photo of cleaning the paper pick roller.">
  3. Make sure that the rollers on the rear access door or duplexer are clean and in good condition. If any are missing, stuck, or loose, replace the rear access door or duplexer with a new one. Figure 9: Rear access door rollers
    [img border="0" src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/968/c01977887.gif" alt="Graphic of the rear access door and paper rollers" title="Graphic of the rear access door and paper rollers">
  4. Allow the rollers to dry completely, and then replace the rear access door or duplexer. Slide the rear access door or duplexer into place, and then gently push it in until it clicks or snaps into place.
Jul 29, 2014 | Canon PIXMA MP460 All-In-One InkJet...
Hp officejet pro l7780 all in one printer, Cleaned the pick up roller still not picking up paper
Oct 30, 2012 | HP Office Equipment & Supplies
PAPER NOT RECIVE
Paper not picking up?..shoot print command and observe printer trying to grabbing the paper?..see any marks on paper leading edge? Remove cartridge and see inside paper pick up roller,might be its dusty or warn out, remove the pick up roller releasing the side locks, clean with wet cloth, fix it back then try once, if its success..end the process.. if not replace pick up roller..observe similar kind of machine: 2_4_2012_9_32_43_am.gif2_4_2012_9_33_08_am.jpg
Feb 04, 2012 | HP LaserJet M1005 Printer
Paper feed won't pick up paper. tried to put single paper in but paper jam light goes on but no paper located. we think we need new rollers for the paper feed but not sure where to get them in...
The paper pick up fingers and rollers get smooth and polished with use and then slide on the paper. Clean the rollers and pick mechanisms with isopropyl alcohol to rejuvenate them and restore their grip on the paper. Do this as far along the paper path as you can get, using Q Tips where necessary and turn the rollers to clean their whole surfaces.
May 12, 2011 | Lexmark E232 Laser Printer
It does not pick up the paper from the trays, it keep saying paper misfeeded.
Feb 23, 2011 | Office Equipment & Supplies
HP LaserJet P2015 Printer Cannot pick papers
Your paper pick-up roller is possibly broken and needs to be replaced, ( common occurance),the shaft that turns your paper pick-up roller could also be broken, it is on the right side of the pick-up roller, but this is not as common.
Good luck
Feb 21, 2011 | HP LaserJet P2015 Printer
My samsung printer is not picking up the sheets of paper correctly and they seem to be sticking on the roller
It could be a dirty pickup roller in printer. Found following advice from Samsung:
Printer will not feed the paper depends on following possibility.
  • Paper Type:
    • If surface of the paper is too smooth, pick-up roller will not feed the paper.
    • In such case, try with different type of paper.
  • Pick-up Roller:
    • If the rubber roller is worn out, it will not feed the paper from the tray. There is not enough friction to feed the paper.
    • Pull the paper tray out and clean the rubber roller.
Feb 28, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Printer won't pick up the paper in the tray to print. Keep getting out of paper message
First check if the feed rollers are 'Slick" with paper dust, if they are ,clean then with 409 on a cloth rag, and scrub till u dont see the white paper dust on the rollers, let the rollers dry, then reset the printer, by turning it off. then turn it back on ,reinstall the paper and begin printing again.
Jul 15, 2009 | Office Equipment & Supplies
Out of paper
This is due to the the problems of pick up rollers.
the roller either became hard or became so smooth that can not pick paper.
no worry.... here is the soluton..... Open the back door of the printer.  the four rollers are visible..... Clean them with a soft cloth dipped in water & detergent.. (never use alcohol....it kills rubber....) Now rub the rollers with some emery paper or emry tool a little. Put some drops of very fine oil like machine oil and spread the same over till it absorbs all. The same procedure is needed for one take up roller in the bottom. It is a difficult to approach. One can use a scale or alike object to reach it. The oil makes the rollers soft and rough so they easily pick paper. Remove excess oil from rollers and refit the back door.
Hurray..... it is not taking paper..........
Mar 20, 2009 | HP OfficeJet 4255 All-In-One InkJet...
HP PSC 1210 All-In-One InkJet Printer Logo
27 people viewed this question
Seeker5211
Seeker5211
