Question about Remington Polesaw Wizard
Need bull gear for Remington Branch Wizard chain saw
    President:
  • 2,220 Answers
Only model numbers work. Examine your saw something should match up here:
http://www.desaparts.com/remington-chainsaw.html
GL
Lou
Posted on Sep 26, 2009
Remington Pole Say
check for a roll pin in the gear or shaft that has sheared off
check that the square end of the drive shaft is not rounded off or that the square drive in the gear is in fact locking on the drive shaft and not turning from worn out
Jun 20, 2016 | Remington Electric Pole Saw
Need brushes for a 111409-01 branch wizard
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
May 03, 2014 | Remington Electric Chain Saw
When using the saw, the chain doesn't stay tight on the bar.
Should be a nut on the side of chainsaw that covers the chain, sometimes all that is needed is to loosen nut them pull outwards on chain bar and retighten nut. Chain should have some play in it so dont make the chain hug the bar tightly. There is also an adjustment screw next to the bar that will tighten and loosen the chain but is used for small adjustments only.
Sep 07, 2010 | Remington 111409 - 01 6" Branch Wizard...
My new Remington Branch Wizard was taken from the box today and, the chain installed, hooked up, motor runs fine, but the chain won't turn. What's wrong with it?
Take it back. Remington Power is no longer in production anyway. You will eventually need parts that you will not be able to find.
Is the chain excessively tight? Remove the Sprocket cover, bar and chain. Actuate the switch momentarily while watching the sprocket gear (item 11).
http://www.masterparts.net/111409-01.html
Did it rotate? If no there is likely a failure in the gear train inside the power head (not repairable). If it rotates I suspect the chain was improperly installed or over tightened.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 02, 2010 | Remington 111409 - 01 6" Branch Wizard...
Which chain saw blade do I use to replace the blade
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
Items 13 and 14 on your IPB
6" Guide Bar $12.98 and 6" Chain $11.97
Remington Power has stopped production and many replacement parts are NLA. I suggest you waste little time ordering these. HTH
Lou
Dec 18, 2009 | Remington 111409 - 01 6" Branch Wizard...
Remington electric pole saw stalls in vertical positon
check the bottom of the chain guard, look for a loose bolt just inside the housing.
Nov 02, 2009 | Remington Polesaw Wizard
Chain came off bar. How do we get it back on...
Here is a link to the installation instructions for a chain, this should help you! http://12.153.20.74/manuals/113556-01A.pdf.
Jul 12, 2009 | Remington 111409 - 01 6" Branch Wizard...
Remington Polesaw Wizard Logo
96 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
