Question about 2wire 2700HG-B Router (2700HGB)
Trying to hook up hpc309a to my macbookpro thru airport extreme wireless. i can print, from mac no problem there. don't want to fax anything at this time.
my problem is i want to be able to scan from the printer to computer and reverse send from mac to make copy or photo. I keep getting system errors on the scan, the hp says to start with the mac, the mac gives this error.
i tried to connect to airport and to the mac itself from the printer, get the same error on both set ups. can u help?
SOURCE: Replaced my old 2wire 1800HG with a new one and can't connect it
hi!
first of all, let's try to make the broadband link light turn green. open any browser, go the modem's UI by typing gateway.2wire.net or homeportal/setup on the address bar, follow the onscreen instructions on running the system setup wizard. it should make the broadband link green now. for wireless connection, click on the airport icon, and select on the SSID or network name in the drop down menu. if ssid is not on the drop down menu, click on other. type the SSID in the network name field and wireless security is none. (SSID is the last 3 nos. of the SN)
Posted on Apr 22, 2008
SOURCE: 2wire homeportal 1000hw cannot find wireless address
Windows 7 (Beta) and Windows Vista 64 Bit. Step 1. Do not allow the autostartup to run the installation application. You must right click on the CD ROM and select the "OPEN" option. Locate the driver on the install CD. Since my DVD ROM drive is my "D:" drive I located the driver at D:\USB_VISTA32364\BACKUP_2WIRE_VISTA_USB_Installer.exe . Before you click on this you want to right click on this and select Properties. In the properties tab click on the middle tab marked "Compatibility". Make sure you select the checkmark box to: Run this program in compatibility mode for: and use the pull down menu to select Windows XP SP2. This is how I was able to get my 2wire utility to work on Windows 7 (beta) 64 Bit.
Posted on Feb 10, 2009
SOURCE: where do I locate wireless router settings SSID?
Go to your Router's "System Summary" and go to Home Network tab. Then click wireless settings. SSID = Network Name.
Posted on Jun 25, 2009
SOURCE: I have a 2Wire Homeportal that was supplied with
It is your firewall I am betting. Quick fix since it is just a printer you can set your firewall on tmz just for the printer and see if that helps.
Posted on Aug 10, 2009
SOURCE: Trying to hook up an HP wireless printer to my
The WPA passphrase is a method of configuring the encryption code in the wireless router.
You can generate the encryption code using words and phrases so you can remember the encryption code.
You can view the encryption code in the wireless router or you can generate a new encryption code. If you generate a new encryption code then all the wireless cards in the computers on your wireless network will need to be changed so the computers can communicate/connect with the wireless router.
Posted on Nov 03, 2009
Sep 09, 2012 | Apple AirPort Extreme (AIRPORTEXTREME)...
May 02, 2017 | Brother HL3070CW Compact Digital Color...
Jun 07, 2009 | Apple AirPort Extreme Wireless-N Wireless...
Apr 28, 2009 | Apple AirPort Extreme Base Station...
Mar 19, 2009 | Canon PIXMA MX310 All-In-One Printer
Jan 23, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Dec 02, 2008 | HP Office Equipment & Supplies
Apr 07, 2008 | Apple iMac G4 Desktop
Mar 28, 2008 | Canon PIXMA MX310 All-In-One Printer
Feb 07, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Feb 02, 2014 | 2wire 2700HG-B Router (2700HGB)
96 people viewed this question
