Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
The fridge is unlevel front to back. The front is relatively too high. How do I level the beast?
    Scholar:
  • 43 Answers
The front should be a "little" higher than the back, in order that the doors will close softly when pushed past a certain point, and to assist in sealing the door to the cabinet. There is a levelling mechanism on the front rollers, turning a screw or bolt head clockwise will raise the rollers and counterclockwise will lower the rollers. If no rollers, then post type feet that screw in and out for height. Most have rollers in front and these can be adjusted with the screw or bolt that you can see in the front behind the lower cabinet cover. It should lift and pull straight out to remove, and you will then see the adjustment bolts or screws. You should be about half a bubble out of true level for the doors to seal well and close softly.
Posted on Sep 26, 2009
My whirlpool wtw4800xq always seem to spin unlevel
Firstly check the type of floor under it. If it is a wooden floor there may be movement when the machine starts to spin. Otherwise make sure the machine is level using a spirit level check that it is level left to right and front to back. If not adjust the feet under the machine until it is level. This will solve the problem
Feb 11, 2018 | Whirlpool Washing Machines
Is there an adjustment to tighten the refrigerator doors to stay open? Samsung refrig it is balanced.
You can adjust the front and back levelers that touch the floor so that the fridge tips forward just a bit. If you don't have a level, but do have a smartphone, there's a level built in, or you can download an app. Get some help adjusting the levelers -- fridges are heavy beasts.
Aug 04, 2016 | Samsung Refrigerators
UNBALANCED LOAD TROUBLESHOOT
First remove all clothes,get a leveler,then check side to side,then front to back and see if it's unlevel.if unlevel,get wrench and adjust.
May 24, 2015 | Washing Machines
After moving the fridge to clean behind, it now continually trips out electrics
make sure the fridge is level, if its unlevel they will often do this.
Oct 09, 2012 | LEC Refrigerators
Leveling a refridgerator
if not level you need to tip it back and unscrew or screw in the feet on it. use a 2ft level on top to be sure which way to go. if just the door, open door and there is a bracket in between the freezer and fridge and it should be adjustable a little bit. unscrew til lose adjust door to right spot and hold while tightening bolts. that should work. if the fridge door is on top and freezer is on bottom then adjust bracket screws on top of fridge.
Jun 24, 2012 | Stainless Cal Flame Refridgerator Steel...
When washer goes into spin cycle it starts to tub starts to bang against side walls and shortly after error out, with an error on electronic display. Kenmore Elite Oasis
either unit is unlevel or one of the tub supports has come disconnected .... these washers have a slanted top lid so you must put level at side of washer on front and both sides and check front to back with level at side cabine seam as your leveling point
Jan 24, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Door does swing closed so it remains slightly open about half the time when the last person could have sworn they closed it. Hubby tried to adjust hinge but it did not make a difference. The fridge is only...
There should be a way to level the feet of your fridge so the door swings closed by itself. Check the user manual that came with your fridge for advice on how to do this on your fridge, as each make and model of fridge differs. This technique to level a fridge on the floor is generally necessary because the floor where the fridge is placed is unlevel, and it does not imply any fault with the fridge itself.
Jun 08, 2010 | Kenmore 53642 / 53644 Side by Side...
Unlevel fron front to rear, how do I fix?
there are levelers on the front and back legs, you may need to move the fridge out so you can get to the back legs
Aug 01, 2009 | Jenn-Air JCD2295HES Side by Side...
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
1,279 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
