Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Printer paper is stuck way in the back and i don't know how to get to it
  • Ryan  Ruch
    Ryan Ruch May 11, 2010
    Is there any bit of the paper visible and in reach?
Problem 391 on OKI C5200 printer but no paper jam was found.
Open the top. Pull on the top of the toner cartridge (don't release the latch, just pull it up). It will come up with the toner drum assembly attached. You will probably see another paper stuck there which can't be seen when the drums are installed. Also, open the back door and look for paper that might be stuck. But usually, when you've checked everywhere else, the remaining paper is flat under the toner drums. Once you get it out, just click the drum/toner assemblies back in place (careful not to let the green drum touch anything while it's out of the printer.
Mar 06, 2012 | OKI C5200n Laser Printer
My Brother MFC 7340 says it has a paper jam so open the fron cover and pull it out. When I do this the rollers don't move and the paper won't budge. I don't want to force it. What do I do?
Hello.
Try simply unplugging the printer from the power, then waiting 2 mins and plugging it back in while pulling on the paper that is stuck.
This sometimes helps
Regards GM
Jun 30, 2011 | Office Equipment & Supplies
My printer lexmark model E250DN....the problems it`s when complete put back the tone cartredge...got some noisy came from printer...noisy like stuck...already refill the paper...i try again pull out he...
The noise coming from the printer is an indication that there is a hardware issue. It would be best to call Lexmark Technical Support for further assistance.
May 16, 2011 | Lexmark E250dn Laser Printer
Hi, Sirs; My name is Heiman, Today I have one question want to request you that, I can not push to stop the button of paper jam in appear a flashing error on the printer. And also when I want to print...
Paper jam means a paper has got stuck up on your printer. open the printer and see if you can carefully pull the paper that has got stuck up in the printer out. after that try fixing the papers correctly in it right positions. or don't load much papers again. if you know you want to print only a page of work, then try putting on one paper inside.
I hope this works for you.
May 16, 2011 | Lexmark X2600 InkJet Printer
While scanning a document, last page backed up and did not completely exit the scanner. I then added more pages to scan and when I did, that last page backed up some more and is not stuck in the printer. ...
There is no paper pressure release on the ADF. You pretty much have to muscle the paper out while trying to be careful. Turn the printer off first so that you are not fighting with the paper drive motors. Typically this type of non-ejection behaviour is an indication that the ADF assembly or the ADF cable is bad. They all come as one unit so unless you have another unit you can rob a cable from then you are looking at replacing the whole top.
May 05, 2011 | HP LaserJet M1522nf Multifunction Printer...
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
Paper jammed when loading paper, don't know how to clear jam
Welcome to FixYa.
To clear the paper Jam, follow the steps below.
1. Remove all loose paper from the paper In tray.
2. Do not pull paper jam from under the front cover.
3. If there is more than one sheet stuck in the printer, remove the paper sheet at a time.
4. Make sure no scraps of paper are stuck in the printer.
5. If there is open the door at the back of the printer.
6. Pull the jammed paper out of the printer.
7. Check again to make sure no scraps of paper are stuck in the printer.
8. Close the back door.
9. Restart your computer.
Hope this information will help.
Mar 24, 2011 | HP Photosmart 2610xi All-In-One InkJet...
Paper stucked inside
Open the top cover.
Pull out the toner / developer units and look for paper under neath.
In the rear, pull open the access door.
remove the paper tray and look for misfed paper.
Dec 12, 2009 | Kyocera Mita FS-820 Laser Printer
Paper Jam light is on and there's no jam anywhere. What do you do?
A paper jam notification can be caused by two things. One a hard jam, paper stuck.
Two, If the paper does not reach a flag or sensor on time, the printer knows that a jam has occurred.
Most likely, you had a paper pick problem caused by dirty rollers or maybe the paper is held to tightly by the paper tray. Also a static charge on the paper can sometimes cause sheets of paper to stick together.
Don
Dec 09, 2009 | Dell 1720dn Laser Printer
Paper jam
There is a sensor in the back that lets the printer know the paper has exited the fuser. It is probably broken off if paper is getting stuck back there.
Also check for paper remnants that are jammed. This may require removal of the fuser.
Mar 13, 2008 | Dell 1700n Laser Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
24 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
