Question about AOpen vKM400Am-S Motherboard
Aopen mother board diagnostic light lite up
I have a AMD 1700* Build with a aopen Proak73(3) thunderbird motherboard - recently when i turned computer on it would shut down after several attempts i could get computer to boot up - at first i thought it was a power supply going bad because fan on supply wasn't turning - i got that problem repair yes by spraying just a little dw40 lube on base area of fan - sometimes the computer will boot up saying your computer may have a CPU problem and upon several attempts i have been able to get computer to boot up - the motherboard has a red LED lit up on it for a few minutes after it shutes down when the computer doen't boot - i've told by a friend that this is probably a bad motherboad ? Suggestions and if you agree How much Damage in Dollars am I looking at for Parts - my friend suggested getting a board with a CPU also since the other could be fried?
Mike Norris
e-mail kylooker@yahoo.com
    Problem Solver:
  • 19 Answers
Three in One Oil & DW40 are not suitable for lubing a fan. What you need is a good lubricant. Axle Lub is a good lubricant, it is resistant to break down by heat (it does not evaporate) and a good solid lube. Good to your local General Department Store, which has a Auto Repair Part Section, and look for a good lubricant there. You'll need to open the reservoir that the lube is put in, wipe it out, and put the lube you purchased in.
I have two Antec, both over three years old, fans are just doing fine. The big case fans slowed down, after the first summer, the lube started to evaporate from the heat. I'm sure that's a common problem.
Posted on Dec 18, 2007
  • 56 Answers
If that problem...that motherboard is defective ...i suggest to buy a new motherboard that compatible to your processor and memory... i'll give a link of site to buy the part.....
http://search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&dfsp=1&from=R10&_trksid=m37&satitle=motherboard&sacat=-1%26catref%3DC6&sargn=-1%26saslc%3D2&sadis=200&fpos=ZIP%2FPostal&sabfmts=1&saobfmts=insif&ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=1%26fsoo%3D1&fgtp=
Posted on Dec 17, 2007
K got an aopen mother bored along with a pentium 4. all ive been doing is adding ram and putting in a new hard driver amd put a new case on the disk drive. then i turn i my computer and its beeping every 5...
Sounds like a RAM compatibility problem. Check to see what ram is supported in that board, and if thats what you have. Kahlon has good prices on RAM
Jun 08, 2012 | Computers & Internet
Custom computer build, foxconn motherboard, computer wont start
Not trying to be condesending but start simple and work your way up.
1. strip dow board to;
a. known good older processor
b. known good single memory stick
c. known good power supply
Test
move memory one slot over
Test
Move memory over one slot
test
move memory to last slot
test
You have tested the variables if still not working you have a bad mother board.
contact foxconn for replacement.
Feb 28, 2012 | AMD Computers & Internet
Pin hookup for on/off reset switch
Go to the AOpen website (http://usa.aopen.com/index.aspx), click on download. In the drop down choose mother boards and then your model. Now if you click search it will bring up all downloads for your motherboard. Near the bottom of the list is manual, Click on the language of manual you need. Download from one of the FTP sites listed, the manual will contain a drawing of *********** board and were everything plugs in.
You can also take a flash light and magnifying glass and try to read on the mother board itself were every thing plugs in. Some motherboards have the information printed right on them, in very small mouse print.
Jan 31, 2012 | AOpen MK77M-8XN (91.88D10.031) Motherboard
I have an AOpen vKM400Am-S Motherboard, when i turn it on a red light and cpu fan turns on but no video to my monitor,i checked if my video card works on a difrent pc and it did, my pc wont turn on
this caused by RAM error, open your computer, disconnect ram, turn on your computer?is computer beeping, 1 long and 2 short beep??if yes the problem is come from your ram, clean your ram connection then connect ram to mother board, turn on your computer, is the video come to screen??if no, try to connect another ram to your computer, for sure use new ram
i hope this helpful
thank you for using fixya
Feb 05, 2011 | AOpen MX4LR (91.89Y10.002) Motherboard
My pc processor not hit when on the mother board my mother board is aopen mother board plaese give me salution
If you mean that your processor pins does not fit in your motherboard, then they are not compatible. The processor pins must be exactly fit the motherboard.
Besides, the processor type must be supported by the motherboard (If the motherboard is supporting P4, Core Dou, Quad, Celeron, Athlon, etc). You have to install the right processor for a particular motherboard. You have to know what particular
processor is supported by your motherboard.. In your
case, I believe it supports Pentium 4, but I cannot
give you the exact speed in Ghz, as well as the clock speed. You can ask the dealer about it.
Nov 22, 2009 | AOpen (MX4SGI4DN2PRE) Motherboard
My mother board AOpen MX4LR, socket 478, dead
bad mobo or psp is bad try psp for now lock down mobo tight also losee no good
Jan 06, 2008 | AOpen (MX4SGI4DN2PRE) Motherboard
Cpu size
Hi handydak
For your Mobo
VKM400 AM-S Try this link it will tell you what max size CPU & Memory you can install to improve performance.http://download.aopen.com.tw/Default.aspx
Regards,
ajb2000
Dec 28, 2007 | AOpen vKM400Am-S Motherboard
I would like to upgrade my aopen ax4b motherboard and 1g of memory
Hi, I have found Foxconn to have a good range of mother boards at a very reasonable cost.
They have both Intel and AMD to suit everybody from simple home use to gamers.
Regards mistyman
Dec 23, 2007 | Computers & Internet
AOpen vKM400Am-S Motherboard Logo
139 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
