Question about Sony Alpha DSLR-A200K Digital Camera
The lens kit of my Sony DSLR A200 produces noise when the function is AF (Automatic Focus). What could be the problem? It seems like the lens is stuck or something...
2 Suggested Answers
  • 58 Answers
SOURCE: The lens kit of my Sony DSLR A200 produces noise
If it's in continuous auto-focus and doing it, then it is just not locking on to one thing and jumping back and forth between two objects that are very close together in distance and it is normal. It should stop in manual, single shot or single point auto-focus. Sony uses Nikon auto-focus technology and my D-300 with a 70-200mmf2.8 will do it if I turn the auto-focus tracking time(lock-on) all the way down with the auto-focus in full auto.
Posted on Oct 01, 2009
Testimonial: "Thanks for the info"
How can I stop the metering on a Sony a77 Camera?
When you are using non brand lenses, with an adapter ring, most camera's can't communicate, so you have to use the lens as a non chip lens and it only will work in full manual mode. So switch the camera to M (manual) and then do manual focus and manual aperture on the lens. When you shoot a picture, look on the histogram if you need a faster or slower shutter speed and dial in the speed (manual) you think is correct.
Jan 12, 2015 | Sony a77II Alpha 77 Mark II Translucent...
What causes noise and vibration in the lens whe. turned on axa100
It's almost certain that some part of the lens or the supporting framework are faulty. You can try troubleshooting the device with the user manual, but you will probably need to have it repaired. Try checking out the user manual to be sure:
Sony DSLR A200 manual
Feb 07, 2014 | Sony Alpha DSLR-A200 Digital Camera
Image shifts off center and two corners appear rounded as if you are focusing on the rim of the lens.
Image shifts off center and two corners appear Problem with the Sony Alpha DSLR-A100 Digital Camera That
The Sony A200 kit (DSLR-A200K) comes with a DT 18-70mm (3.9x) f/3.5-5.6 zoom lens for an estimated US$600.
A separate Sony A200 kit (DSLR-A200W) includes two lenses: the DT 18-70mm mentioned above, and a 75-300mm f/4.6-5.6 telephoto zoom for an estimated US$800.
Click Here To Watch More Information about This Answer
Jul 18, 2011 | Sony Alpha DSLR-A100 Digital Camera
Opteka 500mm f/8 mirror lens for my DSLR and it's says no lens
You need to turn the mode dial to Manual (M). You won't be able to use the camera's built-in exposure meter at all with this lens. You can take an exposure reading with another lens to use as a starting point, then review the pictures and histograms to fine-tune the exposure.
Feb 26, 2010 | Opteka 500mm f/8 for Canon EOS
Everytime i turn on and off my A200(sony DSLR) it shakes and makes noise,, and before it focuses on something it shakes and makes alot of noise?? wahts wrong with it?
It is not your camera, it is your lens, The af lens trying to engage and the gears are grinding. Just for verification go to your nearest camera store and try a different lens on your camera. They will not shake like yours.
Jan 10, 2010 | Sony Alpha DSLR-A200 Digital Camera
Sep 29, 2009 | Sony Alpha DSLR-A200K Digital Camera
Sony 18-70 kit lens vibrates badly
This is a lens problem, the AF motor of the lens is trying to engage the gears. Sometime it works, sometimes it does not... It happened to my sigma 70-300. The only solution is to have it repaired. If under warranty it should be free, if not.... might be cheaper to buy a new lens.
Sep 28, 2009 | Sony A100 Digital SLR & 18-70 Lens Kit...
Sigma 70-300 +''no lense attached'' w/ sony a200 dslr
clean brass contacts with qtip and rubbing alcohol. let air dry couple of hours. do the body and the lens. hope that helps
Jun 02, 2009 | Sony Alpha DSLR-A200K Digital Camera
Unfortunately, there are electrical differences between early and later Sigma lenses. Although the bayonet connection is the same, and the lens can fit, it will not necessarily connect electrically with the connections on the camera. Sigma can modify the lens for you, but this can be quite costly, and you may be cheaper to look for an alternative lens.
Mar 15, 2009 | Sony Alpha DSLR-A200K Digital Camera
Sony Alpha DSLR-A200K Digital Camera Logo
189 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
