Question about Jura Capresso C3000 Espresso & Coffee Maker
Water leaks out of the back of my capresso C3000 how do I remove the back to see what the problem is I sent the machine in for repairs once and now have the same problem all over again, please help
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 60 Answers
There are to oval screws on the backpanel. After removing the panel, unscrew the powerboard and check the flowmeter behind it
Posted on Oct 06, 2009
Machine beps showes Clean New
Cleaning instructions for that machine can be found in the user guide at the link below:
http://www.capresso.com/pdf/super_c3000.pdf
Sep 03, 2013 | Jura Capresso C3000 Espresso & Coffee...
Jura capresso c3000 yellow clip
I found out where it goes, thanks to Juergen, who pointed me toward his excellent page on Jura cleaning: see figure 7d, copied here
which shows the yellow clip helping to hold on the tea pipe. I'm guessing that if you don't use the tea pipe, you will be okay. Otherwise you can just put that clip back on next time you clean the machine.
Nov 08, 2012 | Jura Capresso C3000 Espresso & Coffee...
Is there an easier was to decalcify the capresso 3000 than taking apart the whole machine. The directions say you have to remove the auto cappuccino assembly
Yes
You should run the decalcify program with the JURA decal tablets or DURGOL. Do not use other agents.
See page 25 of user manual.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Jura Capresso C3000 Espresso & Coffee...
How to remove the back panel of a c3000
No, your damn right, theres no tool on the market for tohse screws.
I did it with a fine end point pliers, it cause litle damage to the screws head, but worked.
Feb 28, 2010 | Jura Capresso C3000 Espresso & Coffee...
Service 8 on Capresso 1300
The gears inside are clogged with coffee grounds. The machine will need to be taken apart carefully, and the gears cleaned of the coffee. I just did mine a C3000, and you will have to be careful to remember how all the parts go back together. This takes a T15 hex key for the screws. Good luck.
Aug 30, 2009 | Jura Capresso C1300 Coffee Maker, Espresso...
Went to make a cup and only got about a qt. of a cup. tried again and got no water at all can you help
I own a Jura Capresso S8 espresso machine which has been wonderful except for the pump that makes the froth. I sent it back to be repaired once already, at the tune of $250.00. Now it seems to have gone again, and this time it will cost me $275.00 to have it repaired. Anything I can do myself?
Aug 14, 2009 | Jura Capresso C1000 Espresso & Coffee...
Capresso C1300 LCD stays on stating "Hot water cycle necessary"
I had one that set for 6 months that had that problem. Air had gotten into the water lines. Opened the hot water tap a few times and then removed the end of the water line that runs from the solenoid to heater block to at the solenoid end to bleed air out. It could also have been some calcium deposits that blew out with the air blocking the line. Then I replaced the end of the line, powered the machine up and it worked normally. Note: Jura Capresso and Capresso machines are complicated and it takes some mechanical know how to open them up and service them. They also have four special screws on the back that requires a special tool to open
Feb 26, 2009 | Jura Capresso C3000 Espresso & Coffee...
I have a capresso c3000 and one day it just wont turn on anymore. any suggestions?
We had the same problem. We unplugged the unit from the wall and then plugged it back in again. For us, it was as simple as that.
Jan 08, 2009 | Jura Capresso C3000 Espresso & Coffee...
Capresso C3000 Mega-weak coffee
I have a Capresso fo 7 years now, had few problems, but always solve them.
If youe machine does all the functions properly, but doesn't give you coffee, you should check if everytnhig goes into the grounds tray. If that's the case you may only have a broken "O ring" inside the pressing element. It makes the coffe, but throws it away instead of filling the cup. I had that problem, and it was the "O ring".
If the grounds dunped on the tray are dry, you're looosing the water in the back, probably on the relief valve.
Hope this helps!
Mar 23, 2008 | Jura Capresso C3000 Espresso & Coffee...
Jura Capresso C3000 Espresso & Coffee Maker Logo
614 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
