Question about HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n and the evil Green Streak
My HP Color LaserJet 2600n printer prints a green vertical line on the right side of my paper. It doesn't smear. I rarely use this printer, so most the time it is turned off. But when I do use it, it's prints this very annoying streak on my sheets.
I'm not sure where to start to fix this problem.
  • 300 Answers
SOURCE: HP LaserJet 2600n
It sounds like it, but before you replace it you might want to troubleshoot this through the HP Toolbox (the software would have come with the printer) if you haven't got it, download it from www.hp.com (it's straight forward and easy to use)
Posted on Jun 12, 2008
  • 47 Answers
SOURCE: HP laserjet 3030 black streaks
You have useful help if you measure the distance between the defects. If the lines are repetive, use this link http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=378048&prodTypeId=18972&prodSeriesId=378048&objectID=c00063561
Posted on Nov 05, 2008
SOURCE: STREAK LEFT ON RIGHTHAND SIDE OF PRINTED PAGE
Fuser sleeve is contaminated and needs replacing - cheaper to replace the printer.
Posted on Apr 17, 2009
Evildice
  • 217 Answers
SOURCE: HP 2600n - Maintenance of the transer roller sheet
You can clean it using piece of paper (not printed). time for replacement - your image is very ghostly and you cant get better image after cleaning lasser/scanner assy :)
Posted on Oct 27, 2009
Soulvisitor
  • 1113 Answers
SOURCE: What is the best way to clean the transfer roller
dont clean, unless glued up, but they dont like it, can spot remove stuff with metho, but they last about 60000 pages cause little problems unless torn, Some models just unclick by buttons either side near hinge others are fixed and normally thrown if damaged or charged heaps.... Most faults are alignment issue, faulty remanufacture cartridges or damaged fuser (hot bit) roller causing creasing..
Posted on Nov 07, 2009
Testimonial: "Good job, Thank you."
Hp 2600n line
after you have printed a few pages switch the machine off just as the paper leaves the fuser. then open the front cover and take a close look at the image transfer belt ( black plastic conveyor type belt)
use a torch shone accross the belt to better light the error- if you can see these Green/yellow/cyan lines on the belt then theres a good chance its coming from the toner units- ( also try print quality troubleshooting pages in the menus under diagnostics.look at the individual colour pages and look for any lines or Uneveness about the shaded colour) replace whichever toner is not printing correctly
Jan 22, 2014 | HP Color LaserJet 2600n Printer
I have hp color laser jet 2600n printer.. but after printing, there have line at the both side left and right on my paper.. the line is about 1cm .. how do i fix the problem.. tq..
If the lines are predominatly one color such as yellow or cyan then you likely have a bad cartridge. If you recently replaced a cartridge that is the one I would check first. You can also just look at the drum of each cartridge (the green roller under the shutter). If there is a problem it will usually show on the drum as well. Cartridges are the biggest issue with these printers, particularily the poor quality of cheap remanufactured cartridges coming from Asia.
Mar 16, 2011 | HP Color LaserJet 2600n Printer
I am getting a green/blue streak on my paper while printing. How do I get rid of that?
try to replace Blue cartridge whit new one
if the problem persist - replace one by one all other color cartridges
Be sure your transfer belt is OK too!
Apr 04, 2010 | HP Color LaserJet 2600n Printer
Vertical green line in papers
Your printer green cartridge drum cleaning blade is weak.you change it than solve it
May 30, 2009 | HP Color LaserJet 2600n Printer
Vertical line down left side of page aprox 2" from left side con
when I opened the front door to the cartridge compartement there was a green line of toner on the feed belt, I wiped it off. then I slightly closed the door to open the toner cartridges and found the one creating the mark and cleaned it.
no more line
Dec 27, 2008 | HP Color LaserJet 2600n Printer
Blue smudging down left side of the paper and paper turning greyish color
check the fixing unit if the adjustment for envelop is activated or not the same. set to normal.
Jul 11, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
128 people viewed this question
Seeker5211
Seeker5211
