Question about Sharp AQUOS LC-45D40U 45 in. LCD Television
My sharp tv displays 'please wait' but no picture. and my source input display menu will not come up. model sharp acquos 32 inch.
  • 405 Answers
You will have to replace DIGITAL PCB ASSEMBLY to correct the problem, I assume, that your TV is lc32d40u?
Posted on Nov 05, 2009
How do I change my resolution on my 32 inch flat screen from 480 to 720
Assuming your TV will support 720p signals, check how you have the TV connected to the Playstation 3. Change your video cable to component video or HDMI, depending on the TV. (The Composite input is limited to 480i (SD) pictures. The same is true for a SCART connection.) Put the TV to the new input by pressing the Input Source button on the TV Remote or through the menu depending on your TV.
You may have to do the first of these steps before changing your cables and the TV input source (I'm not sure). On the Playstation, select Settings and then Display Settings.Choose your video output (component or HDMI). Next select all resolution that the TV can use. (Most 32" TVs only do 720p. There are some that can do 1080i or 1080p.) Confirm the video connection works. Then Save your settings.
For screen captures of the steps, see: http://manuals.playstation.net/document/en/ps3/3_15/settings/videooutput.html . You should always turn off the TV and the Playstation before swapping the cables. (So you may need to stop and save after setting the output to component video. Then return to the Display Settings menu.)
I hope this helps.
Mar 14, 2013 | Televison & Video
Screen is completely black except for about 4 inches on top......
Try a reset of the display device or hit the menu button to get a display on the screen- If you get a full picture that way then you have some setting set wrong. It could also be a PIP- picture in picture mode that you only have one source put into the TV rather than two.
Aug 10, 2012 | Vizio SV320XVT 32 in. TV
My sharp aquos 32 in tv has sound but a black picture, what is the problem
Hi
Do you have no picture on all imputs i.e, tv or any AV inputs, can you get any on screen graphics from the menu system?, if not, it is possible the inverters( controlling the voltages to the screen) or a supply to the inverters has failed, either way the TV needs to be repaired. If you do get on screen graphics from the menu it would suggest that you have a external source problem either from you aerial (if you have no picture via the tv input) or a connection/syncing issue with an external source
regards
TechSupp82
Dec 11, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I'm trying to use my 6 yr old Sharp TV as a remote monitor for my MacBook laptop. The Sharp manual says that port 5 is the correct port for PC hook up. So, I'm hooking up the laptop's mini DVI port to the...
You need to set your MAC video resolution to the native resolution of this TV in PC mode, please read your manual to find out what that is, if the resolution is set too high, the TV will not be able to display it.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide">http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span>
Aug 27, 2010 | Sharp Aquos LC-32GD6U 32 in. HD-Ready LCD...
I have a Insignia 32 inch LCD TV Model number NS-LCD32. It recently started displaying no inputs. The backlight comes on but no inputs/ no sound. Green lines display if you press the menu,input, channel...
The first troubleshooting step would be to measure all the voltages from the power supply to the other circuits boards specially the 5 volts going to the main board. If you have the following: Insignia 6HA0112010 Power Supply, check FU502 for open conditions.
If all the voltages appear normal, then the main board should be replace since is hard to find individual components for a component level repair.
Let me know if you need further assistance.
Aug 21, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
The screen on my big screen is black it still works i can hear the tv but just cant see the pictures
If all the following apply to your set:
(1) Adjusting the brightness and seeing that video is present (just black)
(2) The TV's menu system is visible on screen even though no images are
(3) Your particular SHARP model supports picture in picture mode
Then I suspect that the problem is your TV's picture-in-picture sub-board. All external video sources & the internal tuners must pass through this board before being processed and displayed on the picture tube (even when PIP is not enabled). As far as I am aware SHARP does not provide this board as a spare part anymore, but they can be repaired at the component level if the failed component is a generally available device.
Regards
Jun 27, 2010 | Sharp 32C-240 32" TV
HDMI trouble: ''Your TV does not allow display of this program...
''Your TV does not allow display of this program through the DVI input source. Please choose another TV input source
whys it say that
Mar 19, 2010 | LG 32LG30 32 in. LCD HDTV
SAMSUNG 32 IN LCD LE32R73BDX (MASTER RESET)
* With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
* The TV will turn On with the Service Menu displayed.
go to reset
* Press the {POWER} button to exit the Service Menu.
Feb 22, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
No sound from tv
look for a hdmi input via the menu/ video /source button on the remote.[different manufactuers list them differently] if you have multiple input selections on the display,scroll thru each one,wait 2or3 seconds between each input and see if your picture comes on.also check the hdmi connection
wg
Feb 02, 2008 | Audio Players & Recorders
Sharp AQUOS LC-45D40U 45 in. LCD Television Logo
258 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
