Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Floormate stopped vacuming water
I purchased your first floormate vacuum 3-4 years ago, but one day after a wet wash it suddenly stopped vacuuming the water off my floor. I took it to a local Hoover store and the agent said the only thing he could think of was that the motor had lost power and couldn't create enough suction. So he sold me a new model. Now, 6 months later, *this* model has stopped sucking up the water. What's with this? Is there anything I can do?
  • 294 Answers
I'll answer last question first. Your floormate has a 1 year warranty. And should be taken in for repair.
Your issue of not picking up water, is related to suction and getting the dirty water to the recovery tank. check for obstruction in the nozzle, check the filter for debris clogging. If you have an issue with this dealer I would call customer support.
Posted on Oct 11, 2009
Wont turn on
this link is for the manual go to page 12 for troublshooting it could be seversl thing that are quite easy to check,
http://hoover.com/file/682/
Nov 25, 2012 | Hoover Floormate H3000 Upright Wet/Dry...
Can I use the Vacum cleaner for floors only without using the liquid. I do not want to wet the floors just sweep the dust away. I cannot find my manual.
first off your manual is right here....
http://www.hoover.com/pdfs/manuals/H3000.pdf
But more to answer your question, yes you can use it on the floor without the wet. You will want to turn your brush switch to the off position. Also, do not fill the water tank or press the spray lever for dry pick up only.
Hope this helps.
Nov 05, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate will not **** dirty water.
Check the hose coming out of the floor assembly. It tends to split, keeping it from picking up the water
Apr 20, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover FloorMate won't pick water up
Check for the filter in place and it also requires a filter lid for proper suction or it will not work
Jan 23, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
I own a RCA DVD recorder, having problems with the drawer/door opening
This is in the wrong area...you are writing this under the Hoover Floormate H3000 vacuum troubleshooting area
Aug 23, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate stopped sucking up water as well as it used to
Don't know how much dirt has accumulated in the recovery system, but mine was amazing for no more than we use it. The front of the head detaches and you can clearly see where the solution is being vacuumed into. A thin rectangular channel then carries the fluid to a corrugated hose in the back of the head. This channel accumulates a lot of junk too. By removing the recovery tank, you can see where the corrugated tube transfers fluid into another narrow channel which carries it vertically to the top of the recovery tank. The small section of hose seems to be the only thing that stays clean and doesn't limit flow and vacuum. The filter at the top of the tank, which keeps fluid out of the vacuum motor can also get plugged with dirt. Hope this helps.
Aug 16, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate not suctioning water back up
I love my floormate so muck that when my first one stopped vacuuming, I bought a new one - just figured it died. Then my new one worked well until one day, it suddenly stopped.
I discovered that the filter attachment holder (the clear plastic cover over the filter) has to click into place. I guess this might not be a problem for some, but I thought it just sat there over the filter. I finally pushed pretty hard (mostly in frustration at first) and it clicked into place. Now the suction works fine.
FWIW
Jul 11, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Brushes stop spinning after one minute
Check any filters that may be clogged, try running a mix of water and vinegar thru it, to clean out the lines and brush block. Brush block may be bad.
Apr 23, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate plus model #H3010
It seems to be a common problem with this series of floormate... some home quickfixes (a hassle, i kno) but put downward pressure while using the solution.... Check your warranty that came with it, and how long you purchased the floormate... Alot of vaccuums come with 30-90 warranties, I'd recommend having it checked out. That, or if u bought it recent enough,take it back... like i said, these models are unfortunately known to have this problem... Some people have ones that operate normally, but alot do not. >.<
Jan 09, 2008 | Hoover H3030 FloorMate SpinScrub 500...
My hoover floormate won;t suck/ suction anything!
Things to check: Check again that the pipes aren't clogged. Check all the way through from where the muck goes in to where it's supposed to end up, paying particular attention to places where the pipe narrows, goes round a bend, or changes material. Check the machine doesn't just need emptying. Wet/dry machines usually have some sort of float operated stop valve to stop you flooding the motor when you've filled it with water. Make sure this isn't stuck shut. Check everything from the impellor right back to where the muck goes in is airtight. It doesn't take a huge hole to lose you a lot of suction. Pay particular attention to places that are meant to come apart routinely, and places where hoses join to hard fittings. If in doubt, run the machine and listen for sucking noises. If there's a filter between the fan and the air outlet (there usually is) make sure it is clean Assuming the motor is running, check it is turning the fan impeller. Hopefully, one or other of these will get you somewhere. A.
Apr 06, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
602 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
