Question about Sony STR-DB940 Receiver
I have a sony str-db940, since it came back from being repaired, it reports 'not in use' when the 'sur' button is pressed and won't decode surround sound. Any ideas?
  • fraser143 Oct 21, 2009
    It turns out that the main DSP chip had become unsoldered, the guy who fixed it said that this is a fairly common problem, due to overheating - so I may fit a small heatsink to the DSP, or mount a fan that blows onto it.
    Just to clarify - the initial problem was the chip desoldering itself, the cause of the problem after it had come back was that there was a microscopic solder line between earth and the 'surround is on' pin of the chip. The nice chap fixed it for free and was rather embarrased...
    Scholar:
  • 94 Answers
Check if you're using the digital cables like optical cable to get the audio from the receiver. If yes, please select the Input mode to AUTO by pressing the mode button repeatedly. If you're using a analog cables, please try to change the sound field and check. Press the A.F.D button repeatedly to change the sound field and try. You can also try connecting a different audio source like Cable box, dvd player and check the issue.
If the issue persists, please reset the receiver. To reset the Receiver, turn OFF the unit and press n hold the MODE + button and Power button till S.F Initialize appears. If the issue still persists, you may be having 90 days warranty after the date of repair or original warranty which ever is longer. Contact sony to resolve the issue.
Posted on Sep 26, 2009
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
I've got a Sony STR-K880 Cinema surround system and the remote control won't work it anymore! The only thing it will do is turn the system off when I push the'AV I-O' button and the &#
I had the same problem. Found the fix in this document
STR-K880 service manual
On the amp, while powered off:
"While depressing the INPUT MODE button, press the POWER button to turn on the main power."
You may need to do this more than once.
This switches command mode between AV1 and AV2.
Jul 08, 2012 | Sony Audio Players & Recorders
Rear speakers L and R not working and MD in and out not working on my Sony STR-DB940
I'm guessing these are separate issues.
Has either one ever worked and stopped suddenly?
From the manual:
"No sound or only a very low level sound is heard from the rear speakers.
>>> Make sure the sound field function is on (press SOUND FIELD - MODE).
>>> Select a sound field containing the word "cinema" or "virtual" (see page 33-35).
>>> Adjust the speaker volume (see page 72).
>>> Make sure the rear speaker size parameter is set to either SMALL or LARGE (see page 20)."
Be advised that using any Tape Monitor loop (that's what the MD/DAT is) disables any digital sources. Not that that would explain the rear speaker failure. Analog sources can still be processed into various surround modes.
Any Tape Monitor use requires at least a live INPUT to hear anything.
May 29, 2010 | Sony STR-DB940 Receiver
Is it possible to setup lip-sync on the DB940?
no adjustments in that unit for timing
Nov 02, 2009 | Sony STR-DB940 Receiver
My surround rear spks dont work
The rear speaker decoding has to be enabled for them to function, regardless of the media. Enter the speaker setup menu and choose "yes" for the rear surround speaker decoding.
Mar 10, 2009 | Sony STR-DA3000ES Receiver
No sound from rear speakers during test tone usng Sony STR-DE475
I had this problem last night.
To solve it, you can reset the amp by:
1) Put the receiver on stand-by
2) Hold down "MODE" button and press on button
3) "S.F. CLR" appears in the display and surround is back on.
Good luck
Dr Gardner
Jan 21, 2009 | Sony STR-DE475 Receiver
Sony str-db940
Most likely a cold solder joint somewhere in the audio circuit. Most likely on the legs of the relay that turns the speakers on or off. Also check the connections at the audio outputs. Give it a good look over for bad solder connections, given the symptoms that's 98% likely to be the problem.
Oct 06, 2008 | Sony STR-DB940 Receiver
Sony amp str-db940 - protection
Somewhere in your speaker wiring, you have a shorted wire. This short can be as simple as a single strand of wire touching the other terminal on one of the speakers.
With a bright flashlight, look carefully at the back of the receiver and then the speakers for any loose strands.
May 27, 2008 | Sony STR-DB940 Receiver
Rear speakers not working
  • Try this on your rceiver to see if it corrects your problem .If not make sure rear speakers are activated and properly connected
  • Sound Field Clear Mode
    The preset sound field is cleared when this mode is activated. Use
    this mode before returning the product to clients upon completion
    of repair.
    Procedure:
    1. While depressing the [MODE +] button, press the power `/1
    button to turn on the main power. The message S.F Initialize
    appears and initialization is performed.
Dec 05, 2007 | Sony STR-DB940 Receiver
Sony STR-DB940 Receiver Logo
278 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
