Question about RCA Televison & Video
My RCA big screen TV picture now looks like 3D without the glasses. The picture also bows in at the top and bottom in the middle of the screen. What would cause this?
    Problem Solver:
  • 13 Answers
  • RCA Master
  • 5,138 Answers
Go to menu then setup if you donot see convergence on menu then you have a blowed Fuse FL231 it will be on Bottom board to left side onthe righht side of FBT flyback transfomer there is 3 of them in a roll small brwn rectangler looking caps But are fuses the one in the middle is it. Call Mats for fuse 1-800-628-1118
Posted on Sep 26, 2009
Picture is bowed inward and looks like a 3d image without the glasses. I also have a green, red, and blue line curving across the top of the picture.
Looks like the focusing lens may have moved a bit or the projector lamp has gone weak. Get a technician to check up the projector.
There's very little you can do here.
Mar 05, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA HD52W59 HDTV and my kids were watching the other day and all of a sudden the screen went bad. The sound is ok and you can still see the picture however it looks like your watching in 3D...
This is normally an easy fix. I've fixed several of these. When you get the back off of the set, there are 3 small square brown fuses located at the back left corner of the set, if looking at it from the back. They are located next to the right side of the flyback transformer( the large gray or black thing sticking up with the thick red wire coming out of the top). One of those fuses will be open and needs to be replaced, and the pins on the flyback transformer need to be resoldered on the bottom of the board. They will come loose and make the fuse blow. This will fix the problem 95% of the time on this set.
Sep 02, 2010 | RCA HD52W59 HDTV Projection Television
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Aug 30, 2009 | RCA P52926 52" Rear Projection Television
My picture looks like its in 3D
The convergence circuit is not working. It is way too difficult to fix by yourself but any-one who works on RCA TV's can fix this easily.
Mar 30, 2009 | RCA HD52W58 52" TV
Poor Picture on HD 52'' Projection RCA TV nearly 4 yrs old
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2009 | RCA HD52W66 Projection Television
Screen looks like its in 3d
LOOK FOR OPEN FUSE (CTM) BY IHVT, THE MIDDLE ONE.
Feb 20, 2009 | RCA P52937 52" Rear Projection Television
RCA Projection TV Model #p46921, Has bowing effect of pictures
Go to Menu then setup look for convergence if you do not see convergence on menu then you have a open FUSE FL231 it is on right side of FBT flyback transfomer there is 3 of them small brown rectrangler looking caps it will be the one in the Middle.
Jan 31, 2009 | RCA R52WH73 Projection Television
Picture looks like 3D without 3D glasses on???
The cost I don't know, but this can be fixed. I'd say shop around a bit. Make sure the repair person is certified for your TV's manufacturer. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Dec 30, 2008 | RCA HD52W59 HDTV Projection Television
RCA D52W23 breakdown in projection focus
First check capacitors cp150 2200uf 16v and cp114,cp120 220uf 35v If cp150 is puffed up on top it is bad , then there is a fuse FL231 on right side of flyback transfomer it will be the middle fuse if open you will lose convergence on picture .
Dec 30, 2008 | RCA D61W20 61" Rear Projection Television
Picture in 3d without the 3d glasses
Replace 2 convergence chips, will start with stk ###-###
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
208 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
