Question about GE JVM1441 Microwave Oven
My microwave does not heat anything. Turns on but food/water is remains cold. Problem started same time a low rattle noise started when turned on.
    President:
  • GE Master
  • 1,922 Answers
One of 3 things wrong 1( H.V. Diode bad 2)H.V. capacitor bad 3) Magnetron bad
Posted on Sep 26, 2009
Problem with KHMS1850S Stainless Steel 1000 Watts Microwave Oven
Possible that the Magnetron is powered off or is defective. You can check the main capacitor to the HT, check the leads, check the main board.
Also check the sensor which is mounted on the top or side of the cabin which is protector for overheat and can cut the voltage for safety.
If so also check the wave guides
Click on: Waveguides
Jan 30, 2013 | Microwave Ovens
Food does not heat
it sounds like your magnitron has gone its what heats the food up or it could be the high voltage transformer you will have to take it to a repair shop that deals with microwave as they give off alot of raidation and if any of the parts I mentioned are gone can be expensive might be cheaper to buy new one
Dec 12, 2011 | Microwave Ovens
We were using the microwave the other night and it started making a loud noise like the fan was running (although the fan was not). We let it sit for awhile and try to use it again but the noise came...
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
Mar 24, 2011 | Maytag MMV4205 Microwave Oven
Magic Chef MCO153UWF
Tin foil or steel plates in a microwave will burn it out. I suspect it is or has burnt out. Never put anything steel in a microwave.
Mar 12, 2017 | Magic Microwave Ovens
Turns on but not heating food sounds a bit louder
Hi, this is common in most microwaves. this abnormal noise is coming from a faulty Magnetron. this device is responsible for the heating process and, it is damaged and not heating at all at this point.Simply replace the Magnetron and, this unit will start to heat once more.
May 31, 2009 | GE Profile Spacemaker Over-the-Range...
Constant rattling noise during operation
possibly the "stirrer" motor - this is in the top and turns a metal reflecting ring to disperse the microwaves around the oven more evenly. About $70 on GE site for my oven.
Jun 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Works - but the sound has changed
Possibly, the "fault" was the buzzing in the first place! Buzzing is usually a cabinet vibration caused by magnetic fields from the "gubbins". If the buzzing should occur again, try pushing/ pulling/ poking the cabinet while the oven is running, you may find a position that causes the buzz to stop.
Another possibility is you previously had something else placed in close proximity to the oven.
If a rattling cabinet is the problem, either try to reposition something, or just ignore it!
Apr 29, 2008 | Maytag MMV4205 Microwave Oven
GE microwave oven groans then turns off
Can you give more details, such as when and how it "turns off" as well as the brand and model?
Happy to help.
Oct 22, 2007 | Microwave Ovens
GE JVM1441 Microwave Oven Logo
105 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
