Question about Garden
Having trouble re-stringing Ryobi 775r weedeater. Is .080 string to big?
SOURCE: ryobi weed trimmer
I have one of this trimmers. It is simple to replace the line.
-First line up the arrows on the bottom of the spindle.
-Then feed the line back in one of the holes in the side of the spindle (this is the same hole that the cutting string comes out of).
-You will see the line come out of the bottom of the spindle.
-Take that line a place it in the hole on the bottom of the spindle.
-Leave about 9 feet of string hanging out of the weed eater (do the same with the other side).
-Then turn the inside wheel (I can't remember if it is clock wise or counter clock-wise but it will only turn one way) most of the string is rolled into the spindle.
-Cut the string of about 5 inches out of the weed eater. You're ready to cut!
Posted on May 31, 2008
slohry
  • 87 Answers
SOURCE: How to adjust mix on WEEDEATER FEATHERLITE PLUS
Red=High speed and White = Low speed
Clockwise closes needle, Counter clockwise opens needle. Set both needle to 1 1/2 turns open, then fine tune from there.
Posted on Apr 10, 2009
  • 6 Answers
SOURCE: How do you reline a Ryobi es30
Here is a link to homelite and ryobi. but you will need trimmer # like ry30023 or something like that. it should be on the trimmer. when you find your trimmer look at the manuals.
https://www.gardnerinc.com/recons/disclaimer-lg.php
Hope this helps
Tobaz
Posted on Jun 17, 2009
  • 76 Answers
SOURCE: Starter string broke in Ryobi SS30 Ry30140.
Hi
please check this link its not the same model but it might help you
http://www.youtube.com/watch?v=AXW4xEwagso
Posted on Jul 16, 2009
AUTODOC01
  • 216 Answers
SOURCE: I need to know how to load a two string trimmer
most of these use 2 wires coming out of 2 holes on opposite sides roll the firstwire clockwise, then the 2nd counterclockwise so that when the spool turns the string comes out its not hard
Posted on Aug 25, 2009
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
Where can I get a parts breakdown ( exploded view ) for a Ryobi 775R 16" string trimmer.
here's the link. http://www.partstree.com/parts/?lc=mtd&mn=775r+41AD775A034
Mar 17, 2013 | Garden
My pull string wont move on my ryobi x430
Mine seized up and the string wouldn't pull because my girlfriend used it a few times without making sure that the oil was full. I filled the oil well with Marvel Mystery Oil and was able to slowly get the string to move. Eventually the motor became lubricated enough to pull the string with regularity and now the weedeater works perfectly.
Apr 06, 2012 | Garden
I can't get both sides of my weedeater restring right so it can pop out when i hit i t on the ground
Make sure you are winding the string in the correct direction. Check the spool for arrows, as centrifugal force is what feeds the string out the holes.
Aug 29, 2011 | Ryobi Garden
The spline for my Poulan TE475 WeedEater comes out during start up and wraps around the shaft. I use .080 round spline. It started recently to do this.
The string head on these units is very poorly designed. There is hardly anything in the head to retain the line. I suggest removing the stock string head and going to Home Depot and getting a replacement Universal type head or one for the Ryobi or Homelite They are basically interchangeable. Check the length available on the shaft end (threaded part) after removing the head.Use a large wrench or pliars to hold the dust cap when you unscrew the head. If you feel the driveshaft turning, don't continue turning head or you will break the flex driveshaft.
Jun 30, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I need to know how to load a two string trimmer head. This is on a ryobi weedeater model 700r, 31cc, 15 inch.
Aug 25, 2009 | Garden
Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
May 07, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Garden Logo
125 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
