Question about Jazz JDC31 Digital Camera
I keep getting an e53 on the screen - Jazz JDC31 Digital Camera
You need a 2gb memory card, Walmart has for 10 dollars
I had the same problem. i had bought a 4gb.
Posted on Jan 28, 2011
How do I correct an E53 error code?
I appreciate your post, Allan!
From my understanding your Frigidaire washer is displaying an error code of "E53". An "E53" stands for low voltage to the speed control board. This could be a possible problem with your wiring harness between the motor control board and speed control board or the speed control board. I would recommend resetting your washer in case it is a miscommunication issue. To reset your washer you would need to disconnect power from it for at least ten minutes. If that does not correct your problem you may need to have a professional technician out for proper diagnosis and repair. I hope this is helpful information. -Matt
Jun 11, 2015 | Frigidaire FAFS4272LW Affinity 3.81 Cu....
Is there a way to get the DC E53 camera to accept a larger SD card than the 512mb that it currently accepts?
The following link describes the maximum SD card size for your camera.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/BenQ/BenQ+DC+E53_Memory_Cards
The following is from their site:
BenQ DC E53 BenQ DC E53 Memory Cards (SD Card) & Accessories
The following digital camera memory cards are compatible with your BenQ DC E53. Every digital camera memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty.Your BenQ DC E53 accepts SD Card cards.The largest SD Card card you can use in your BenQ DC E53 is 2GB
So you can buy up to 2GB SD cards.
Jan 05, 2011 | BenQ DC E53 Digital Camera
What does E53 mean when memory card is in? how do i fix the problem?
The E53 error code generally refers to the recording media error.
Try using a different SD card with lesser capacity, like 256mb instead of maximum capacity Memory Stick.
Aug 24, 2010 | Cameras
I need a battery for it
Ebay is as good as any for this kind of supply.
Watch out for low battery price but artificially high shipping - you need to keep an eye on the total value of the order (which should be around $8 delivered, with a one year guarantee).
For example:
http://cgi.ebay.com/Battery-BenQ-DC-E43-E53-E53-E63-E720-C500-CAMERA-/320511141882?cmd=ViewItem&pt=Batteries_Chargers&hash=item4a9ff3e7fa
Apr 28, 2010 | BenQ DC C500 Digital Camera
Error Code E53
Brand new camera?...take it back.
Apr 13, 2010 | MGA Entertainment 366218 Digital Camera
Hello, I have a E53 2002 BMW X5, i cannot get the
hi Andrew, try to press the pairing button and keeps hold for 3 sec. then switch the ignition in first position while still holding the button for another 3 sec then the the pairing messeage should be sig on. but it the pairing messeage did not show i suspect that your ULF control unit is faulty and needs to be replace.
Jan 22, 2010 | 2002 BMW 5 Series
My digital concepts camera displays "E53"
try using a different sd card with smaller capacity, like 256mb instead of 2 gb
Feb 20, 2009 | Digital Concepts Digital Camera
Toshiba satellite pro 600 won't boot up
If you get this error in a black screen before windows xp can boot up....
CLIENT MAC ADDR: xxxxxxx GUID: xxxxxxxxxx
PXE-E53: no boot filename recived
PXE-MOF: exiting intel PXE Rom
Your network card's settings in bios have somehow been changed. PXE means Pre-Execution Enviroment. In other words, it allows your network card to connect to a network server to pull operating system images off the network and other files without having an operating system installed.
The Fix,
Go into BIOS press F2 or F12 whatever your PC's screen at bootup says. In Bios, reset your bios settings to the default bios settings, or original settings. If nothing else fixed it. Windows Recovery cd will not fix it, because you cannot boot windows if this error is still occuring, Your network card will keep prompting DHCP to search for a network. Its a bios function not a windows function. Reset your bios settings to the default.
Dec 16, 2008 | Toshiba Satellite Pro 6000 Notebook
Viewsonic E53 monitor
Base on the information given to me.
I think your computer is on sleeping mode.
first thing check if the video cable is not loose connecting the pc.
because what would happend, if it is loos it would turn on and off at times.
The other thing you can do.
right click on the desktop.
go to properties
go to screen saver
click on power
adjust the time you want your monitor to shut off.
Dec 06, 2007 | ViewSonic G90fb 19" CRT Monitor
Damaged Screen
Check the BenQ tech Support site for service links for Canada or U.S.
May 30, 2007 | BenQ DC E53 Digital Camera
Jazz JDC31 Digital Camera Logo
99 people viewed this question
Top Jazz Cameras Experts
Pavel Pranovich
Pavel Pranovich
Corey Fields
Corey Fields
Level 1 Expert
Are you a Jazz Camera Expert? Answer questions, earn points and help others
