I do not have a manual for my Fender deluxe reverb II. How can I get a copy?
  • feloniuspunk Sep 26, 2009
    The 'solution' you sent is not the right manual. You sent a manual for a 65 Fender deluxe reverb. The amp I have is an 83 Rivera era deluxe reverb II. It is substantially different from the regular deluxe reverb. The Rivera era model has a master and gain knob on channel two as well as a boost function and a presence control. It is hand wired. It was designed by Paul Rivera when he worked at Fender. I still need a manual for this amp. I already have a schematic but would like to get a copy of the original owner's manual for this model.
Yes, I also need a manual for my 1981 Fender Deluxe Reverb.
Hi there feloniuspunk. Please send me the Schematic that you have. Thanks. Email to: nilosantos49@yahoo.com
Posted on Mar 26, 2010
    Scholar:
  • 94 Answers
Please click on 'Download the complete
user guide (2645 Ko)
" on the right middle of the screen and complete the survey to download it .
http://safemanuals.com/user-guide-instructions-owner-manual/FENDER/65%20DELUXE%20REVERB-_M
Posted on Sep 26, 2009
I have a '93 Fender Blues deluxe tweed and don't seem to have any reverb, am I missing something?
Check the connection to the reverb tank (rectangular box usually sitting on the bottom of the amp). There are a pair wires that connect it to the amp. If wires are connected, and the reverb is not working, you may need to replace the reverb tank.
Oct 16, 2016 | Fender Music
Need a 1978 Fender Deluxe Reverb manual
Whats the model number?But still,the link below gets you to the full list of Fender available model manuals.Click on selection to download.
www.fender.com/support/articles.php?section=downloads&category=product-manuals
Hope this helps.Thanks!
Jan 07, 2012 | Fender Music
Sometimes the reverb works, then next day it dont.i have a 1999fender hot rod deluxe
Fender Amplifiers are notorious for their reliability issues.However, I'm sure that amp will sound sweet once you get everything working again!
The problem is likely your "tank". The tank contains the springs which create reverb as the guitar's signal is sent through them. A broken spring could be causing your problem.
Luckily, any of the larger music stores should have them avalible.
Good Luck!
-Sheeves
Mar 02, 2011 | Fender Hot Rod Deluxe Guitar Combo...
My reverb on my Fender deluxe Hot rod amp has stopped working. What is wrong?
Your reverb spring is most likely broken. If it has electronic reverb, then the chip has gone out. For both of these problems, a qualified amplifier technician will have to look at it and replace the parts.
Hope that helps!
Feb 13, 2011 | Fender Hot Rod Deluxe Guitar Combo...
My Fender Hot Rod Deville reverb is not working. What should I look for in trying to fix this problem
There are two coils in the reverb unit which use delicate wires which can break off - these can easily be checked, as follows:-
i) Remove one cable plug from the reverb unit & substitute an uncapped phono plug to the socket.Then check that there is electrical resistance across the plug terminals.
ii) Reconnect original phono plug & do same test as i) to the other socket.
iii) If either is open-circuited, then look for a break in the lead-out wires from the corresponding coil inside the reverb unit.
This break may be repaired (contact me for details) or buy a new reverb unit!
iv) If there is electrical resistance at both sockets of reverb unit, then clean both original phono plugs & try the system again.
Sep 15, 2010 | Fender Hot Rod Deluxe Guitar Combo...
How do i connect the boss gt 10 to a fender blues deluxe amp and bypass the amps preamp
You can plug the output of the gt10 into the "power amp in" jack of the Fender. This bypasses the preamps in the Fender but uses a buffer amps in the Fender to drive the power amp. Please note that the reverb is STILL in the circuit when you do this. You can turn the reverb to zero if you wish to disable it.
Jun 09, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Fix Reverb unit on Fender Hot-Rod Deluxe Amp
Could have broken a spring in the reverb tank, or a wire connecting it to the amp, or the reverb driver tube, or a few other things, but those are the most likely in this situation. Thats what I'd check first. Give it a little slap and if it vibrates like normal, your spring is probably ok, you can still open it up and double check though. Check your wires. Then pull your reverb driver tube and replace it. If that doesn't work, it is probably in the circuit somewhere, and you should not work on your amp unless you know what you are doing. They store large amounts of electicity in the caps and they can kill you.
Apr 24, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Hot Rod Deville, reverb squeal...
Here is an article that might help:http://www.guitarplayer.com/article/reverb-troubleshooting/jun-09/97165 Here is the schematic:http://www.fender.com/support/amp_schematics/pdfs/Hot_Rod_DeVille_Schematic.pdf Check to see if someone hasn't reversed the input and output cables at the reverb tank. Then troubleshoot the reverb section .
Aug 28, 2009 | Fender Hot Rod Deluxe Guitar Combo...
I have a Fender Hot Rod Deluxe. It has very few
First try turning the volume control down before turning switch to operate.
IF this seems to fix it, IF the unit has a tank reverb, the vibration of the reverb springs MAY be causing the problem. The solution then is to reduce the volume before applying power WHICH is a good idea anyway... from an electrical engineer.
Jul 24, 2009 | Fender Hot Rod Deluxe Guitar Combo...
205 people viewed this question
 Grubhead
Grubhead
