Question about Radio Flyer Toys
Repace handle on rocking horse - Radio Flyer Toys
Can rocking horses be made from material or does it have to be wood?
Traditional rocking horses are made from wood but nowadays you can buy them in colorful plastic and soft fluffy material, so it really depends what kind you like.
Go to a really big department store and check out their selection or you could just look online at Toys'rus to get some ideas.
Jan 14, 2013 | Toys
Are rocking horses safe to buy as toys?
Rocking horses have a bit of a reputation for being dangerous because of a few accidents involving the reins around the rocking horse. You do really have to be careful not to leave young children unattended.
And you can shorten the reins on the horse so that there's no danger of strangulation.
when kids go too fast on a rocking horse they can cause it to tip over but this is true of nearly all motion type toys.
i still think the rocking horse is a classic but you should be careful to supervise kids who are using it.
Jan 14, 2013 | Toys
I did not receive a solution to my problem
How many days have you had the baby? If he is dreaming of a rocking horse he won't give a dailey bonus until you build the rocking horse. You can tell if he is dreaming about it by looking at his thought bubbles when they pop up. Also I was having a problem with the baby and tried reseting my game and nothing would work. A little after 24 hours everything returned to normal. If all else fails give it 24 hours and these things work themselves out a lot. I don't think you can get rid of the baby until the quest is finished which requires building a bed, rocking horse and baby pool etc. It is ongoing for quite awhile.
Aug 28, 2012 | wooga - world of gaming Monster World
Rocking horse replace band
I'm from Brazil, so a have a toda's kids rocking horse end a need those four rubber bands. How can I buy these replacement rubbers?
Feb 01, 2012 | Giddy Up Rocking Horse
How to fix door handle on chevrolet cobalt 2008
Have to remove inner door panel and is usually 2 bolts around 10mm that hold handle in, but the rods must be removed first and these rods are only held in place by a spring steel clip that just flips out off the rod at the handle end.
To remove door panel - look for visible screws under and around the edges and or handles, remove all these. If window is winding type a horse-shoe clip holds the handle on and can be pushed off with a screw-driver if you push the panel away from handle and look behind the handle.
Then take a putty knife and or butter knives and insert between door and panel to pop plastic clips from door then lift on panel to remove from window jam.  Be careful of wires and plugs after this.  Remove plug clips and place panel aside.  Remove plastic and sound-proofing if any in the corner near the handle and a 10mm 1/4" drive ratchet to remove bolts on each side of handle.
This is a general answer but should work for the Cobalt as well.
East Coast Canada Rocks!!
Jun 09, 2010 | 2008 Chevrolet Cobalt
Where can I get Rocking Horse poo??
Hi Jan,
After checking the resources of three states in the Pacific Northwest, the same answer kept coming up. It may require some patience though.
Survey says:
The South end of a Rocking Horse that's facing North.
Best regards
Mike
May 11, 2010 | 2007 Rolls Royce Rolls Royce Corniche
I have a Troy-Bilt PTO Horse (Horse III) 8HP TINES
The tines are very close to the housing and sometimes you do get rocks hitting,as for the dirt it should have side panels to keep the dirt in place.
May 07, 2009 | Garden
Toys Logo
354 people viewed this question
Top Radio Flyer Toys Experts
Tom Chichester
ray gallant
Are you a Radio Flyer Toy Expert? Answer questions, earn points and help others
