Question about Remington Precision Deluxe PG-200 Beard Trimmer
Remington pg-200 shaver won't charge. the charger base seems to be working and the red light comes on when plugged in. the green light signifying that the shaver is charged never comes on and there is no power at all from shaver. i can't figure out how to take the shaver apart either.
SOURCE: Reg Remington Model PG-250
Send back to manufacture. I have 2 and i had to call remington to order the replacement microsreen. very hard item to find replacent parts for
Posted on Feb 26, 2008
SOURCE: Remington es1000
The Remington ES-1000 was probably the best slot-head shaver ever made by Remington. I cannot believe that the market demand was so low as to prompt a cancellation of production. I believe that the production run was limited to about 4 years or so. I have 8 of these shavers and keep a couple old Remington slot heads around as well. The ES-1000 was not perfect. The batteries were way too small and stressed so battery life was poor.You could not buy individual blades as you could with past Remington slot-head units.Also, the edge of the head was too exposed and sharp and when used for body shaving would tend to cut the skin.Slot-head shavers are superior for body shaving and for skin that is suseptible to shaving bumps.They are also great for young men that are prone to ingrown hairs.My guess is that the Norelco 3 head has taken it's place. Those shavers actually use 3 small slot heads. Rumor has it that shavers.com is trying to have a new slot head manufactured in Asia.
Posted on Mar 02, 2008
SOURCE: Remington MS2-250 shaver disassembly?
This shaver was pretty clearly not designed for battery replacement. To open, first remove the screen and blades, and unhook the metal collar from the tab on the back of the case. Then carefully pry off the black inset on the front of the shaver. Underneath it, near the bottom are two screws. Remove these. The case is now only held together by several plastic latches, which can be carefully pried apart with a small screwdriver. The two 2/3A size batteries are soldered to the printed circuit board, which can be pulled out (don't break the wires to the motor) by a little wiggling. The original batteries in mine are 1100mAh, and I have just ordered 1600mAh replacements. The new ones don't have tabs - so soldering them in place is probably going to be a challenge.
Good luck.
Posted on Dec 28, 2008
SOURCE: Where to buy a new charger
http://www.remington-store.com/product_detail.asp?CAT=parts&SKW=remcord&T1=REM+72150
Posted on Apr 08, 2009
brector3
  • 1610 Answers
SOURCE: It won't charge. it lights up but does not turn
It probably needs new batteries. You will find the batteries at shaveroutlet.com. See link below. You will need to order two batteries.
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
Replacement instructions:
Remove the two screws on the back to remove the back cover. Unsolder the wires connected to the batteries and solder in the new batteries the same way you take out the old ones
Posted on Mar 27, 2010
Charger cable for remmington pg-400
You will find the charger at shaveroutlet.com using the link below
http://shaveroutlet.com/remington-charging-cord-for-pg-250-and-wpg-250.html
Jun 22, 2014 | Remington High Precision PG400 7in1...
Not able to switch ON
This model is several years old...probably about 7 years old and the battery is probably dead from age. The easiest fix is to purchase one of the items linked below from shaveroutlet.com
http://shaveroutlet.com/remington-ms2370-lower-unit-p-208.html
http://shaveroutlet.com/remington-ms2100-lower-unit-p-209.html
May 28, 2010 | Remington MS2-200 Electric Shaver
Just bought braun 8585 electric shaver, return it to the store as nothing happens while charging. Got a new one and still not able to charge it, shouldn't the indicator turn red or green? nothing happens....
Did you insert a cartridge into the cleaning base? It needs that in order to work. Otherwise, try plugging the charger directly into the shaver. It should definitely charge the shaver, as long as the shaver is fine. Depending on the model, the charging indicator may be green or blue.
Jun 03, 2009 | Braun 8585 Electric Shaver
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Remington Precision Deluxe PG-200 Beard Trimmer Logo
274 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
