Question about Epson Stylus RX690 InkJet Printer
Waste ink error
Waste ink pad in the printer is saturated ....on LCD and the led blinking...
  • 4,041 Answers
Hi there you can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Posted on Apr 25, 2010
Epson cx9400fax error waste ink is saturated
Get the User Guide from the Epson site for your printer. If that doesn't tell you what to do go back to the site and ask the question.
Oct 16, 2014 | EPSON Stylus CX9400Fax Series
EPSON R545 waste ink saturated
You need to reset your printer. Goolgle search for "indoreset for rx595" and download it. That is the program you need to use to reset the waste ink pad counter back to zero.
Jul 20, 2010 | Epson Office Equipment & Supplies
What does it mean when the power light and the printer light are blinking on an Epson c60 model?
If all the Led's/Light's are blinking/flashing on an Epson Printer, that indicates "Maintenance Request Error". The maintenance request error is actually a "Waste Ink Pad Overflow Error". Normally your remedy is to replace the Waste Ink Pads with a new ones and then reset the INTERNAL WASTE INK PAD COUNTER...The need to replace the waste ink pads is measured by the amount of ink uses, which is determined based on the number of Head Drive Pulses, accumulated in the waste ink counter. When the total quantity of ink deposited onto the waste ink pads, during cleaning and flushing, reaches the set limit, the printer generates a maintenance request error and stops printing. If you just reset the counter and don't replace the pads, then your printers old pads will eventually overflow and normally start leaking ink out the bottom of your printer.I know this information is not much help, but at least you will know what your ERROR is.
Feb 26, 2010 | Office Equipment & Supplies
Waste ink absorber needs emptying- what do I do?
This advice is for a Canon IP3000 printer.
The waste ink absorber consists of several sponge pads, two of which run almost the full length of your printer underneath your printer. When a cartridge is cleaned, a small amount of ink is forced through the print head to remove the blockage. This waste ink then goes through two small tubes to the waste pads below. Over time these waste pads become saturated with ink. It is usually the case, that by the time the waste pads become saturated, your printer is well past its warranty period.
Ironically, you don't need to use this method to clean your print head on this printer, as it is easily removable. On most printers including some other models of canon printers the print head is not removable, so you have no choice but to waste ink. With the Canon IP3000, remove your print head out, put it in a container of hot (but not boiling water) and ideally leave it for a couple of hours and usually this cleans it effectively. I usually put into the hot water, some ink jet cleaning fluid. (The purple fluid that comes with refill kits.)
From your question, it sounds as if it is too late for this. so you have two choices. First, you can try resetting the waste counter; if successful this may mean that you can carry on using your printer. However, this is only a short term measure. If your waste pads are saturated they will need removed, replaced or cleaned.
This is how you can reset your printers' waste counter:
1.With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. (DO NOT release the buttons. The LED light should be green to indicate that a function is selectable.).
2.While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.).
3.While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
4.When the LED light is green, press the Resume/Cancel button 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
5.Press the Power button. The LED lights in green, and the reset is performed. (When the operation completes, the printer returns to the menu selection mode automatically.).
6.Press the power button to exit service mode.
Note: if you accidentally press the Resume/Cancel button more than 4 times in step 4 then just press the Resume/Cancel button at least 10 times and the printer will be returned to step 4 automatically
This may allow you to continue to use your printer. However, please be warned, if left unchecked, you could end up with waste ink spilling out of your printer.
Second you can dismantle your printer, remove and clean the pads, and you may also have to reset the waste counter. This web site outlines the steps on how to do this: http://www.druckerchannel.de/artikel.php?ID=1831&seite=6&t=step_1_removing_the_printers_sides
Finally if all this, brings you out in a cold sweat, perhaps it’s time to invest in a new printer. The Canon IP4600 is the modern descendant of the IP3000, with a removable print head and separate inks. It’s quite expensive but it’s worth the extra for reliability and quality.
Hope this helps. I wish you well.
Jul 31, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Printer blinks alternate red and yellow lights, error in commun
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C43 Service Manual". You will often find them for sale very cheaply on E-Bay. Note, however, if you can find or borrow any of the C40, 41, 42, 43,or 44 service manuals, as far as ink pad replacement goes, they are the same.
Please don't hesitate to report back if you have any other queries.
Jan 26, 2009 | Epson Stylus C43SX InkJet Printer
Red & Green led is blinking continiously after carriage initial.
The Waste Ink Pads are deemed to be saturated and should be replaced. You can overcome this problem temporarily bu using the SSC utility - download from
and reset the Protection Counter. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C46 Service Manual.
Jan 09, 2009 | Epson Stylus C46 InkJet Printer
Printer showing error
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. This is quite straightforward once you know what to do.
If you decide to have a go at replacing the ink pads yourself, post a new comment, and I will provide further help.
Dec 08, 2008 | Epson Stylus C40UX InkJet Printer
Epson R230 ink & Paper Lamp Blinking
my epson stylus photo R230 Printer problems always
two red light blinking
please help me
thank you
Sep 29, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson stylus c45 (Problem)
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C45 Service Manual". You will often find them
Jun 14, 2008 | Epson Stylus C46 InkJet Printer
Epson Stylus RX690 InkJet Printer Logo
143 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
