Question about Tricity Bendix TM220W Electric Dryer
My drum is hard 2 spin by hand - Tricity Bendix TM220W Electric Dryer
  • Tricity Bendix Master
  • 2,605 Answers
You sholud let the motor do that.
just kidding. several possibilities with those bendix/equator/slendid/kariba etc.. the most common being a garment jammed between the inner and outer basket/tub. recently wash a pillow, or floor rug ? did they come apart ? they usually do if a "no spin" is not selected. do you hear anything scraping ? I digress. these machines have poor access from the front, and unfortunately not great from the rear either. I'll give you some tips if you feel you can follow great, lets do this.(if not call a tech.)
1) unplug the machine from the ac outlet. there should be a small door on the left hand bottom in the front of the unit.(your model maynot have a little cover/door but just the insert/filter in plain view). open it, you'll see the pump "insert" or filter and some even call it a "pincatcher". unscrew it ccw (counter clock wise) drain any water out of the pump. use a light and inspect inside the pump, especially the bellows which goes up to the basket/tub. see anything that could be jammed, i.e. nylons, socks or any other garments obstructions ? if not, you'll have to move onto the next step.
2) you might want to remove the fill & drain hoses, this will free up some space behind the unit, it's pretty crampy at best of times.
3) remove the rear access panel, (careful panel edges are sharp) this will expose the pulley, belt etc. does it look like it's been leaking out the back wall were the tub bearing is located ? if yes, major repairs required, call a tech. if no, awesome. let's move on.
now, spin off the belt, don't pinch your fingers...again make sure it's unplugged please. (if you've ever put a bike chain back on you can do this).give it a turn on the pulley while applying some pressure pulling the belt towards you, the belt should "turn off", now spin the pulley without the belt on. still tight? no ? how about giving the motor shaft a spin, is it tight ? if so it's either toast (bearings) or you need brushes (as long as the stator isn't damaged too badly) if it's spinning freely, great.
ok. now, having checked those things and ruled them out. get yourself a trouble light or good flashlight for this next step.
4) from the back looking towards the front, at the bottom of the tub you'll see a rubber bellows going between the tub and the drain pump. remove the bellows from the tub end, look in the bellows for clothing etc. if nothing try this. hold your hand or a couple of fingers inside the tub hole from where you removed the bellows, unless you can see clearly with the light shinning into the hole. "slowly" spin the tub (sharp edges again, be careful. and this may require another hand) see anything jammed inside ?
That's really all you / I can do for now in my opinion.
These washer dryer combo's also have a heater/blower housing up top that can become clogged with lint, especially the blower wheel, but that is usually a "clothes not drying" complaint. I guess in extreme cases, it could be clogged so much it's rubbing against the drum thru that opening, this would require removing the complete heater housing and physically cleaning it out though. there isn't much room in there either, careful not to damage the timer, switches, wire connections, etc. (you'll see what I mean by removing the top)
hope that helps
good luck.
Posted on Sep 26, 2009
  • 7,482 Answers
Your problem could be the belt has slipped off the pulley or idle arm.
Or your drum rollers need lube or replacement
My Duet Washer is making loud noise during spin cycle and has plastic shavings, from front tub rubbing i assume.
Hi, it could be your drum bearings are gone the drum would wobble slightly. A way of checking is , machine unplugged put one hand at bottom front and one hand at top front edge and push up and down if it clunks quite badly then your bearings on the drum shaft are needing renewed. You also have a shock absorber for steading the drum this can also fail. The absorber is very hard to compress so if its easy to compress then it needs re-newed.
Dec 29, 2015 | Washing Machines
Kenmore oasis washer noisy when spinning
Hi, your probably right about the bearing its usually hard to tell untill they have compltely gone have you tried turning the drum by hand to see if it turns smoothly if it does then it could be the motor thats noisy both can be replaced but the drum bearing is a nighmare trust me you need pullers and its hard work.
So try turning the drum by hand and see if you can feel any roughness or catching this would tell you if the drum bearing has gone.
Let me know the outcome ok
May 01, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
The motor on the Maytag Neptune MDE7550 Dryer is very hard to spin by hand. Is this normal.
You should not need to spin the motor by hand. Check if the belt is not to tight or the motor itself could be defective.
Apr 15, 2008 | Dryers
Drum turn left side easy by but right side hard
A Quick and Easy Fix for Whirlpool Washer Brake Lockup
www.davesrepair.com/DIYhelp/DIYddbrakelube.htm
The symptom of what I call 'spin brake lockup' is the washer's basket stopping ... of this article for help) and you'll see the chrome clutch drum, right above the transmission. ... It would be very hard to put grease on the clutch linings inside the lower clutch drum, but I mention ... Please click the "donate" button on the left side of
Washer Agitator/spinner Turns One Way, But Not The Other ...
www.diychatroom.com/.../washer-agitator-spinner-turns-one-way-but-no...
Jan 9, 2009 - 6 posts - ‎2 authors
It agitates just fine, but when the direction switches to spin the drum, it almost feels.... That will make it easier to remove the belts and turn the drive pulley. ... find that the drive pulley won't turn anymore, or will be very hard to turn. ... on the left side or the hose going to the air pressure switch on the right side.
Nov 15, 2015 | LG Washing Machines
Very hard to spin, even with tuning with your hand
More than likely the drum bearing has siezed.
Nov 15, 2013 | Samsung Dryers
I bought an estate dryer by whirlpool second hand. its less than a year old. first load dyied just fine then put the second load in and it was just humming when i hit the start switch. it would start if i...
Verify the dryer's age here: http://www.appliance411.com/service/date-code.php
Was the drum hard to spin? You should be able to spin a drum with one hand. If not, the drum may be binding due to a roller/glide problem or a bad bearing. The drum may have been knocked out of alignment when the dryer was moved.
If the drum moved easily, the motor's start windings may be bad. The motor is about $80 at repairclinic.com.
Mar 03, 2011 | Estate Dryers
We have a MMDE9206AYM model dryer that makes a low humming sound but will not start. Last night it also produced a burning smell. I assume either the belt is gone or the motor is overheating although it...
Sounds like drum is locked and motor is running and burned the belt. Try to spin drum by hand, Might check drum ends felt seals, Teflon bearing strips located on the bottom lip of front drum end for wear causing drag. Also check 2 drum support wheels to see if they spin freely, take the belt off motor pulley and spin drum by hand, if easier & motor runs drum is dragging. How is the spring on tensioner, does tensioner pulley spin free? Hope this helps locate the problem.
Feb 13, 2011 | Maytag Dryers
How do I remove rear brake drums on 2002 toyota camry
first remove the wheel and this will expose the brake drum. next make sure emergency brake is off. spin drum by hand, if it spins freely you can use a heavy hammer and give it a hard whack and drum should pop loose, if not remove the drum by inserting two bolts into the threaded holes on the drum face and continue driving the two bolts forward evenly which in turn walks drum off. if this was helpful please rate 4 thumbs.
Jan 15, 2011 | 2002 Toyota Camry
Dryer motor just hums, doesn't spin, kenmore front loading dryer
Try turning the drum by hand with the unit turned off. If it seems fairly easy to turn, then check the motor to see if it has a capacitor (about 2 to 3 inches long and 1 inch in diameter with two connections).This capacitor is used by the motor for starting. Replace the capacitor. If the drum is very hard to turn, something may be jamming the drum or the motor bearings may be frozen (new motor). Hope this helps.
Sep 26, 2009 | Dryers
Help please
You may have to replace the drum guides. Reach into empty drum (tumbler) and push up on the top of the drum gently. If it has a travel space of more than 1/4 to 1/2 inch the guides needs to be replaced.
May 19, 2008 | Whirlpool LER7646E Dryer
Tricity Bendix TM220W Electric Dryer Logo
151 people viewed this question
Top Tricity Bendix Dryers Experts
Tim Whalen
TO Lady
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
