Question about Toro Lawn Mower With Toro Power Tools
Brand New, Will not Start
Brand New Mower, after putting oil and gas in it, and followed manual instructions to start, it will not start.
  • 437 Answers
Carburetor may need to be cleaned out, sounds like the jet is clogged.
Posted on Sep 26, 2009
Brand new Echo gt-225 trimmer wont start. What could be the issue?
brand new did you put gas oil mix in it?? did you follow the exact starting instructions on it? newer one seem to need to bne primed like 10 times and the throttle held open when pulling the starter rope. choke on??
Jun 25, 2017 | Echo Garden
Lawn mower instructions why wont it work
check for spark at plug if spark at plug then squirt some starting starting fluid in carb see if will start it should run long enough to burn out starting fluid if does check for water in gas if is drain tank and carb bowl put in fresh gas not and repeat not old gas you were using strat lawn mower if still dosnt start rebuild carb and add and additive called seafoam to the gas this is good stuff follow instrution on bottle
Sep 02, 2014 | Garden
Why won't my brand new Honda mower start
Take it back for a warranty fix as it is defective from the factory. Do not make any adjustments yourself as they will claim unauthorised work and may not repair under warranty.
Apr 24, 2013 | Gcv160 Gas Engine
Brand new Blue Max 20" chain saw wont start, has fresh gas/oil mixed @ 25:1
I also have a BlueMax 45cc chainsaw that I could not start right out of the box. I got lucky a couple of times after many (20 or 30 pulls) but normally I just gave up. Many others online seem to be having this problem with this chainsaw.
It turns out the solution for me was that the starting instructions in the manual are not really complete, there is another step that aids in starting: it needs some throttle. The chainsaw does not like to start with power at idle. After setting the switch to on and setting the choke, as the manual says, before attempting to start, squeeze the throttle while pressing the side button to lock it. For me, this allowed it to FINALLY start with only a few pulls. I learned this when I ran across this video:
How to start BlueMax Chainsaw 45CC
Hope this helps anyone else who runs into this.
Nov 03, 2012 | BLUE MAX Garden
Brand new mower died after first start
recheck your fluid levels make sure the spark plug wire is on also is the fuel your using 30 days or newer old gas doe not burn very well in small engines
Jun 14, 2012 | Garden
I bought a brand new Troy-bilt lawn mower model 336077 and tried to start it by pulling on the started string after filling gas and oil. But the cord is stuck and the mower does not start. WHat coul be the...
Are you holding the emergency stop lever? If you were operating the mower with your hands on the handle, there is a separate lever that you are expected to hold together with the main handle. You have to hold these two handles together to start and to operate the mower. Good luck.
May 31, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I have a brand new TB250 21" self propelled mower with the Honda engine. I put it together, added oil, added gas, and when I go to start it it does not start. The issue is that I cant seem to get the...
Hi jb--
Since you have already added oil and gas, and this is a new mower, see if you can locate the 'dead man' switch on the mower. There should be a handle on the mower that must be held down when you try to start the mower. It will follow the shape of the larger handles, just about a third of the size: you can see it in the picture you used for this post. Attached to it is usually a cable that actuates a braking mechanism that will stop the mower's flywheel from turning. This handle will swing down against the handlebars of your mower before and then during normal operation. Try holding this safety down and try to pull again.
--Hope this helps.
Oct 08, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Brand new 550! push red pump button 3-4 times... pull handle..mower starts up then dies. Will not continue to run..
Sounds like wet fuel! The priming puts enough gas in to start it but the running circuit does not.
Check your gas can for a layer of water on the bottom of it. If it has a lot of water in it you should dispose of this fuel at a gas station that collects used oil and gas. Drain the mower and take that gas away too.
Put in fresh gas from a known clean and dry source.
Let me know what you find ok?
Good luck and be careful!
Jun 29, 2010 | Craftsman 550 Torque 22 in Deck 2n1 Side...
My brand new Briggs and Stratton Lawnboy won't start!!!
if you play with it u will void the warrantee. call the dealer u got it from
Apr 02, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Toro Lawn Mower With Toro Power Tools Logo
90 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
