Question about Goodmans CD / MP3 car radio GCE780MPT CD Player
Goomans car cd player
Hi ones more ! what can i do about my cd player ,cant get cd inside the player ? and if i push a little error code 7 ?
  • hansvil Sep 27, 2009
    Thank you!
    President:
  • 1,462 Answers
Error 7 indicates that the disc is not good.
Try
1.is the disc free from scratches, dust or fingerprints?
2. Is it the correct way up in the tray?
3. Does your CD Player support the type of disc you're trying to play? eg: MP3 Check the instruction manual supplied with your product.
4. Try other discs to see if the problem is with that disc.
5. Clean the disc with mild detergent and water. Dry the disc thoroughly with a lint free cloth and retry...
Please leave me comment, if you need furthur assistanve
RNJ VINODKUMAR
Posted on Sep 26, 2009
Recently the CD player stopped working with a cd inside it says error 1/error 2 after it trys to load it also won't eject the cd at the same time this started the usb also stopped charging my devices
Try to put another cd in on top of the stuck one . don't force it , just push in a little ways then pull it out . Sometimes that will make player eject the stuck one. I would take it back to whoever installed the radio.
Dec 05, 2015 | Cars & Trucks
2004 lexus RX330. CD player has 6 cd's in it. Has one cd in it. Will not play or eject. Error 4
Something inside the cd player has broken and can most likely be sent off for repair but I don't know how much that would cost, but a new one can range anywhere from $500-$1,000.
Aug 10, 2012 | 2004 Lexus RX 330
I have a 2005 chevorlet aveo my cd player reads error 7 when i put a disc in. how do i fix that?
error 7 is The disc is not in the tray correctly. so it sounds like your cd player is starting to die. and its about the same price to fix it as it would be to buy an aftermarket. but if cant afford a new one taking the radio out and pulling the power cord on it to reset it works sometimes. (caution your radio might have a thief protect on it causing to lock when unpluged. if its does you will need the code for it)
Dec 24, 2010 | 2005 Chevrolet Aveo
I hav a clarion auto cd/stereo displaying err 6 please explain, thank you
Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
For error code 6:
Try an original purchased cd with no scratches and see if the cd player reads it. If yes then lens is dirty or tired so try using a cleaning cd(has little brushes on it). If it doesn't read with the original cd try using the cleaning cd and if no go then look at purchasing a new cd player!
Nov 01, 2010 | Car Audio & Video
Hi there, is there a way to get my goodmans ghc58 surround sound system to play through my virgin + box? I cant seem to find an optical input/output from the surround sound but i do have a goodmans dvd...
There is an optical output from your Virgin + box but there is no optical input in the Goomans, there is only 5.1 input. The only way to do it is to connect the re and white phono audio output from you virgin box to the red and white tv inputs on the goodmans, this will sound good but it will not give you dolby digital sound.
Dan
Nov 28, 2009 | Audio Players & Recorders
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
My clarian car stero will play the cd player while
It sounds as if the power leads are not connected properly.
Make sure the memory lead is connected to a constant 12+ volt source, and the switched lead is connected to a 12+ volt power source that is controlled by your ignition switch.
Aduz
Feb 24, 2009 | Car Audio & Video
CD stuck inside the player
hi leigh
im dave
most car stereos have an emergency release. look for a hole somewhere under the cd intake (it could be anywhere) and using a paperclip push the gear mechanism forward. it might be a little hard to do but your cd should pop out
Jul 17, 2008 | Volkswagen New Beetle Cars & Trucks
Release cd
Your CD reader must be damaged. You will have to manually take the CD player out of the cradle, and take it apart. This should be easy. Once you have the top off the CD player remove your CD and put it all back together again. You can by lens cleaning CD's from walmart, K-mart..any mart. Run that through and see if it helps. Once CD player is back in the car, hit eject to make sure the player knows it has no CD in it anymore.
Jun 10, 2008 | Audiovox ACD-24 CD Player
Cd stuck in player not ejecting or accepting other cds
hi you nhave a faulty u8nit. there is a repair kit, but its not easy to fit, please see: http://carradiospares.co.uk/repair-8619001490-p-256.html
Mark
Jun 07, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Goodmans CD / MP3 car radio GCE780MPT CD Player Logo
61 people viewed this question
Top Goodmans Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
rpar
Are you a Goodmans Car Audio and Video Expert? Answer questions, earn points and help others
