Question about Liberty Hardware Bath Unlimited Alexandria Rubbed Bronze & Ceramic Soap Dish
The ceramic ball on the end of the broze rubbed broke.
The ceramic ball on the end of the broze rubbed towel rack broke and I am looking for a replacement. It is about 3 years old. Where can I get the replacement ball?
I have a spare, if you're still looking for it...masterfool@att.net
Posted on Jun 21, 2011
I'm trying to install a Glacier Bay ceramic towel rack but the instructions are worthless. How does the metal mounting bracket attach to the wall? Does the indented part screw in and and the c
The indented bracket is attached to the wall with screws but should be left loose enogh to allow the ceramic part to slide down over it and seat.
Oct 05, 2014 | Home
Power steering fluid leaking 89 buick park avenue
look for loose hoses just tighten down
look for cracked hoses they could be spraying fluid when under pressure.
The rack is sealed with boots on each end where the tie rods come out.
they crack or could be rubbing on something.
Mar 06, 2013 | Cars & Trucks
Have anyone out there ever change inner tie rods on a1995 honda odyssey?,if so simply explain,THANKS
Procedure on replacing the inner tie rod ends:
1) Raise and safely support the vehicle.
2) Remove the front wheel/tire assembly.
3) Clean the steering rod between the steering boot and outer tie rod end lock nut with a suitable penetrating lubricant and a clean cloth or shop towel.
4) Loosen the outer tie rod end locking nut 1/8 turn.
5) Loosen the steering boot clamp(s), and slide the small clamp off the boot.
6) Carefully loosen the boot and slide outward off the steering rack and onto the shaft to expose the inner steering rod mounting fastener.
7) If necessary, position the inner steering rack shaft in or out to allow for additional access.
8) Relieve the steering rod nut locking tab from the inner steering rack shaft, then loosen the steering rod ball socket nut 1 turn.
9) Matchmark the tie rod end to the threaded shaft.
10) Remove the cotter key and castle nut from the outer tie rod end threaded spindle, and using a tie rod end removal tool, remove the tie rod from the steering knuckle.
11) Hold the tie rod with a wrench, and remove the outer tie rod end from the threaded rod, counting the number of complete turns it takes to remove the tie rod end from the shaft. Write the number of turns on a piece of note paper.
12) Remove the tie rod end lock nut from the threaded steering shaft.
13) Slide the steering rack boot off the shaft.
14) Remove the inner steering rod ball socket nut from the inner steering rack shaft.
To install:
1) Inspect the tie rod end for looseness, and the steering rack boot and tie rod end boot for cracks deterioration or damage and replace as necessary.
2) Clean steering rack shaft and apply a light coating of Genuine Honda Power steering fluid as necessary.
3) Apply a medium strength locking agent to the threads where the inner steering rod ball socket mounts. Use a new locking washer and a new stop washer, and install the inner tie rod onto the steering rack shaft.
4) Tighten the inner tie rod end fastener by 58 ft. lbs. (78 Nm)
5) Peen the lock washer over the nut or onto the flat surface of the steering rack shaft.
6) Apply silicone grease to the outer circumference of the inner tie rod end ball socket, and onto the groove just outside of the socket.
7) Apply silicone grease to the inside of the small end of the steering rack boot, and slide the boot over the steering shaft and onto the rack and install the boot clamps. If the boot has air hose fittings make sure they are installed as removed.
8) Apply a light film of an anti-seize compound onto the threaded tie rod end, and install the tie rod end lock nut.
9) Install the tie rod end onto the tie rod, turning it in exactly the number of turns it took to remove it.
10) Install the tie rod end following the tie rod end installation procedure.
11) The balance of installation is the reverse of the removal procedure.
12) Check the front end alignment and adjust as necessary.
Sep 10, 2012 | 1995 Honda Odyssey
I hit a curb and broke the racket pinion but replaced it and its making a squelching noise like the tires are squelching what could this be
If you hit a curb hard enough to break the rack and pinion, then you have also damaged some other parts in your front end. You need to take the car to an alignment shop and have it checked over. You could be looking at repalceing ball joints, tie rod ends, struts or even control arms. Hope this helps.
Nov 05, 2011 | 2001 Ford Focus
What is the distance from center of metal mounting bracket to center of other bracket for 24 inch ceramic Glacier bay towel rack
Put the towel rack together setting on a table and measure the distance between the two mounts.
make sure you know where the mounting bracket fits into the ceramic peace's.
Feb 03, 2011 | Home
How can I attach a ceramic towel bar inside a tub surround without drilling through the surround? I was thinking about a good water proof glue. Any suggestions??
You could use a good water proof glue but that would only work for a short while. What kind of material is the surrounding made of? Ceramic towel bars are normally set in ceramic surroundings. If you really must have this towel bar you may have to cut two squares out of the surrounding and put in two ceramic tiles, that way you can put ceramic on ceramic.
Oct 04, 2010 | Moen 24 In. Towel Bar...
How do I remove the piston on a 1957 Chev Belair power steering cylinder?
YOU HAVE TO REMOVE UNIT FROM CAR.REMOVE THE CONTROL VALVE ASSEMBLY AND THE ACTUATING LEVER.REMOVE THE PITMAN ARM SHAFT ASSEMBLY.REMOVE THE CAP SCREWS HOLDING THE UPPER END COVER TO THE HOUSING AND REMOVE THE END COVER.USE A SMALL PUNCH OR SCREWDRIVER TO REMOVE THE OIL SEAL FROM THE COVER BE CAREFUL OF THE NEEDLE BEARING.NOTE THAT IDENTIFICATION NUMBER OF THE BEARING IS INSTALLED TO THE OUTSIDE OF THE COVER.PULL THE RACK PISTON BALL NUT AND THE WORM ASSEMBLY FROM THE HOUSING.REMOVE THE PISTON RINGS FROM THE PISTON REMOVE THE BALL NUT RETAINING SCREW. TURN THE RETAINING SCREW HOLE DOWN SO THAT THE BALLS AND THEIR GUIDE DO NOT DROP OUT AND SLIDE THE BALL NUT AND WORM ASSEMBLY OUT OF THE RACK PISTON.REMOVE THE BALL GUIDE FROM THE NUT AND TURN THE HOLES DOWN.THEN TURN THE WORM BACK AND FORTH UNTIL ALL THE BALLS HAVE BEEN CAUGHT ON A CLEAN CLOTH.THERE ARE 23 BALLS.THEY HAVE A DEFINITE SIZE AND MUST BE REPLACED AS A SET.THEIR SIZE IS STAMPED ON THE END OF THE BALL NUT.REMOVE THE BALL NUT AND ADAPTER FROM THE WORM.REMOVE THE RETAINING RING WASHER AND SEAL.FROM THE NUT SIDE OF THE ADAPTER.CHECK OVER THE BALL RETURN GUIDES AND CLIPS THE RACK PISTON THE BALL NUT AND THE WORM.THE WORM AND BALL NUT ARE A MATCHED ASSEMBLY IF ONE IS DAMAGED BOTH MUST BE REPLACED WITH A NEW SET.DO NOT DISTURB THE END PLUG IN THE RACK PISTON UNLESS IT IS LOOSE.IT CAN BE DRIVEN OUT FROM THE INSIDE OF THE RACK PISTON.STAKE THE NEW ONE IN PLACE AT FOUR POINTS.THE END PLUG IN THE HOUSING IS DRIVEN TO THE OUTSIDE BUT IS INSTALLED FROM THE INSIDE.IT SHOULD ALSO BE STAKED AT FOUR POINTS.
May 04, 2010 | Chevrolet Chevy Cars & Trucks
Apple super mouse scroll button will not operate. tried cleaning oil off of it with napkin & water but still did not help. A new super mouse works great. but need to repair malfunctioning mouse Any...
Try unplugging the mouse, take a paper towel dampened with rubbing alcohol, and with the mouse upside-down, rub the scroll ball on the paper towel.
Then try using compressed air (the spray cans available at electronics stores) and spray in the cracks around the ball.
There is a way to get these super mice open, but it isn't pretty and doesn't always work. I don't recommend opening up this mouse..
Another alternative is replacement... There's alot of aftermarket mice and almost all will work on your mac with just plugging them in...
Jan 01, 2010 | Computers & Internet
Dish towel stuck to ceramic cooktop
When they are really bad, I use a razor blade in one of those scraper holders. Finally a green scrubby with some comet....Once finished polish it with a very good cooktop cleaner and you will be looking good as new.... If I can help further, I am here.
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Wolf Range 18 in. SPR-100 Gas Cooktop
Liberty Hardware Bath Unlimited Alexandria Rubbed Bronze & Ceramic Soap Dish Logo
88 people viewed this question
Top Liberty Hardware Home Experts
Donni Steen
Tom Chichester
Are you a Liberty Hardware Home Expert? Answer questions, earn points and help others
