Question about Garden
One valve of my Vigoro timer will not close completely. It's been in use since about March. Could it have sand lodged in the valve? Can I fix it myself?
  • 3 Answers
I had the same problem with several of mine. So I tore one apart. The problem isn't that the valve doesn't close. The valve uses a rubber diaphram that flexes in and out, sealing off the water supply. The rubber diaphrams develop cracks, allowing water to pass through the valve. The rate of water flow depends on how large the crack is. The crack will become larger over time as the valve moves the rubber diaphram in and out. The diaphram can be easily replaced. However, these units are not designed to be taken apart and repaired and I can't find a replacement for the diaphram. The bottom line is that once the diaphrams crack (and my experience is that they all do within 1-2 years-time), you have to throw it away and buy a new timer.
Posted on Jul 02, 2010
Need to known how to set the timer do not have a manual we have the VIGORO deluxe water timer, they are about two years old.
I do not know how to set the timer, but can offer possible source for manual.
VIGORO timers can be same as Melnor:
Match up image with your timer and then download manual.
Water timers last 1 or 2 seasons. There is no repair for broken water timers.
http://www.melnor.com/instructions.php
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 12, 2011 | Hardware & Accessories
The low battery light on my Vigoro 2 Zone Water Timer stays flashing even after I installed 4 new AA batteries. Can you please tell me how I can turn off the flashing light? Many thanks! Frustrated...
The problem is the valve is stuck and the little motor inside can't move the wheels to open or close the valve. This happens a lot. I have had two timers, and the same thing happened to both. Unless you are mechanically inclined and can figure how to take it apart, there's nothing you can do. I got inside and rotated the valve and hopefully it will work for a while before I have to do it again. If you want details on how to take it apart, let me know and I'll give you a few tips.
Sep 08, 2011 | Garden
How do I get free instruction for Water Timer Vigoro Duo- Deluxe Water timer # on front top lefte is 225-379 # on back is 0708
The vigoro duo delux might be same as Melnor 3100
Open following links:
http://www.melnor.com/instructions/3100_InstructionSheet.pdf
Take a moment and rate answer:
Sep 02, 2011 | Hardware & Accessories
I need instructions to the Vigoro- Duo Deluxe water timer 9 volt battery operated # on back is 0708..# on fromt top left is 225-379 Purchased at Home Depot I has5 to 6 cycles that can be programmed. I...
I have 2 Vigoro 196-036 watering timers. Why does water come out of the three holes near the battery compartment on one of them?
It comes out of the holes because the water goes in the holes. That might sound dumb but Vigoro designed these only to be in dry conditions, such as attached to the water line. I used them for sprinklers, but the water poured into the timer so bad it shorted it out in a week. I did find a vigoro timer with no holes and a sealed unit, and they work great. But I can't find them anymore.
Aug 25, 2010 | Hardware & Accessories
I bought a Vigoro deluxe water timer last spring, it worked fine all summer. This year I can't seem to get it to work, I hook it up to the spicket and the water runs thru the whole thing and in on the...
Jun 14, 2010 | Garden
Hayward Vari-Flow valve SP710X making cavitation noise w pump on.
These valves will get stiff with time and grit and sand will get into the shaft of the valve and make it hard to turn. As far as the noise, the valve is probally an 1 1/2" valve. The volocity of the water through the valve will cause cavation and this noise. When you get to the point where you need a new valve you can fix this by using a 2" valve.
Apr 15, 2010 | Hayward Pro Series Side Mount Sand Filter...
Do I turn the faucet on fully?
Yes, when using an inline water timer, it does not control the pressure of the water, only the "on/off" of the pressure. So make sure to keep the faucet at the pressure you want the drip system set at as if you weren't even using a timer.
Jul 19, 2009 | Garden
Freezer not freezing, and leaking
If this unit has an ice maker and you noticed water leaking into the refigerator, I had a similar problem. The water turn off valve for the ice maker had a small piece of sand or grit lodged in it and stopped the valve from closing properly. So it could not turn of completely and the valve became increasingly more sloppy as the piece of sand was wedged in further. The solution was to replace the samll valve. An easy job for someone a bit handy.
If the water has frozen in the bottom of the freezer compartment the colliing port for the cold air may also be affected. Don't chip the ice out of the bottom, defrost it with pans of hot water.
Hope this helps
May 03, 2009 | Frigidaire Freezers
Garden Logo
127 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
