Question about Black & Decker Garden
Why does bag keep coming off - Black & Decker Garden
  • 437 Answers
May be time for the bag to be cleaned so air can flow thru it when it is on the blower. or you may be missing the band to hold it in place.
Posted on Sep 26, 2009
AIR BAG LIGHT KEEP COMING ON DID SEND IT AND BEEN RESET STILL COMING ON
There is a code stored in the air bag computer , have it checked an fixed by a qualified repair shop !
Sep 02, 2016 | Cars & Trucks
HOW TO KEEP IT JUICY AND TENDER IN OVEN?
Brenda, they now sell a type of oven bag that will help you out.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Bags
How to make moist Thanksgiving Turkey using reynolds oven bags
Mar 23, 2016 | Ovens
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
How to keep my oreck xl bag docking station attached. bought
Put smaller part of bag docking system on first. Seperate it from the other. It has to be pushed on past plastic lip around hole. It should feel very tight. Then attach larger part of bag dock onto the smaller one.
Jun 13, 2014 | Oreck XL Ultra Bagged Upright Vacuum
The bag will not stay attached it comes off the rubber nozzle and dirt gets everywhere my old oreck had a much better design with the velcro closure.i am very dissapointed.
Please make sure that the plastic pieces that holds the outer/inner bags on the vacuum are attached properly. Push the outer (permanent) bag down against the vacuum. It will go over a black lip. Put first piece of the bag dock on..make sure it is behind that lip also. When you reattach the second piece to the dock, this will tighten the docking system. It will keep the outer bag on and keep the inner (disposable) bag in place so that it is catching the dirt...not the outer bag.
Sep 23, 2011 | Oreck XL Ultra Bagged Upright Vacuum
Aerus Lux 7000: the full bag light keeps coming on but the bag is not full.
Electrolux uses a pressure differential control valve. This valve measures air before and after the bag. There is a orfice or small hole where the hose connects to the vacuum cleaner, and a orice at the back of the bag canister. As the bag fills up the suction pressure reduces at the hose connection and increases at back of the bag canister. When this happens the control valve has a diaphram that closes, which shuts the vacuum off and gives you a full bag light. There is a thin plastic flange that prevents an o ring on the control valve stem from coming off. The flange breaks, the o rings comes off the stem and the vacuum will shut down indicatiing bag full. The after market price is about 22.00. The valve is easy to replace if you are familiar on electrolux vacuums. When I replace these valves, I use epoxy two part plastic putty on the flange of the valve. It takes 2 days to cure, but the flange will not break.
Jun 25, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Air compressor keeps running what may cause that
it is possible that a leak has occured or that a sensor has come loose indicating to the compressor module that the air bag still needs to be inflated. proceed underneath to each bag and lines and listen. if no leaks are heard then look for arm near the axle that mayhave come loose also sensors on the bags themselves.
Aug 18, 2009 | 2004 Hummer H2
Garden Logo
55 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
