Question about Denon AVR-985 6.1 Channels Receiver
It seems to pick random days not to output any sound. When it does not output sound it doesn't matter what the input is, even the tuner. The next day all is well. Then, another day, no sound again. Video comes through just fine. I have already tried: - going through setup - adjusting too many of the settings to list - turning off and on my components in different orders (just for kicks)
I have a similar problem. Called the company that sold/installed it. After 2 months they tell me that it is a heat problem with the processor. They are checking how much to fix.
Posted on Apr 26, 2010
Sound ok but no picture
see the b. diagram and test the power supply ;transistor, fuse, filter, switch, c.breaker rectifier,IC regulator voltage.
measure the horizontal output =125vdc
all other circuit:12vdc
color:12vdc
Oct 17, 2012 | JVC Televison & Video
No sound...We moved the TV from one place to another and lost our sound... I have a multiviewer 4 dual tuner PIP
Try to check the cables specially the input, output of your digital receiver specially the audio cable. Good day and best regards.
Aug 07, 2011 | Hitachi Televison & Video
Hitachi L26D103. Less than 2 years old. Working fine one day. Turned on the next day and the sound works, but not the picture. This is an issue when in both the TV and DVD modes.
Good day!
If your TV doesn't have a picture even you play a DVD it means there is problem to your TV.It could be the Inverter board or the cold cathode lights is busted.
This are the steps on how to fix that problem.
  1. Remove the back cover of your TV.
  2. After that,plug in the TV and power it ON to perform a voltage data.
  3. Check the the output voltage of your power supply by using multimeter tester (range in DC) then check the 24vdc(supply of inverter board).
  4. If you have 24vdc in power supply output,check also the input voltage of inverter board if have 24vdc.If doesn't check the wire connection from power supply to the inverter board.
  5. If have you input voltage of inverter then check the high voltage output of it,if have at least 500vdc so be careful to check it because it have a high voltage.
  6. If doesn't have high voltage output replace the inverter board and if have a output voltage the cold cathode lamp inside is busted so you have to replace it
The inverter board looks like this:
You can buy it to this link: http://www.shopjimmy.com/catalogsearch/result/?q=Hitachi+L26D103+inverter+board
If this solution will be helpful please rate my answer. Thank you and good luck.
May 06, 2011 | Hitachi L26D103 LCD TV
I need to know what input & output connections are available on the Akai PDP4290 Plasma TV?
This was the cheapest Akai in its day. No Tuner, No Speakers, must use a surround sound or regular stereo amp for sound.
It also has the standard A/V input also.
Best to use a HD Box and RGB cables for best picture.
Dec 04, 2010 | Akai PDP4290 42 in. EDTV-Ready Plasma...
I just picked up a used Onkyo TX-SR502 receiver that has no audio output on any of the channels. I obtained a service manual for it and have tried a few things, but dont know the source of the problem...
I have the same problem, how did you initiate debug mode ?
The receiver worked perfectly until a few days ago, then one day it didn't work when I turned it on but started working after a few minutes. The next day it did the same thing and the folowing day it didn't work at all. Have tried the power reset and also had the top off to see if there's anything really visibly burnt - nothing.
This receiver never got bad treatment, left on overnight a few times but not with sound running out, just powered up. It's a bit enclosed I guess so maybe overheated but I find it hard to believe.
Anyway, can someone advise how to initiate debug mode and also what to do with it.
Thanks
Oct 04, 2010 | Onkyo TX-SR502 Receiver
Re: Technics HD51 home stereo system (amp, tuner, CD, and cassette player) - I'm told it needs a pre-amp in order to get any reasonable amount of sound out of lp's on the Linn Sonex LP12 turntable. At the...
The Amplifier must have a high impedance input for the turntable to be connected. Now most of the present day amplifiers do not have this input but only the regular aux input which is designed for a larger signal . But the turntable outputs is quite low and so it requires an amplification of high order. What you can do if you need to play the turntable is to have first a preamplifier with a high impedance which is available even inkit form and can be fitted on to your system. The preamp output can be shared into the input of the source selector maybe with a switch and you willl be able to fix two RCA sockets to accept the input of the phono. This will work fine provided the shielding is done well to avoid the high feedbacck to oascillate and cause noise, the premap must be housed in a shielded cabin. On the other hand you may have to buy a universal amplifier so that the phono input is present. Definetely nothing better than a designed input. So think and decide. hope I could help; Good day
Aug 10, 2010 | Technics Audio Players & Recorders
How do record a movie or a live feed on a zenith vcr? we can't seem to do it
First of all, if you have a cable box for cable TV this will be first in line. Next connect the antenna in from the VCR to the cable box (or antenna system)output. Lastly, connect the output of the VCR to the RF input on the TV. With this setup you will need to tune the VCR tuner to the output channel of the cable box (ch3or4)If your TV has audio/video inputs you can connect the DVD/VCR to your TV with these cables instead of the RF cable. Your TV will have to be on ext video inputs.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 31, 2009 | Zenith Televison & Video
No output
I have this same problem, I took my unit to a Denon authorized repair center and after 12 days and $50 to check out the problem they have told me that my DSP was bad and that Denon no longer makes that part. For a unit that about 2years old and no parts???
any help would be appreciated.
Nov 12, 2007 | Denon AVR-2805 Receiver
Random no audio
I have had this happen with this particular brand frequently. I have it plugged in to a power "strip" or surge protector. I find that if I turn the strip off then on again, it resets and fixes the problem.
Feb 18, 2007 | Cyberhome CH-DVD 300 DVD Player
Denon AVR-985 6.1 Channels Receiver Logo
74 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
