Question about Acard Technology (ARS-2030LD) DVD±RW Burner
I have a Acard 1 to 3 Burner I click 5 up arrows to select source click select source click Slave Click 8 down arrows to "copy" Normally the screen reads " preparing " Now " PARTITION TOO SMALL " comes up. What does this mean and how do I correct the problem. thank you lawrence mitchell
    Genius:
  • 1,043 Answers
This message normally means that you do not have enough room left on your hard drive to create the image to burn the data you are trying to copy to your blank disc. All you should have to do is go through your hard drive and get rid of any files that you do not need. If you have a defrag program you should also run that to further clean up your drive and make it easier to burn your data. If you are burning regular cd's you should leave at least 1 Gigabyte of free space for each disc.
Posted on Sep 26, 2009
Acard technology 1 x 5 burner manual
Check out this manual .... at:
http://www.wimmedia.com/content/support/adtec_manual_standard.pdf
Mar 05, 2014 | Acard Technology Acard ARS-2030A 1-to-5...
5 disc burner just hangs at 100 percent some of the time other times it burns perfectly i even updated the firmware
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Aug 24, 2011 | Acard Technology Acard ARS-2030A 1-to-5...
Acard duplicator - 'Source drive not ready'
> source drive not ready
When you push the button to open/close the drawer, does it work,
i.e., is there electrical power reaching the drive?
Did you put a disk into the "source" drive?
Is the same disk recognized when you put that disk into any other computer?
If so, then the "source" drive is damaged, and needs to be repaired/replaced.
Jul 18, 2011 | Acard Technology 15 CD DVD Duplicator...
Burner keeps telling me it has burned the cds to 100%, but nothing is being copied to the blank dvds
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem
It could be a problem withthe lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the acpower 3. remove powercable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps
don
Feb 16, 2011 | Acard Technology (CD1TO7T) CD-RW Burner
Error 19
Hi
You can try the following steps to resolve the Code 19 issue.
1. Click Start.
2. Click Run.
3. In the "Open" field type REGEDIT.
4. Click OK.
5. Click "File" in the menu bar.
6. Click "Export" from the drop down menu this will open a new box.
7. Click the down arrow beside "Save In" and select "Local Disk (C".
8. In the File Name field type BACKUP.REG.
9. Verify that under the “Export Range”, that the radio button is beside "All".
10. Click Save.
11. Click the plus sign (+) beside HKEY_LOCAL_MACHINE.
12. Click the plus sign (+) beside System.
13. Click the plus sign (+) beside CurrentControlSet.
14. Click the plus sign (+) beside Control.
15. Click the plus sign (+) beside Class.
16. In the left hand window pane click on {4D36E965-E325-11CE-BFC1-08002BE10318} to select that key.
17. In the right hand window pane select the UpperFilters registry key and press the delete key on the keyboard.
18. Confirm with an OK.
19. In the right hand window pane select the LowerFilters registry key and press the delete key on the keyboard.
20. Confirm with an OK.
21. Click the "X" in the upper right hand corner of the Registry Editor window to close it.
Jul 16, 2010 | Sony Optiarc AD-7240S 24x DVDRW DL SATA...
I'm having the exact same problem...
The solution to this is simple. On the menu when you see that the # of MB is 0MB. Press the Arrows that change the menu option to #8 Select Source. Change this back to your original DVD-Rom or RW drive.
Aug 05, 2009 | Acard Technology (ARS-2030LD) DVD±RW...
SOURCE DISK EMPTY-- when there is master disk in there
Jul 26, 2009 | Acard Technology (ARS-2030LD) DVD±RW...
Help switching Samsung sn-m242 cd burner from master to slave
If you are to be using two DVD drives and want one as a slave, hook up both together as you would a hard drive with the ribbon cable. Restart the computer in CMOS by hitting F4 (may be different on your system) If you navigate a little with the arrow keys and the enter button, you will see boot options. Often the DVD player is first or second after Floppy and the hard drive last. Now you should see two DVD drives (if thats what you have), just select it to be a slave. This also works if you have only one DVD drive and want it to be a slave. Just select your DVD device to be the second boot option. Windows XP detects hard ware on its own and should not need any firmware unless the burner is made for Windows 95. If this does not answer your question, let me know.
Nov 20, 2007 | Computers & Internet
Acard burner
install the cd software that came with it.
Nov 12, 2007 | Acard Technology (ARS-2030LD) DVD±RW...
Acard Technology (ARS-2030LD) DVD±RW Burner Logo
55 people viewed this question
Top Acard Technology Computers & Internet Experts
Martin Murray
Alun Cox
DROPNDEAL
DROPNDEAL
Are you an Acard Technology Computer and Internet Expert? Answer questions, earn points and help others
