Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
I have a 19hp craftsman 42 deck. It has two blades. It does not cut the grass in the center. It leaves a strip uncut. What adjustment should I do
  • 437 Answers
You may be running too fast on ground speed for the mower deck to cut completely. It may be time for some new blades. The blades may be worn down to where they are shorter than when they were first put on.
Posted on Sep 26, 2009
I have a Craftsman SL3500 42" riding lwan mower. the two blads make uneven paths ans the left blade makes a cut about 1/4" lower than the right blade. What do I do?
You should be using a up lift blade it will help by sucking up the grass to be cut. You should have an adjust on both sides of the blade deck . As for the strip check to see if you have a wheel behind the mower deck. If you do it might be the cause for mower leaving a strip uncut . Sears has been noted for putting wheels in the path of the blade area and smashing the grass down . That is also why I suggest to use an up draft blade it should **** the grass back up again so you can cut it.
Oct 07, 2013 | Craftsman Garden
I have a John Deere LA105 Riding Mower and when I mow it leaves a strip of grass in the middle. Left and right sides are cutting fine. I have taken the blades off and shaarpened them and have leveled...
jack the tractor (using a tractor jack) or remove the deck, measure the blade tips against each other where they meet in the center of the deck and see if they are the same tip to tip. Bearing wear, a bent deck or blade can make them cut at different heights in the center.
Sep 25, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Uncut grass in center & higher grass cut on right.
Hi, this may sound obvious but make sure the new blade is the same type as the old one and make sure it is not fitted upside down. Spin the blades and make sure the tips are level with each other, this will tell you if the deck is straight where the blade spindles mount. Regards Phil.
Jun 24, 2012 | John Deere Garden
I have 11 years old Murray (42 inch deck). After deck adjustment still leaves uncut portion of the grass between blades. Should I exchange the blades (I have not done it for many years, but I sharpened...
On a two blade deck, such as yours, there is generally an overlap between the cutting coverage of the blades so that you do not leave a mohawk. This does not work well on turns however, and the sharper the turn, the more grass is left. Overcoming that issue brings you up to a 3 blade deck. If your mower is leaving a strip of uncut grass while cutting in a straight line, somehow you are running blades for a smaller deck, thus there is no overlap. The mandrels are offset, one slightly in front of the other so that the blades do not hit each other. I would measure under the deck and see how long a blade could be and still fit within the deck and not strike the other blade, then ask a parts store to sell you something longer than what you have now.
Oct 20, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
It leaves the center uncut
i think i would raise the whole thing up on jack stands and take a look at the bottom of the deck. do not start it of course, but the problem should be evident. 42 inch generally means only 2 blades which are cutting on the outside leaving you a mohawk. so something is blocking the grass from being cut in the center. if it is by chance a 3 blade deck , then something is wrong with the center blade, if it is there i would guess a broken key.
Aug 23, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
I have a Craftsman Lawn tractor. Blade leaves grass uncut.
Hi Tom,
Check your spindle shafts for loose play. If your bearings are worn out and sloppy, the belts pull the spindle to one side and an angle cut results... close cut grass at outer edge and high in center will leave this grass trail you are describing. I'd replace the bearings next year for sure.
I hope this helps... Good luck!
Oct 04, 2009 | Garden
42 inch craftsman. Replaced bades and now have a row of uncut grass in the center of cut.
OOPS! I hate to tell you but you most likely put new blades on that were too short. Check your manual and get the proper length blades. If you still have the old ones, check them against the new ones and you will see that they are shorter resulting in the uncut grass in the center.
Jun 23, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
A row of uncut grass left between blaces when mowing
THE answer that FINALLY worked for me. Torque the bolt that holds on the blade to the recommended torque specified in your owners manual (for my Exmark this torque is 120 ft-lbs). When I first used the torque wrench, i was quite surprised by the amount of addional force I needed to apply to reach 120 ft-lbs Exmark blades have a round blade hole with a washer and therefore, relies only on friction provided by torquing bolt to the proper torque to prevent slippage so that the blade rotates at the same speed as the spindle. When slippage between the blade and spindle occurs, blade tip speed slows leaving uncut grass.
Note: this solution will NOT work for mowers with a blade and spindle design which uses a positive means (e.g., a star shaped hole on the blade) that assures the blade rotates at the same speed as the spindle with no slippage.
Jun 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
592 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
