Question about NEC MultiSync LCD1810X 18.1" LCD Monitor
Power unit failed
No output from unit, can I buy a new unit/ is it repairable
John Gerrard
    Problem Solver:
  • 11 Answers
Was the monitor working prior, as in was it working then stopped? If yes confirm if you can by hooking it up to another computer. Sometimes it may be your video card. (I have seen a simple pump on the side of the cpu case dislodge the video card enough to cause the monitor to go blank.) Once you are sure get a new monitor, they are much cheaper and better than just 2 years ago! Will cost less than 2 hours in a computer shop.
Posted on Sep 26, 2009
I mistakenly connected energy source at the AC inverter output .Inverter is 5KVA cyberpower inverter.After correcting the connection, It cannot switch from DC to AC( fault signal is displayed on its...
John,
It's shorted out, either replace the part or buy a new one.
If you need UPS, Surge, or Power Related help don't hesitate to contact me!
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Sep 24, 2013 | Cybernet Systems CyberPower DC to AC...
My intex pool pump want come on. Would air in the lines cause this?
No...Either the unit is not getting power or the motor pack has failed and will need to be replaced. Try another electrical device in the same outlet if you do not have a meter to measure voltage at the pump. If the device such as a lamp or radio works then the unit is getting power...unfortunately there is no repairing those pumps so you'll need a new one.
John
Mar 21, 2011 | Intex Pool & Spa
How can i repair a power suply
9 times outa ten there is a small 2.5 amp fuse inside.
you will have to desolder it and er-solder a new one in.
Oct 07, 2010 | RaidMax 350W Power Supply...
The power light blinks rapidly,no response from the power button and no video or audio output.
when your power lite thats tell you sommething wrong count flash then go to sharp flash code to fine out whats wrong
Jun 24, 2010 | Sharp VC-H810U VHS VCR
FAN RUNS BUT NO OUTPUT
It has failed, although if you open it up carefully, there is a...or there maybe a fuse like a 13amp but of a much lower capacity which sometimes after some usage blows. This usualyl renders the unit dead as a dodo. Frankly its always best to buy new .... dirt cheap on ebay!
Jan 04, 2010 | E-Machines Emachine T5026 power supply **...
NOT CHARGING CANT TURN ON
The modern adaptors are 'switched mode' that allows them to accept a wide range of input voltages (typically 100-240 VAC). Unfortunately, they have some components in them that are critical to their operation and on these, many mfrs. like to cheat on quality. This causes the early demise of the supply.
I saw Acer supplies offered at <$20 US searching on Google so I suggest you replace the supply. Note; this may not fix your problem anyhow as most laptops have a bit of circuitry inside to control the input from the pack and choose whether to use the battery or not. If that fails, the unit may not receive input from either.
Sep 15, 2009 | Acer Ferrari 3400 Notebook
Denon 455
Typically amps do that for one of two reasons:
1. All the speakers arent connected proper
or
2. One or both of the amplifier output modules have failed.
I dont know if that model uses discrete transistors or STK type units.
Most of those parts are available off the shelf though
Jan 25, 2009 | Audio Players & Recorders
WHERE CAN I GET SERVICE ON A MODEL DPF15K DIGITAL PICTURE FRAME?
i have had the same problem and i have resolved the problem as following : - measure the output tension on the external power unit ... she must be 12v ... on my unit i had 10v!!! - open it (it's difficult but not impossible) ... look at the 2 condensers 1000uF 16v ... change them and you will retrevie the 12v output and your frame picture. - an another solution is to buy a another 12v-3A external unit
Nov 30, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
Hitachi charger failed
hi
whenever youve got problems with your charging unit, check out if the capacitors are busted. but i its not, dont take a risk and buy a replacement instead. lets just avoid accidents with that. hope this helps.
Jan 25, 2008 | Video Cameras
Standby light but no power
Your set has a output problem you will have to take your set to the repair shop and have them change the output IC or Transistor.
Jan 20, 2007 | Durabrand HT-3915 System
NEC MultiSync LCD1810X 18.1" LCD Monitor Logo
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
