Question about Paragon Partition Manager 9 Personal Full Version Volume License for PC
I have Paragon Partition Manager Professional 9.0 ~ Retail and installed it on my Windows XP Home PC when I went to boot up after shut down I get a blue ''Paragon Technology'' screen with a message saying: ''BOOT'' and a count down indicator starts from 15 seconds to zero ina a pannel on the right hand side of the screen, when it reaches zero it starts to count down again and won't reboot, it won't go to safe mode either after tapping ''F8''...any idea's? Thanks in advance
  • 103 Answers
To get your boot configuration back you need to boot eith your windows xp cd and enter into recovery console mode
type the following commands
fixboot c:
fixmbr
bootcfg /rebuild
Posted on Sep 27, 2009
Configured an additional active partition on a sd card on my Winvista laptop already having an active C: partition. Now there's a paragon boot manager holdup during startup. help!!
You may be able to fix by typing MSConfig in Start / Search. Choose boot. You can verify boot path, delete, and move positions. Be very careful. You can a critical choice.
Jan 09, 2013 | Computers & Internet
Greetings, I need help trying to recover some files on my pc. I had an XP installation working fine on a single hd setup with about 25 gb free space. I tried partitioning the drive (c to free up that empty...
http://pcsupport.about.com/od/findbyerrormessage/a/missinghaldll.htm
It seems like that "free" partition manager, was not free after all. When it's something as important as your HD you should seriously consider anything free as "if this doesn't work, u'll get NO help" type of thing. It sounds like it's trying to boot from the part of the drive that you partitioned and now can't because there is no OS there (or a damaged one). Depending upon how important the folders are u may want to consider professional recovery. Wish I had better news.
Apr 27, 2010 | Microsoft Windows XP Home Edition
New computer built, XP installed, no full HDD capacity??
Check your motherboard BIOS specs. I know that Windows XP can see a larger hard drive but some BIOS issues could limit the maximum partition.
(My XP box started with a small drive but I added a larger SATA drive later and formated it with the XP disc management software. One caveat: I was using SP3)
To expand your partition, try using a third party partitioning software option. These will often save you from having to reinstall the os (sometimes things go wrong but mostly they are good). I've had good luck with Paragon Partition Manager and Partition Magic (before it was purchased by Symantec).
I hope this helps.
(Paragon offers a 30-day free trial of their Partition Manager software; however I am not aware of the limitations of the software.)
Mar 29, 2010 | Microsoft Windows XP Professional SP2
Windows doesn't recognize recovery partition after os reinstall
The issue you are having involves using multiple systems,...If your emachine came with vistan and you installed xp, you voided your warranty status...However remove your dual boot and stick to vista if you wanna keep your restore partition working properly.....On a side note theres usually conflict with running OEM OS's on dual boot...typically it doesnt work and if it does it doesnt work like you want it to! so here is what you can do..Call Emachine up and fib to them a bit (just alittle) tell them that you cought a nasty bug and it messed with your restore partition and now you cant restore your pc....request the factory programing discs (if you ask nicely they'll hook you up 99.99% of the time) you get the discs so you can reprogram the pc to factory spec if you ever wanted to. Now use a retail version of vista and a retail version of xp. and create your dual boot, feel free to remove your restore partition if you want (cause you have the factory programing discs if you wanna go back to stock stuff YAY) I hope this helps!
Sep 26, 2009 | E-Machines eMachines Desktop PC
Problem installing xp
You can install both wista and xp in the same computer, better for this to create new partition (resize ild one and free some space and create partition in its place) then install XP created partition (partition create is possible professional tools paragon partition manager, norton partition magic or other).
afrer restart only XP works, then insert VISTA install cd and "fix boot"
Here is brief discussion about this VISTA>XP or XP>VISTA.
Take care of drivers may some of them dont be created for XP if your pc is super new.
Aug 20, 2009 | Microsoft Windows XP Professional With...
I installed Paragon Partition Manager and set up boot manager. It said to restart my computer and I did. Now there is a boot screen that only shows one partition it says XP and the right side says boot...
If I were you I would pull the harddrive out, slave it to another machine and save all your documents before putting your harddrive back in and doing a full Dell restore.
Any wrong move at this point is likely to damage the MBR and render your machine unable to boot up at all.
Aug 09, 2008 | Computers & Internet
When I boot up my computer before windows xp loads it asks which operating system I want to run,and it gives me 2 choices WINDOWS XP HOME, or, WINDOWS XP HOME. You use the up and down arrows to select...
simply you can remove the second option in the boot.ini.
go to the or right click the my computer at the desktop and the properties. and then click"advance TAb" in the start up and recovery, click "setting" and then "edit"
you will see this:
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(2)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
Timeout=30 change to: 0
and then delete this:
after deleting you must save it.
and then restart the system
Please leave a comment b4 your rate, Thanks!
Jan 28, 2008 | Computers & Internet
Install win xp and erase win vista
Would like too know how to erase win vista and install win xp
Dec 29, 2007 | Microsoft Windows XP Professional With...
How to remove a second installation of a windows o/s
you would not have been able to install xp home over xp pro as pro is an upgrade from home, so xp pro will be on a different drive partition, so the last version you put on will be on the 'C' drive as thats the one that is bootable. Follow your instructions, or simply use your xp disc to format the drive and install XP home.
Jun 13, 2007 | Microsoft Windows XP Professional for PC
Paragon Partition Manager 9 Personal Full Version Volume License for PC  Logo
82 people viewed this question
Top Paragon Computers & Internet Experts
David Payne
David Payne
Are you a Paragon Computer and Internet Expert? Answer questions, earn points and help others
