Question about Nintendo DS Lite Console
Every time i press the left trigger it doesn't work.Can you help me fix it?
    Scholar:
  • 50 Answers
Your trigger is out of the socket, or the connection is broken.
Open it up using the www.powergamingparts.com forums, and then take out the trigger and spring, put it back together, and then see how it works.
If it still doesn't work, contact me again and then we will see what happens from there.
Posted on Sep 27, 2009
How do you reset all family settings on xbox 360
There are different codes for different 360 consoles and different dash versions:
1. On the 360 dashboard, scroll over to the "System" tab.
2. On the System tab, click "Console Settings".
3. Scroll down in console settings and click "System Info".
4. When the system info box comes up SCROLL TOP THE BOTTOM and type in this sequence:
LT RT X Y LB RB Y "Left Stick in" (press it in and hold it in) Y Y
A box should come up and say, "Would you like to reset the console to the factory defaults?"
Click Reset and you're done!
!!!HERE ARE MORE CODES THAT HAVE BEEN TESTED AND WORK!!!
LEFT TRIGGER, RIGHT TRIGGER, X, Y, LEFT BUMPER, RIGHT BUMPER (Do this twice)
LEFT TRIGGER, RIGHT TRIGGER, X, Y, LEFT BUMPER, RIGHT BUMPER, X, X, UP, DOWN, DOWN. Then down, down again.
Left Trigger, Right trigger, X, Y, Left Bumper, Right Bumper, DOWN (dpad), Y, Left, Left
Jun 22, 2014 | Microsoft Xbox 360 Console
How do you fix a jammed trigger on the Ryobi 10 Amp Electric Power head
Not really a fix but it worked for me. I opened up the case. Their is a little black box with a red button that must be depressed. Pulling up on the trigger pushes the button. Their is what i call a counter press above the trigger. By pressing it, it makes room for the trigger to slide up and press the red button. There isn't much you can do improve this process. But i took the two springs off the trigger and depressed them trying to shorten them thus reducing the force needed to press. The counter press in spring load. I carefully stretch it by pulling on the end directly above the trigger(not against the frame). This took some pressure off the counter press. I finally took a small file and carefully filed down the edge of the counter press where the trigger presses against. This makes it slide upward easier even if the counter press isn't pressed down fully when you squeeze it. The trick is pressing the counter press first, but doing these things has made my trigger a lot smoother. It use to be a hard press to activate, but now it is 10 times better than it use to be. Good Luck!!
May 17, 2014 | Ryobi 10 Amp Electric Power Head RY15122
Avital 2100 wont let me program 473 L remote
is the door open? door trigger switch has to be installed either green or violet wire the blue instant switch doesn't work as a valid trigger
May 10, 2012 | 821001/2100 2100 Security System
Please,Could you help me to reset my XBOX 360? My son doesn' t remember his family parental code? My S/N # 033015292707
Go to the system info screen under console settings. HIt Left trigger, Right trigger, x, y, Left bumper, Right bumper, up, left bumper, left bumper, X.
You have to do it quickly or it wont work. This will put it back to factory default setting
Oct 21, 2010 | Video Game Consoles & Games
My xbox 360 controller left bumper trigger wont work. I have opened it but it looks like nothing is wrong and it doesnt wiggle or move at all? please help
The contact point on the left trigger might have failed already due to wear and tear since there are moving parts, and if there are moving parts there is friction thus likely could damage the contact point of trigger whenever being pressed. The might need to be replaced in that case.
May 27, 2010 | Microsoft Xbox 360 Controller
Nintendo DS left trigger malfunction
the l and r buttons have springs behind them it could be the spring has snapped and the button has fallen onto the switch. the next time it happens hold the ds upside down if it stops its the spring if it doesnt stop then its the micro switch gone faulty and you would have to open up the bottom casing and replace it, its soldered on the motherboard and is smaller than a pea with 5 soldered joints.
Jun 27, 2009 | Nintendo DS Lite Console
The Right Trigger isn't working at all
I had a similar problem with my left triger but cross731 had said to lift up the triger with your finger nail, and blow into the hole. This supposedly gets rid of dust. Now if you have damaged it by dropping it several times than.. I recremend that you take it in to be fixed.
May 31, 2009 | Nintendo DS Lite Console
Nintendo DS Lite, left trigger not functioning
The thing that cross731 said really really helps. If your too scared to open your ds/ds lite, just put your nail under the trigger pull up and just blow into the little hole that you see. It works I just tried it and my left rigger is working just fine.
Feb 05, 2008 | Nintendo DS Lite Console
Left Trigger
if you undo the screws from the underside of the controller and gently part the body just enough to see the back of the button, then spray a very small amount of WD40 or any lubricating liquid around the button and press button gently in and out to lubricate it.
Jul 29, 2007 | Microsoft Xbox 360 Console
Nintendo DS Lite Console Logo
180 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
